Question about Linksys Wireless-G WRT54G Router
I have tested my internet connection with my ISP and the connection is fine but the signal from my wireless router seems to be the problem. This just started out of the blue (no recent changes). Pages load very slow if at all. My computer tells my that the connection is good but profermance says otherwise.
    Brigadier General:
  • 10,406 Answers
Disconnect the router, and use an Ethernet cable to connect your computer's network-port directly to the cable-modem (or DSL-modem), and try the "performance" of Internet activity.
Posted on May 07, 2010
Is there a time limit setting on the router
I would check ALL cables, connections, reseat all connections. Have your ISP verify the signal from the outside. Have a ISP tech come out to analyze the connections and signal.
Jan 04, 2013 | Edimax 3G6200n Wireless Router
My D-link router (dir 615) saying is connected but have no internet access
Wired or wireless? Check all cables, have you tried to connect with a Ethernet cable to the ISP modem, if it connects, try connecting via the cable to the D-link. Work you way through the devices one by one.If it connects via the cable, it's the computer's wireless adapter. Will other computers connect? Or contact your ISP to verify the signal, have a tech come out to analyze the signal. It may be outside. It's happened before, to me.
Dec 26, 2012 | D-Link DIR-615 Wireless Router
Sometimes cannot connect, sometimes losing internet connection.
Are you using a wireless router/access point or is this a wire connection?
If it is wireless, you might just need to relocate where your wireless router is located, many times building construction materials can create RFI and cause the signal to be weak and drop connections more often.
The other problem might be the fault of your ISP. If they are having equipment problems, they might actually have a router that is failing. If you are unsure of the connection to your network, simply contact your ISP and ask that they perform a signal check or to PING your router from their side and measure the signal strength and return rate on the signal.
The last possibility is that your network adapter in your computer might be having problems. There is one check that you can perform on your network adapter to verify that it is working properly. With out being connected to the Internet, open a DOS window (Command.exe). At the prompt enter the following command:
PING 127.0.0.1
The computer will perform an internal loopback test. If it comes back OK, then most likely your network adapter is working fine.
If everything checks out, you might just have a bad router and will need to get it replaced. Hope this helps you out.
Cheers,
Keith
Sep 19, 2009 | D-Link 4-Port Ethernet Broadband Router...
Linksys wireless connected to router, signal fine, no web pages
First thing i would try is power cycling your equipment. Unplug the router and the Modem-
Plug the modem in first and once all the lights come on- plug in your router- then restart your computer.
Apr 09, 2009 | Linksys Wireless-G WRT54G Router
Computer connects to router but not to the internet
This seems to me at first look to be a problem with your ISP not accepting the credentials for your connection. I presume you tried restarting everything after resetting the router, but resetting it has erased your ISP login and password.
Apr 07, 2009 | Dell TrueMobile 1184 Wireless Broadband...
Cannot recieve a internet signal from router wired and wireless
Are you getting DHCP from ISP? If not ask them if you can static the address in your router. then do ping tests.
Jan 11, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin Wireless G wont connect to cable modem
If you switched ISP then you have tor reconfigure your router according to the settings of your new ISP.
Aug 24, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin router
it is possible that the settings for your ISP is already gone or the router is not recognizing the settings.
Oh by the way who'se your ISP, is it cable or dsl internet?
For cable internet the router's internet/WAN connection type must be set to "Dynamic" for DSL internet there are some that will require you to setup your userID and password given to you by your ISP, to do this just change the connection type to PPPoE and fill out the required fileds(usually it just the userID and password from your ISP).
To access your router setup page, just open internet explorer on your computer(given that its connected wireless or wired to the router) and type http://192.168.2.1 . Type admin for the password and leave the password blank.
Jul 15, 2008 | Belkin (F5D5231-4) Router
Wireless router not working
hello!
-- who is your internet service provider
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
if this still didnot work, upgrade the firmware of your router
note:
configuring the router settings will depends who is your provider. if your isp is dsl you need to configure your ISP username and password on the router. if your router is a cable no need to change any settings on the router. it should automatically work
if you are still having trouble configuring your device, call supportrix and use supportcall as your promo code for 1 free technical support.
Jun 10, 2008 | Linksys Wireless-G WRT54G Router
Wireless network
Have you looked at these posted solutions? http://www.fixya.com/support/t133938-wireless_connection
Feb 14, 2007 | NetGear WGT624 Wireless Router
Linksys Wireless-G WRT54G Router Logo
82 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
