Question about Toshiba Satellite M55-S141 Notebook
My screen is VERY dark...I can shine a light onto it and I can see it...how do I repair it?
  • 415 Answers
On your laptop there is an Fn (function) key and another button showing the image of sun. Keep Fn pressed and then click the "sun" button to increase the brightness of your screen.
Regards,
nicolasiac
Posted on May 07, 2010
5 Suggested Answers
  • 68 Answers
SOURCE: Loss of light on screen Dell Inspiron E1705
Hmm, this could be a problem with the backlight inverter or something as simple as power settings.
In power settings from control panel there should be an option to alter the brightness lever of the screen when on battery.
Have a look in there and set it to default to see if it makes any difference.
Let me know if you need any more help.
Regards
Nick
Posted on Oct 26, 2008
Dipu007
  • 2110 Answers
SOURCE: I have hp pavilion dv6226us
Your LCD screen needs to be changed
Posted on Dec 08, 2008
myrlex
  • 674 Answers
SOURCE: I have a Dell Latitude 5085 the screen is dark, if I shine a light on it I can see the program without the light I barely see an image.
CHECK THE INVERTER... THEN THE CABLE OF VGA..AND CONNECTION
Posted on May 31, 2009
parrotheadpc
  • 2600 Answers
SOURCE: Screen is dark but icons are barley visible.
What you have is an inverter failure most likely. The inverter takes the AC adapter voltage and converts it to high voltage AC for the backlight bulb. Backlight bulbs rarely fail but the inverters do. Ebay has inverters for around 15-20 bucks. The inverter sits under the lcd panel behind the screen bezel. In most cases, removing the bezel is all you need to do to change the inverter out. Below is a link to the service manual for that model.
When you click on the link go to page 4-61, this is the start of the lcd disassembly. I thing just 4 screws need to be removed and then take your finger nails and pry off the bezel in a small area and work your way around the screen until the bezel comes loose. When replacing the bezel always start at the bottom between the hinges and work your way up and around.
http://tim.id.au/laptops/toshiba/satellite%20m50.pdf
Posted on Jan 18, 2010
Red standby light is on TV won't power up. Tried reset button, didnt work. (Wd-y65
sounds like you are having problems with your control board, psu, or most likely the power inverter. shine a flashlight onto the screen and see if you can see a dark image.
Jul 02, 2016 | Video Game Consoles & Games
I have a dell inspiron laptop, and a dell monitor hooked up to it, i turn on the monitor and it is very bright for about half a second then it becomes very dark, so dark that it looks like it turned off,...
Does the fault appear on the laptop screen aswell? It appears by your description that the fault is only on the external monitor. If the screen comes on for a moment and then goes blank as described, then this appears to be an invertor fault. It is very common among laptop and tft screens and requires the invertor inside the panel to be replaced / repaired. Simply plug the screen into another computer to confirm.
May 29, 2011 | Rosewill R900J 19" Flat Panel LCD Monitor
My samsung 940b it has a clear bright screen ( as normal ) just for 2 seconds then the screen turns dark but you can see very very dim Window logo.Turn off the power ( does not matter for how long ) when...
Shine a flash light onto the monitor, if you can see icons/desktopon the screen then you know you need a new monitor!
You should be covered under warranty!
Mar 02, 2011 | Samsung SyncMaster 940B Monitor
Display will not light up. It is completely black but if you shine a light at it you can barely see it
If you can see characters when shining a torch on the dark screen then the screen is OK it is the lamp or ballast that has failed. I would find an authorised repairer and get it repaired.
Hope that helps.
Feb 25, 2011 | Fujitsu Tablets & eReaders
Projector light does not shine. (Power is on, bulb
I will assume from your description that the projector is powered on and you can look in the rear vents and see the lamp illuminated, yet the light does not shine on the screen.
The Ektapro 9020 and most of the Ektagraphic line of projectors are equipped with a "dark shutter". What that does is keep the screen dark unless a slide drops into the gate. At that time the sensing circuits trigger and open the shutter, allowing light through the slide & onto the screen.
Dec 16, 2009 | Kodak Ektapro 9020 Slide Projector
Mitsubishi WD-62527. Dark picture.
That unit is a two mirror set. Meaning the light engine lens shines down onto a small mirror and that is reflected onto a large mirror and then onto the screen. Gravity being what it is dust and other contaminants cover the lower mirror. Moving the set would only aggrevate dust settling on it. To fix the problem the screen must be removed and the mirror cleaned. You won't believe the difference. It will be like watching a new tv.
May 28, 2009 | Mitsubishi VS-50605 50" Rear Projection...
Laptop screen goes dark while loadin windows
If you can see everything when you shine a light on it, it's most likely a 'backlight' going bad. These are somewhat easily repaired, but can be expensive. Good luck!
Apr 18, 2009 | Microsoft Windows Vista Ultimate Edition
My compaq presario m2000 screen is very dark
You will need to replace the LCD screen. The cheapest way to go is ebay. Here is one.
Thanks and please take a moment to rate as fixya.
Jul 06, 2008 | Compaq Presario R3000 Notebook
My toshiba screen
Shine a torch light onto the screen. If you can see a faint outline of the images, it could indicate a back light failure. Unfortunately, you cannot fix this by yourself. You will need to take it for servicing.
Jun 11, 2008 | Toshiba Satelite A10 Notebook
Toshiba Satellite M55-S141 Notebook Logo
60 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
