Question about HP Photosmart 3310 Printer
My HP photosmart printer is not printing the red color, instead it prints an organge color. I replaced all cartriges and did not fix the problem.
rcsnet
  • 15 Answers
SOURCE: print head proplems on the hp photosmart 3310
ok, if you are using old cartriges, might want to try some rubbing alcohol on a tissue. This has worked on a number of cartriges in the past when i start getting missing pins. it lubricates the holes so in can flow again.
Take a q-tip and do the same if there's any kind of print head, but most print heads these days are built into the cartrige.
Posted on Mar 21, 2009
  • 130 Answers
SOURCE: hp c4480 prints blue instead of black
Check the print properties and verify the black ink cartridge still has ink in it.
Otherwise, you may have a bad ink cartridge. If the cartridge has not been used for a while, the ink gums up the nozzle. You can try cleaning the ink cartridge and slot with alcohol. However, new color and black cartridges may be the best solution.
Posted on May 02, 2009
heavyice
  • 374 Answers
SOURCE: It is printing the wrong colors. My reds are
Step one: Check the ink cartridges HP doesn't guarantee the quality or reliability of non-HP ink. If the ink cartridges have been refilled, try replacing them with genuine HP ink cartridges.If you have checked the ink cartridges and are still experiencing a problem, proceed to Step two. Step two: Print a test page
  1. Verify that there is plain white paper in the input tray.
  2. Press the OK and Help buttons simultaneously. A two-page Extended Self Test Diagnostic Page prints. Figure 1: Extended Self Test Diagnostic Pagec00728269.gif
  3. In the Print Quality Pattern section on the second page of the test page, look at the color blocks for any lines. Figure 2: Print Quality Patternc00728270.gif
  4. If the colors are still wrong in the Print Quality Pattern color blocks, print a document to determine if the issue has been resolved.
If you have completed all of the steps above and are still experiencing a problem, proceed to Step three. Step three: Check the printer settings
  1. In the software application you are trying to print from, click File and then clickPrint . The Print dialog box opens.
  2. Verify that your printer is selected and then click Preferences . The Printing Preferences dialog box opens.
  3. Click the Printing Shortcuts tab.
  4. The Printing Shortcuts tab lists most printing needs, but you might need to modify some of the options. Options on the Printing Shortcuts tab include:
    • General Everyday Printing
    • Photo Printing Borderless
    • Photo Printing with white borders
    • Two Sided (Duplex) Printing
    • Presentation Printing
    • Fast/Economical Printing
    • Postcard Printing
    • Hagaki Printing
    NOTE: These are general printing shortcuts with pre-selected settings.
  5. To change the settings from those available on the Printing Shortcuts tab, click the Features or Color tab. Options on the Features or Color tab include:
    • Print quality : If you are unhappy with the quality of your printouts, try increasing the print quality. To print more quickly, try decreasing the print quality.
    • Paper type : If one of the options matches your paper type exactly, choose it rather than Automatic.
    • Paper size : Make sure this matches your paper.
    • Print in Grayscale : Print a document in shades of gray.
    • Orientation : Specify how the document is positioned on the page.
    • Paper Source : Select the tray that you want to use for printing.
    • Two sided printing : Print on both sides of the paper.
    • Color Management : Specify the color space that the printer will use to interpret image data.
    • Pages per Sheet : Specify the number of pages in the document that will be printed on each sheet.
If you have completed all of the steps above and are still experiencing a problem, proceed to Step four.
Posted on Nov 07, 2009
  • 241 Answers
SOURCE: hp printer power light keeps blinking -- wont print any document
Turn both your printer and computer off then after a few minutes turn back on. This should cancel the print job.
Posted on May 28, 2010
aimrans78
  • 52 Answers
SOURCE: My HP Photosmart D7160 is printing color pictures
try to reinstall the drivers
everything is going well with the hardware
only software has some bugs
Posted on Jun 18, 2010
HOW DO I FIX THE INK CARTRIGES WHEN REPLACED ?
Could be improper installation, or cheap cartriges, or could be failed print head which I had and replaced with good results.
May 21, 2014 | HP Photosmart C6380 All-In-One InkJet...
Since installing new ink cartrige every time I turn on the printer it prints an alignment page
Hi:
This problem is usually caused by one of the colors in the installed cartrige not printing out on the alignment page. You need to have red, blue and yellow working to get a good alignment. Try removing the cartridge, and wiping the print head with a wet paper towel to try to start the ink flowing. You should see three bands of color ink oozing out the bottom. If not, the cartridge is bad and needs replaced again!
Apr 19, 2010 | HP Photosmart C3150 Printer
Print head proplems on the hp photosmart 3310
Mar 21, 2009 | HP Photosmart 3310 Printer
My HP photosmart A520 Printers ink wont align
I had the same problem with mine when I bought it. The print head is in the ink cartrige not the printer. If it prints all red, blue or yello one of them is stuck, this happened on the trial cartrige that came with it. I put a fresh 110 in it and it aligned and I have printed a TON of pix with no problems.
Pat - Houston
Mar 05, 2009 | HP PhotoSmart C4180 All-in-One Color...
Printer will only print color pictures in black and cyan
Hi, this printer color cartridge contains all colors in one. So if you can print with one color means that the whole cartrige is ok but one or more colors ended. And you should had a low ink message on screen if it was genuine HP. Best thing to do is to go and buy a new one cartridge and see how it will go. This cartridge is green color.
Sep 05, 2017 | HP Photosmart 2575 All-In-One Printer,...
HP Photosmart C5180 In Cartriges Empty
uninstall the software and reload it it will mostly fix your problem.
if still the problem presists .
feel free for further assistance.
thanks
Nov 14, 2008 | HP Photosmart C6180 All-In-One InkJet...
Print Cartridge in Right Stall not Supported.
print cartridge colour ink is not workink fix with hp print
May 19, 2008 | HP PhotoSmart C4180 All-in-One Color...
HP Photosmart 3310 Printer Logo
241 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
