Question about Canon imageRUNNER 5570 Copier
Error code E 000025-0001
Toner supply motor dosen't rotate. I do troublshooting procedures in the service mode, take the toner bottle do the motor soution, but still the same problem. Please show me the best way or informations that i can resolve the problem please help me.
Thank you
Soster Jose
  • Anonymous Aug 25, 2008
    i change the hopper drive assembly motor with the new one, still the same problem. also i do the solution you gave me, but still the same. please show me the best way to clear that error code. oh also when i close the toner cover it show the error, but when i open it the error code disappear.
  • Anonymous Sep 22, 2008
    i change the new motor and also the toner bottle still the same problem. please show me the easy way to clear that problem.
    thanks
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 4 Answers
Hi, check the fuse 2A 125V beside IC TOSHIBA TA7270P on DC Controller board, if broken replace with new fuse, to check this fuse compare with others fuse with multimeter. If fuse no problem, there are 2 possibility broken : M9 (bottle toner motor) and M10 (toner stirring motor), the toner motor not rotate when first machine on, the machine quiet. You can see or hear whatever the motor rotate by open the cover hopper.
Posted on Mar 16, 2014
  • 4 Answers
 hello i m ramy,first  replace the toner bottle, second check the hopper motor connection,
 hopper motor unit gears.
or test if there 24 vdc .to the motor
Posted on Mar 28, 2008
SOURCE:
Hi, I have Ricoh mp2001L machine.and problem is blank page coming when i check toner bottle not rotating. whats solution??
If toner bottle not rotation then the toner bottle motor is faulty. You can check does the motor work in service mode. But also it might be and the gears on the PCU to be worn out. If you need instructions how to check in service mode does the toner bottle work, please write a comment.
Apr 16, 2018 | Ricoh Office Equipment & Supplies
Tip
Konica Minolta Copier service code C0070 C-0070
This service code C0070 is a universal code used by Konica Minolta to indicate a toner bottle rotation failure. These machines add toner by rotating the toner bottle that you install in the machine. Most of the time this code is caused by a toner cartridge that has been installed incorrectly or has become dislodged from it's holder. To clear the code open the front door or toner door and remove the toner cartridge/bottle from the machine. Close the toner door and if needed open then close the front door to reset the code. Let the machine run. This may take several minutes and will allow the machine to bring the toner bottle receptacle into it's home position. Once the machine stops running completely, then you can re-install the toner cartridge. If the code does not come back you are ready to go. If the code came back after removing the toner but before you re-installed it then you have either a dirty rotation sensor or a bad toner drive motor and will need service.
If the code comes back after the cartridge is re-installed then there is either a priblem with the cartridge or with the toner bottle drive.
Most of the time though the problem will be resolved by the outlined procedure.
on Jan 04, 2010 | Office Equipment & Supplies
000110-0001
Code Error name/description
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
Jul 15, 2013 | Canon Office Equipment & Supplies
ERROR E0024 FOR CANNON IR2270
check the toner hopper .toner is not being fed into the developer module at set rate.clean the hopper by blowing the toner and check the toner screw motor for rotation and do check when u install toner by service mode does the toner bottle rotate.
Aug 13, 2011 | Canon ImageRunner 2020i Copier
C0070 machine trouble
Good Luck and Thank You for using Fixya.
Jan 08, 2011 | Minolta EP4000/5000 CS/PRO Copier
It doesnt print the first page and its a minolta cspro 3000 and the error code is c0070
This service code C0070 is a universal code used by Konica Minolta to indicate a toner bottle rotation failure. These machines add toner by rotating the toner bottle that you install in the machine. Most of the time this code is caused by a toner cartridge that has been installed incorrectly or has become dislodged from it's holder. To clear the code open the front door or toner door and remove the toner cartridge/bottle from the machine. Close the toner door and turn the machine off then on to reset the code. Let the machine run. This may take several minutes and will allow the machine to bring the toner bottle receptacle into it's home position. Once the machine stops running completely, then you can re-install the toner cartridge. If the code does not come back you are ready to go. If the code came back after removing the toner but before you re-installed it then you have either a dirty rotation sensor or a bad toner drive motor and will need service.
Sep 29, 2010 | Minolta Office Equipment & Supplies
Minolta di250 error code c0070 this error code
This service code C0070 is a universal code used by Konica Minolta to indicate a toner bottle rotation failure. These machines add toner by rotating the toner bottle that you install in the machine. Most of the time this code is caused by a toner cartridge that has been installed incorrectly or has become dislodged from it's holder. To clear the code open the toner door and remove the toner cartridge/bottle from the machine. Close the toner door and turn the machine off then on to reset the code. Let the machine run. This may take several minutes and will allow the machine to bring the toner bottle receptacle into it's home position. Once the machine stops running completely, then you can re-install the toner cartridge. If the code does not come back you are ready to go. If the code came back after removing the toner but before you re-installed it then you have either a dirty rotation sensor or a bad toner drive motor and will need service.
Sep 28, 2010 | Minolta DiALTA Di250 All-In-One Laser...
We have a Minolta CS Pro that is displaying a trouble code of C00 70. We are a not-for-profit school and wanting to find out what is the problem.
This service code C0070 is a universal code used by Minolta to indicate a toner bottle rotation failure. These machines add toner by rotating the toner bottle that you install in the machine. Most of the time this code is caused by a toner cartridge that has been installed incorrectly or has become dislodged from it's holder. To clear the code open the front door or toner door and remove the toner cartridge/bottle from the machine. Close the toner door and if needed open then close the front door to reset the code. Let the machine run. This may take several minutes and will allow the machine to bring the toner bottle receptacle into it's home position. Once the machine stops running completely, then you can re-install the toner cartridge. If the code does not come back you are ready to go. If the code came back after removing the toner but before you re-installed it then you have either a dirty rotation sensor or a bad toner drive motor and will need service.
Sep 15, 2010 | Minolta Office Equipment & Supplies
MACHINE SHOWING THE 0070 CODE PROBLEM
If the code comes back after the cartridge is re-installed then there is either a problem with the cartridge or with the toner bottle drive.
Jun 30, 2010 | Minolta EP4000/5000 CS/PRO Copier
C0071 error code minolta cs pro 2080 copier
this code is for toner motor rotation abnormal timing. check for any loose toner inside the toner hopper rotational path, clean the sensor for toner motor. check the toner bottle inserted is for the same model
Nov 21, 2007 | Office Equipment & Supplies
Canon imageRUNNER 5570 Copier Logo
3,709 people viewed this question
Clive
Clive
old marine
old marine
Ekse
