Please advice on sound card to run cubase ?
Can you help as i am having problems on latency ?
Download ASIO4ALL
Posted on Apr 19, 2008
For some reason I cannot select my UA-25 as the ASIO Device in 'Audio System Setup' in VST5. VST 5 always seems to select 'ASIO Multimedia Driver' as the ASIO Device, which has a latency of 750ms. The...
I am using a laptop for my music creation and I am thinking about using an External Sound Card connected with a USB cable or getting an Sound Card. My integrated sound card has a little bit too much latency. Will I have just as much or more latency with the External Sound Card because it is connected with the USB cable or would I be better off with the Sound Card?
Thanks for vinu plz plz plz plz plz plz plz plz help me sir.
Mar 06, 2011 | Edirol UA-25 External Sound System
When i import an instrumental into cubase it will playback but will be very distorted, if i change the device settings in cubase and dont use the io2 it will playback fine so im assuming its something to...
In order for an imported file to sound correctly in Cubase, the bit rate and KHz must be the same or you will create garbage when going through your interface. For instance if you have ripped something from a CD it will be in 16 bit 44.1 KHz format. If you were to pull this into Cubase at 24 bit with 48 KHz selected as your projects rate you would encounter this problem. (I'm guessing this is what is causing your problem.)
Please open up cubase and click import, a window should pop up asking if you want to convert formats, please select the check boxes for conversion for the bit rate and KHz (depending on what version of Cubase it will be something similar to this.) An alternate solution is to go to the project preferences and select the rates that match the imported material before importing and no conversion will be necessary. (Although, I recommend always working in 24 bit and 48 KHz if you're machine can handle it.) A final possibility is that you have the latency set really low and the converters can't handle the speed at which the information is being processed. If the above should for some reason not work, check in your preferences box in Cubase if possible or through software that came with your interface and increase the latency. This can cause an audible delay between the time you hit a note and hear it back so make sure to decrease it before recording and increase it while mixing since you won't being recording new material and can use that processing power that would have gone to making sure you hear your live audio quickly can be steered to use plug-ins and get crackling free playback. Remember, with latency, even if get crackling from a low latency you will not hear that crackling upon mixdown! However, I'm quite sure your problem is with conversion rates, but if never hurts to know or get a reminder on things like latency. Cubase is a high quality product and I hope you enjoy using it. Thank you and I hope this helps.
Feb 25, 2011 | Alesis iO | 2 Sound Card
Good morning I have Cubase SX version 1.01. lately when I record vocals to a track. Im noticing that the Vocals are not in sync with the music. one is playing slower than the other track.. the slower is...
I don't 100% understand why Cubase does this. I'm assuming it's a memory (RAM) problem. If you record loud and clear anough you can just drag the tracks to where they're meant to be afterwards because you can see where they go relative to the other tracks
Aug 20, 2010 | Steinberg Cubase SX3
Recording on cubase le4 using my tascam us122 mk2
You're probably not recording through your tascam interface. Go to control panel -> sound, and then select the us122 as your default sound device. Close cubase and open it again. Then go to devices -> device setup, and then under your asio drivers, select asio us122. That should solve it
Oct 25, 2009 | Tascam US-144 Sound Card
Audio Latency. Need faster computer
Windows has a lot of programs running in the background which eat up the system resources and that you do not need for Cubase.
Do a CTR+ALT+DEL and end task on everything except Explorer & Systray, start Cubase and see if that helps.
Jun 16, 2009 | Computers & Internet
Edirol not able to record on Cubase essentials
This interface works fine with other hosts but with cubase is more tricky. But you can fix it.
You need to disable the onboard sound card, also use the UA25 Asio drivers, go to programs/Steinberg cubase/ ASIO multimedia setup and you should see the UA25 outports are active and that the sync ref "YES" also that the UA25 Input ports are active. the next bit is a bit of fun select the Advanced options and select Detect buffer size, when thats finished select Check Buffers and Sync, press the start button and the test will run,if everything is ok you should have zero "Sync lost" and zero "Buffer lost"
Depending on how lower you want to get your latency , you may have to tweek the UA25 driver settings and re-run the setup above.
Jan 25, 2009 | Edirol UA-25 External Sound System
Tascam US-144 problems with ableton live and in general
Im using Vista on a Sony Vaio FW11E with Core 2 Duo Processor. 3Gig ram. Its not working properly with me either. Its a loan of a mates. Ableton and Windows Media Player just keep stopping for a second every few seconds! Very annoying!
Sep 28, 2008 | Tascam US-144 Sound Card
Cubase REcording/Playback Problems
check first the sample rate maybe its to high like instead of 44k. its in 48 96 or something like that so the buffering isnt catching with the recoding . alogn with your lattency configuration must devices are ok in 512 latency.
and also be shure not to be recording directly to tyour external hard drive
in case of plugin overload issue it would not stop recording suddenly it would slow down first with some crackles and then stop or must shure freeze.
so impretty shure its somethin else.
hope it works
good luck
May 10, 2008 | Steinberg Cubase SX3
TASCAM US 144
Are these problems that have cropped upover time, or is this a new installation?
accordianman
Apr 03, 2008 | Tascam US-144 Sound Card
Nuendo/Cubase sound cuts off
I chased this same problem with a friend's laptop using Cubase. Additionally, he had several recurring pops at high end, in regular intervals, with 23 seconds of trouble free gaps in between incidents. Eliminated hardware problems, so I contacted some Cubase user groups and they indicated their older software was not compliant with the newest hardware... in other words, they suggested he buy a newer version.... He did (gasp, sticker shock... the horror) and the problem disappeared. Might be all that is wrong for yours, if your desktop has newer hardware and older version of Cubase.
Jan 31, 2008 | Intel Steinberg Nuendo AudioLink PCI 96...
Computers & Internet Logo
308 people viewed this question
David Payne
David Payne
