Question about Daewoo Washing Machines
Rinse and spin stops unbalance problem
My machine (Fisher & Paykel 8 Kg Top Load Aquasmart)has been working fine (eg 2yr+) but now suddenly in the rinse/spin cycle the machine shakes very hard (ie the machine actually moves); then stops; moving the cloths to the middle and press continure works for a minute or two then shake and stops; sometimes after few go it works; I have tried different wash type/size or spin speed
three weeks wait list for the technician; any idea? Thanks
  • 4 more comments
  • e4amir May 08, 2010
    Hi Thanks for the quick reply; I have opened the machine and there are four elastic straps on each corner; one of them was out of place; It had a little tear; I put it back and doing a wash now and I'll let you know how it goes.
    I have noticed the straps are very loose; is that normal or they need to be tighter and be replaced?
    Thanks
    Amir
    Thanks for the reply.
    The tub support rods are still in place; I just noticed one of them had a very small tear; I am going to the shop tomorrow and compare them to a new machine's and order a new sets.
  • e4amir May 10, 2010
    I have just checked the new machine's rods in store and they are also not very tight; the new rods costs $150; and the local supplier has not them in stock. would it be possible to be another problem? should I check something else as well before ordering the part and see no change? yesterday I tried the machine with all rods in place and it was shaking so hard during the rinse that I have to stop the machine; it sounded that the tub is hitting the side of the machine etc.
    Thanks
    I went to the store and checked the tub support rods for a new machine; the rods/straps were not tight either; the new set costs $160 and the local supplier has to order it? is there anything could be wrong and I should check before ordering the rod and see no change? yesterday I tried the machine and it was shaking so hard during the rinse that I have to stop it; it amost sounded that the tub was hitting the side panels etc
    Thanks.
  • e4amir May 14, 2010
    Hi, I just received the part and I thought it come with the elastic straps; with it is the full metal rod with plastic corner on the top? don't I have to change the rubber band as well?
    I'll try to change the part tomorrow and let you know. Thanks
  • e4amir Jun 02, 2010
    Solution #3 was spot on, thanks.
  • Daewoo Master
  • 3,740 Answers
Hi and Wlecome to FixYa. I am Kelly
This is usually a balance ring problem with the inner tub. The ring is filled with water. If it gets a pin hole in it then the spin becomes eliptical and the machine will walk slide, glide across the floor in the spin with or without clothes. There is little you can do if the balance ring has failed other than replace it. If it does the serious unbalance routine with no cloted in the tub during the spin the problem is most likely a damaged balance ring.
Thanks for using FixYa.
Kelly
Posted on May 14, 2010
    Top Expert:
  • Daewoo Master
  • 77,202 Answers
There are spin cycle stabilizers that keep the washer tub from going way out of balance, it is very likely that one or more of these has failed and this is why the machine shakes, you will need to remove the washer tub and inspect the parts to determine what parts has failed. Taking the machine apart to this level of tear-down for inspection is only for the person who has advanced mechanical skills, it requires a good set of tools and allot of patience
Posted on May 07, 2010
  • yadayada
    yadayada May 14, 2010
    hAVE U REPAIRED THIS YET?
    President:
  • 1,554 Answers
The tub support rods need to be replaced when a sign of wear and tear is obvious because there is an imminent danger of incurring further damage when it fails totally during the machine operation, specially during a high speed spin. The rods are sold as a set of four and it is part number 421127P.
Posted on May 08, 2010
  • 1 more comment
  • Jahn27
    Jahn27 May 08, 2010
    Please let is know then. Just take note of the tub support rods part number.
  • Jahn27
    Jahn27 May 10, 2010
    Make sure first that the washer is installed on a sturdy floor and that it is level and all feet are on the floor. There's no other reason the washer goes unbalanced except the tub support rods if the washer is level and installed on a sturdy floor.
  • Jahn27
    Jahn27 Jun 02, 2010
    We are glad to hear that. Please consider accepting and rating the solution which give you the best idea.
What does error code E7:04 mean? Quicksmart 7.5 kg frontloader
To stop the sound, touch any button and perform the following steps:
  1. Turn your machine off at the power point.
  2. Wait one minute and turn it back on.
  3. Check your machine is correctly leveled .
  4. Remove your wash load.
  5. Perform a 'Rinse' cycle.
  6. If the fault re-occurs repeat steps 1 and 2.
https://removeandreplace.com/2015/12/07/fisher-paykel-aquasmart-top-load-washing-machine-error-codes/
Dec 15, 2017 | Washing Machines
Out of balance message being received constantly even after redistributing the load - knocking
Your AquaSmart machine requires 4 new suspension damper rods & 4 top bands, these are a common problem for AquaSmart machines.
Dec 14, 2014 | Fisher and Paykel Aquasmart wl80t65c
Fisher & Paykel Aquasmart washing machine makes loud banging noise then stops during rinse/spin cycles
Your Aquasmart machine requires 4 new suspension damper rods & 4 top bands, these are a common problem for AquaSmart machines.
Feb 02, 2013 | Fisher and Paykel Washing Machines
Continues to go out of balance
The stainless steel bowl has lost its ballast water & goes out of balance,Replace faulty bowl.
Oct 03, 2012 | Fisher Paykel Fisher & Paykel AquaSmart...
My fisher & paykel 7.5 kg excellence smart drive doesn't spin
Check the out of balance switch (under the larger Grey board)
for corrosion on the terminals and replace if faulty.
Jul 03, 2012 | Fisher and Paykel Washing Machines
My fisher & paykel washer will not move to rinse cycle
Fisher & Paykel GW712 AU 93200-A STOPS @ THE RINSE CYCLE & THE SPIN CYCLE?
Oct 12, 2011 | Fisher and Paykel IWL12 Top Load Washer
Washing Machines Logo
258 people viewed this question
Top Daewoo Washing Machines Experts
Owen Barnes
Are you a Daewoo Washing Machine Expert? Answer questions, earn points and help others
