Question about HP LaserJet 1100 Printer
Printer is not Printing right. Printer has space on page that does not print.
    Sergeant:
  • 313 Answers
You have a problem in your pc or printer driver
Posted on May 07, 2010
I am trying to print a booklet 2 pages per sheet double sided. Printing is OK but spacing is no good for the binding when the pages are cut in two. What instructions should I give the printer to allow...
Hi
By spacing, I assume you mean the margins at the centre.
The default margin settings are not the same for the right and left hand side of the page, so the printing on the reverse side is offset from the printing on the first side.
The right margin is always wider to allow for punch holes in file paper.
It is not the printer settings you need to adjust, it is the page layout of your word processing software.
Adjust the margin settings manually. In MS Office 2007:
Page Layout > Margins > Mirrored Margins.
Hope this helps.
Aug 24, 2011 | Canon PIXMA MP610 InkJet Printer
My printer is printing slowly
Print speed can be affected by three important factors:
Available computer RAM
Available computer hard drive space
The HP All-in-One product paper sensor
Follow the steps below the ensure the computer is operating properly.
Step one: Verifying the amount of RAM
Verify the amount of RAM installed in the computer.
Determine the amount of memory currently in use by background programs or processes.
Programs/processes will run in the background even when no applications are running. Most of these programs/processes will be indicated by an icon in the lower right corner next to the time.
Less memory available for applications will result is slower processing time and consequently, printing speed.
To determine processes running in Windows 2000/XP , do the following:
Press Ctrl , Alt , and Delete simultaneously and then release.
From the Windows Security box, select Task Manager.
Click the Processes tab to view all running processes.
Click the Performance tab to view the total and available amount of memory.
To determine processes running in Windows 98 , do the following:
Open the Device Manager .
Click the Performance tab.
The available system resources will display as a percentage.
Turn off unnecessary background processes.
This will free up system resources and increase printing speed.
To turn off processes in Windows 98/ME/XP , do the following:
Click Start , Run , and type msconfig.
From the System Configuration Utility, click the Startup tab.
Determine what processes are unnecessary and remove the checkmark those items.
Step two: Verifying the amount of hard drive space
Follow the steps below to determine the amount of hard drive space on the main drive.
Open My Computer , right-click the C drive, and then click Properties .
This will display a chart along with the total hard drive space, used space, and available space.
Verify that there is at least 2-3 GB of hard drive space available.
The computer will require at least this amount to process printing data for simple text files, more for image files. The lower the amount of available hard drive space, will greater the time to process print data.
Step three: Ensuring the paper sensor is clean and not damaged
The all-in-one product paper sensor plays an important role in determining the print speed.
Printing a self-test or demo page will ensure that the paper sensor is in proper working condition. If the page completes in less than 40 seconds, the sensor is working correctly.
Even if the sensor is working correctly, the printer driver might need to have the paper sensor turned off. To turn off the sensor, follow the steps below:
Open the Printer folder, right-click the printer and click Printing Preferences or Properties.
From the Properties box, click thePaper/Quality or Features tab.
Under the Paper Type section, open the menu and select Plain Paper instead of Automatic.
This will disable the paper sensor and increase the print speed
Nov 10, 2009 | HP DeskJet F4280 All In One Printer InkJet
Valid page names message driving me nuts
when printing specific pages the valid range is in this format 1,3,5,7,9,11 etc or if printing even numbers 2,4,6,8 etc or if printing specific pages 1,5,17,21,23,24,32 etc
what makes it a valid range is the comma between the numbers, no spacing and no full stop at the end
to further add confusion
when printing all of the pages just click all pages and it will print one sided all of the pages so no numbering is required
however if you want to save paper and reduce the size of the document
click pages 1,3,5,7,9,11,13 through to ,57
print those pages then turn them all around and upside down reinsert in the printer
now select pages 2,4,6,8 through to ,58 and print
that will give you printed data on each side of the paper in the correct page number order
to get to know how to reinsert the paper test with a print page 1 then reinsert and print page 2 to make sure that you have turned the paper the right way round
Jun 28, 2017 | Samsung ML-2510 Laser Printer
Spaces in printed lines
then the problem is in cartridge replace them asap, no other way around it,
cheers
Sep 04, 2008 | Dell 922 All-In-One InkJet Printer
Programs Lock until Printing Finished
1. Click on START, CONTROL PANEL, PRINTERS AND FAXES (or PRINTERS AND OTHER HARDWARE).
2. Right click your printer, and select PROPERTIES. (If your printer is not listed, click on VIEW INSTALLED PRINTERS first).
3. Select the ADVANCED tab.
4. Select SPOOL DOCUMENTS BEFORE PRINTING.
5. Click on APPLY (if applicable), then OK.
6. Restart your computer.
7. Try printing now.
Aug 14, 2008 | Epson Stylus Photo R300 InkJet Printer
Slow printing
try to verify your RAM space or do the following:
  1. Verify the amount of RAM installed in the computer.
  2. Determine the amount of memory currently in use by background programs or processes.
    1. Press Ctrl , Alt , and Delete simultaneously and then release.
    2. From the Windows Security box, select Task Manager.
    3. Click the Processes tab to view all running processes.
    4. Click the Performance tab to view the total and available amount of memory.
    1. Open the Device Manager .
    2. Click the Performance tab.
  3. Turn off unnecessary background processes.
    1. Click Start , Run , and type msconfig .
    2. From the System Configuration Utility, click the Startup tab.
    3. Determine what processes are unnecessary and remove the checkmark those items.
Step two: Verifying the amount of hard drive space Follow the steps below to determine the amount of hard drive space on the main drive.
  1. Open My Computer , right-click the C drive, and then click Properties .
  2. Verify that there is at least 2-3 GB of hard drive space available.
Step three: Ensuring the paper sensor is clean and not damaged The all-in-one product paper sensor plays an important role in determining the print speed.
  1. Open the Printer folder, right-click the printer and click Printing Preferences or Properties .
  2. From the Properties box, click the Paper/Quality or Features tab.
  3. Under the Paper Type section, open the menu and select Plain Paper instead of Automatic.
    This will disable the paper sensor and increase the print speed.
May 15, 2008 | HP PSC 1350 All-In-One Thermal Printer
Character spacing when printing 2 pages on A4
Hope this gives you an idea. When printing from your pc, please select print properties to draft/best printing resolution. We'll see the difference between fast draft to best. Else you'll have to allign the printer settings from your pc, using the printers alignment tool.
Best regards,
Rosener
Feb 05, 2008 | HP PSC 1210 All-In-One InkJet Printer
Tally Voucher printing
see just go start setting and printer in printer right click go to server properties in that you will get option of creating form choose new form and give the sige of voucher so whenever you printing voucher select this paper size. bye
May 29, 2007 | Epson LX-300 Matrix Printer
Printer switching orientation
Make sure that manual feed is set to letter, on the printer front panel. This is a tabloid printer, so letter size sheets are fed long edge. The cassette will print okay because the media size info for the cassette is read by the printer from the cassette cams.
Dec 21, 2006 | Xante 4G Printer
HP LaserJet 1100 Printer Logo
46 people viewed this question
Seeker5211
Seeker5211
