Question about Sony Cyber-shot DSC-T20 Digital Camera
When I turn on the camera it will not take a picture, code E:6100
Camera is flashing E:61:00 on the screen when turned on. camera will not focus you can soombut unable to get perfect focus
  • 87 Answers
if you alsow get vibrationOn Sony T100 and similar,
its the vibration canceling unit, i had the same problem.
if you have good hads you can fix it.( on your oun risk)
1) disasamble the camera, you will see black plastic box inside, this is he lens unit.
2) on the botom you see 2 scrwes, they are holding the CCD remove them and the ccd unit will come from the lens assembly
3) the next is the stabilizer unit it is the problematic one. it is located on the left side of the lens asebly and is held by 2 screws.
you can test it by puling out the cable connected to it (the conector is just under the lens) and verifign that the problem is solved. ( you can leave it this way it will shoot fine just without the anti shake)
4) to fix it take it out ,remove the plastic cover, you see the lens on a plastic mount it should be glued to the magnet under it. the problem is that the glue fals apart.
remove one of the pins on wich it slides, and take the lens and the magnet out.
5) reglue the magnet and reasemble the camera.
6) power up and test, for me that solved the problem
if you need more help you can mail me at adisarit(et)yahoo(dot)com
this is spam mail so be prepared to wait a few days for reply.
this was tested and worked on 2 additional cammeras
Posted on May 10, 2010
When i held the flash button, the whole screen turned pink. now it wont focus on anyone and when i take a picture, the picture is still pink lines. how do i fix it?
maybe there is something wrong with your camera len,it can not focus,so the picture turns pink.
and we suggest you send it to the camera repair center immediatedly.
http://www.digitalcamera-parts.net/
www.skiliwah.cn/
e-mail/msn:e-8090team@hotmail.com
Sep 30, 2011 | Kodak EasyShare M530 Digital Camera
Pictures are out of focus on screen and when taken i cant seem to reajust the focus camera has been working fine untill i went to take a close up shot and now completely blurry .
If you are focusing On a subject make sure first that you are two feet away,
You can also try to turn On the blur reduction under setup menu. make sure also that your on auto mode or smart scene.
when taking picture indoor turn of the flash, you can do this by pressing the flash button On the camera
here are some basic troubleshooting
try to put your camera On a tripod or on the table to stabilize the camera then try to take a picture.
the technique of taking a picture Is first you need to half press first on the shutter button and you will noticed camera will adjust Now if the camera already adjusted pull press on the shutter button.
Blurry picture may caused if camera is not stabilized and may cause also if the flash will not fire correctly.
you may call tech support for further support toll free 1 800 235 6325
Nov 12, 2009 | Kodak EasyShare V550 Digital Camera
Hello. My daughter has had her samsung S73 for 3
The eye flashing is normal when the flash is trying to charge up , if the batteries are healthy the camera won`t take a picture until the flash is charged fully.Try turning the flash off and see if the camera fires, get some higher rated rechargeable batteries (2000mah) or above this may resolve your problem.
Aug 02, 2009 | Samsung Digimax S730 Digital Camera
Flash-Off Problem
Do you have the camera in the auto mode?
Did you check to make sure that the auto focus is not in the manual mode when the flash is turned off?
If the above does not comply, call the tech support for the camera.
There is also a possibity that there is a defect, or that the flash is part of the auto focus function.
Jerry G.
Sep 15, 2008 | Olympus ? Stylus 500 Digital Camera
Pictures are blur
Your pictures are blurry because the camera did not focus properly on the subject.
First, turn on the camera in any picture taking mode (or video mode), then look at the screen or viewfinder. There should be four white corners in the center of the camera display. This is your targeting area.
1. Aim the camera at your subject so this center area is directly on it.
2. Press the shutter button lightly, not all the way down. Wait for a second or two WITHOUT RELEASING YOUR FINGER. If the white corners turn green, keep the finger on the button and press it all the way.
(Once the screen flashes black, a picture is taken and you can release the finger).
If the targeting area turns red and blinks, then the camera has not focused. You can to try to focus again by following step 1 and 2. If a picture is taken when the targeting area is red, then the picture will be blurry.
If there is no targeting area, then you can still focus by aiming the camera at your subject. Now follow step 2. A green box will appear on the subject, then a sharp picture can be taken.
The red arrow that flashes means that the pictures or videos are being written onto the memory card.
Also, try to be steady when taking pictures, because slight hand movement can cause blurry images too.
Page 25 in the DMC-FZ7's english manual will also explain how to focus.
Jul 18, 2008 | Panasonic Lumix DMC-FZ7 Digital Camera
I can turn my camera on then the screen picture is all blurry and it won't do anything if you press the button as if to take the picture. The one thing i have noticed different is the letters [CAF] in the...
When the camera is set to C-AF (Continuous Auto Focus) mode the focus is continually aligned according to movement of subject or the camera even when shutter button is not pressed. The Continuous Auto Focus (C-AF) is disabled while the camera is zooming in and out. Once the camera stops zooming the CAF is initiated and the cameras focus is adjusted.
This is actually used for video.
Jun 06, 2008 | Samsung Cameras
Cybershot H7 focus problem
Things to check before you assume it is a mechanical issue-you can get vibration message if flash is disabled, be sure also that the macro mode is not enabled-this is very common on sony cameras to turn on by accident-flower button on camera will put in close up mode and you will get blur make sure no flower is present on lcd screen-if in macro press button on camera w/flower to turn off-also in menu you have continuous and monitor auto focus settings try changing one or the other and see what happens
Mar 18, 2008 | Sony Cyber-shot DSC-H7 Digital Camera
Camera error
The problem is the internal focus lens is either stuck, or knocked out of alignment. The lens will need to be serviced, or replaced with a new (not cost effective), or good used lens assembly.
Aug 07, 2007 | Sony Cyber-Shot DSC-W1 Digital Camera
E:61:10
Sony Technical Support team is the play to go
Jun 26, 2007 | Sony Cyber-Shot DSC-S50 Digital Camera
Can't take pictures
The focus element within your lens may not be moving normally. This can be due to contamination such as sand, impact, or failure of the motor itself. If the lens cannot resolve proper focus the auto focus system on the chip will not continue to take the picture. Another possible reason is that the button has simply failed. David Millier Advance Camera Repair
Feb 07, 2007 | Canon PowerShot A40 Digital Camera
Sony Cyber-shot  DSC-T20 Digital Camera Logo
181 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
