Question about Network Associates Symbol Wireless Networker 802.11b (NIC-WSYO-NA-100I)
Vpr Matrix 220A5 wireless network not working
Vpr Matrix 220A5 always used with cable, internet ok. Past 2 weeks tried wireless for first time and did not work. When inspecting laptop,wireless card was not present so I bought one. After installation, I do not see the antenna icon on the task bar, nor on the network connections page. I installed the driver with no avail. Any suggestions?
  • 22 Answers
Please follow the mentioned step to check if the Wireless card is installed properly
Step 1 :
> click on start (assuming it to be a windows OS)
> right click on "my computer" and select "Properties"
> you will have the system Properties window pop-up
> under the Hardware tab, click on Device manager button
> under the device manager list look for network adapters
> you should now be able to see your wireless card under network adapter - check if the adapter is enabled ( if not kindly enable by right clicking on the adapter)
> once the adapter is active - it will have a green icon with not error on it.
Once you complete the above task you may follow the below mentioned step.
Following the below mentioned step will help the Microsoft to take control over the card and try to connect (instead of the software provided by the card manufacturer to control the device)
Step 2 :
> click on start
> Select Run - new window will pop-up
> type "Services.msc" - new window pops up
> scroll down to the bottom of the list
> right click on "Wireless Zero Configuration" and Start (if not already started)/Restart the service.
> now close all the windows and search for wireless networks again
you should be able to find it
Posted on May 10, 2010
Network Adapter will not work on Startup
Attach a Ethernet cable to the laptop, Open Device Manager, Network Adapters, Uninstall the Wireless adapter, reboot, Allow the software to apply the generic driver, try to connect to wireless network. Post results.
Jan 26, 2013 | Acer Aspire Computers & Internet
My Rangemax wireless wndr3000 is not working properly, though it has in the past. The problem seems to be that I'm hooked up to the wireless network (ex. I can print wirelessly), but with no internet....
Same situation here. Wired connection from modem works fine. I can also log in to the router via routerlogin.net. However, the router does not detect an internet connection.
Jul 12, 2011 | NetGear WNDR3300 - RangeMax Dual Band...
Wireless no longer accesses router
OK try this go to that PC, go START>>RUN>>service.msc (enter) Now when services window comes up, scroll down to DHCP, set to OFF & Disable, reboot, now try again. Sometimes just a Turn it ALL OFF, and ON again and most often it will sort itself out., IF it was working OK prior. You could always run the "Connect to internet Wizard" again, and do that. Also go into router and ensure that DHCP, is set to ON in the Router. Sometimes, a simple re-setup will get it all working again too.
Apr 01, 2010 | Belkin F5D7010TTSN-W WIRELESS 802.11G...
I cannot connect to the internet with my linksys wrtu54g hotspot. It was working until 2 weeks ago. I get error message that says - a network card is incorrectly configured. The card should be able to...
The network card should be configured to obtain a IP address automatically,
Open Control Panel - click on Network Connections - right click on the network/wireless card - select Internet Protocol (TCP/IP) and click on Properties and then enable Obtain an IP address automatically and enable Obtain DNS server address automatically.then click OK and click OK again.
Dec 21, 2009 | Linksys Wireless-G WRT54G Router
Problem with DIR 655
On the laptops, check that your Internet is set to use "Private" networks as opposed to "Public". Private networks allow others to see you and you to see others on the network, once you've entered the proper pass phrase as set up in the router's software. Your Manual for the router has the instructions you need to complete this process.
Dec 15, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Wireless network access: 1 laptop fine, other not so much
Check the wireless card on the PC first. Go to "My Computer" then "Device Manager" and check to se if all the hardware is ok.
Use Control panel/netconnections to check to see if you still have a wireless connection and if it works. Also check "My Network Places." Try re-installing the drivers.
As a last resort....try System Restore if it's an XP or Vista system. Remember - using system restore will return the PC to an earlier time but you could lose some stuff so decide first.
Mar 21, 2009 | Acer Computers & Internet
Loss of internet connection
Please google "network magic" from cisco. Get it ... free for a limited time then they want $ or ... keep using the limited version for free.
I use the paid pro version to manage my network and I love it.
The program is easy to use and will perform all the functions you will need to stay on the WWW. Did I mention it is SIMPLE to use yet it is complete and comprehensive. It will help with wireless security too, if that is an issue.
Dec 26, 2008 | NetGear RangeMax NEXT WNR834B Wireless...
"The process mdns stopped unexpectedly..."
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Are these printers connected with a LAN cable directly to the router, or are they wirelessly connecting to the router?
HP C8180 has built in wireless adapter and Ethernet according the Website at HP.
If this is connecting to the network wirelessly, check to see that it is connected to the Network, is your router using secure passwords for a connection to the network,
Your printer will need these passwords just as your computers would
If you connect the printer with a Lan Cable, it will be more reliable, and shouldn’t need a password to be on the network. And makes life a little easier...
Your internet provider has nothing to do with your Printer not printing; this is an Internal Network Problem. The settings or your network has changed.
The Printer should have a static IP address
Here is a link to a tip I put together about this subject,
http://www.fixya.com/support/r1173875-network_connected_printer_not_printing
If you need any further assistance, feel free to contact me...
Oct 26, 2008 | HP Photosmart C6180 All-In-One InkJet...
Setup asistant will not work with Belkin wireless router & computer
Try the manual method.connect router to pc with ethernet cable
1.logon to 192.168.0.1
2.Connection type ; PPPOE
3.type in your username@ISp and pass
4.Save settings
5.Configure wireless setting(SSID,Wep)
Configure pc with the same SSID and WEP
uplug the ethernet cable and check if your are able t connect wireless
if you still have issue use this guide
Cheers !!!
Feb 23, 2008 | Belkin (F5D7230-4) Router (587009)
Can't Connect to the Internet
Two things you can try before trying your browser/Internet connection:
1. Right click on the Wireless Network Connection Icon, click on Repair. Allow the computer time to repair its WiFi connection and some other settings;
2. Right click on the Wireless Network Connection Icon, click on Status. Click on properties button, select TCP/IP (Internet Protocol), click on Properties button, verify that the option "Obtain IP address automatically is ticked, OK, OK.
3. In your browsers, verify/modify settings:
In Mozilla, click on Tools, Options, Advanced tab, Network tab, Settings button, tick "Auto-detect proxy settings for this connection, OK, OK;
In IE, Tools, Internet Options, Connections tab, LAN settings button, check "Automatically detect settings" (& pls make sure there is no check mark on the Proxy server), OK, Advance tab, check Use HTTP 1.1 through proxy connections.
In Opera, Tools, Preferences, Advanced tab, Network, Proxy server buttons, check "Enable HTTP 1.1 for proxy, OK, OK.
Pls post back how things turned out or should you need additional information. Hope that this be of some help/idea.
Good luck and kind regards.
Nov 17, 2007 | D-Link Air DWL-122 802.11b Wireless...
Computers & Internet Logo
83 people viewed this question
Top Network Associates Computers & Internet Experts
micky dee
kamal dev  jhalli
kamal dev jhalli
1860ph
Level 1 Expert
Are you a Network Associates Computer and Internet Expert? Answer questions, earn points and help others
