Question about Fujitsu Siemens (MAN3184MCB) Hard Drive
Computer recognises drive but does not show drive letter
    Brigadier General:
  • 10,406 Answers
Click Start
Right-mouse click on My Computer
Choose Manage
Click to get to Disk Management (local)
Use Disk Management to "create" and "format' a partition onto the disk-drive, and to assign a drive-letter.
Posted on May 07, 2010
Testimonial: "Many thanks for your help. 160 GiG drive now installed and working perfectly."
How to delete from playlist/mic
Hi
Generally speaking, when you connect an mP3 player to a computer via USB then the storage capability usually shows up in file explorer (My Computer) as an extra drive of some description (often "removable drive"). Its a good idea to have My computer open and showing your drives when you plug the USB cable in, because then you will see the USB drive added to the list and recognise a new drive letter.
Having got a drive letter for your mP3 player you can then scroll through the folders and files on the mP3 player just as if it were a drive in the computer, and hence copy, move and delete files as on the computer. Particularly with an mP3 player with relatively limited capacity, this means that you can change the tracks on it regularly from a larger library on the computer.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 31, 2014 | Audio Players & Recorders
I formatted my Verbartim 500gb external hard drive using DOS.When I plug it in my computer it is being recognised but it is not being displayed in my computer.I have tried installing the drivers for the...
Right click My Computer and select Manage
Click on disk management
Drives without drive letters will not show up in My Computer Right click the drive and select Change Drive Letter and PathGive the drive a letter and you are all set
May 12, 2011 | Computers & Internet
No drive letter is assigned to a USB mass storage devise. it is recognised in devises and says it is working properly. A thumb drive works OK and is assesable. This as a 20GB external HD in a Centre X 2...
Well, you can manually assign the drive letter for the Drive. To do this, follow the instructions below:
Right-Click "My Computer" > "Manage" > on the left pane "Disk Management" > on the right pane check out which one is the drive that's not available with it's drive name, after it's located, right-click on the drive and select "Change Drive Letter and Paths" or "Assign Drive Letter", give any letter you want to assign and "Ok". Close the window and open My Computer, you'll be able to see the drive with the drive letter you just assigned. If it doesn't show up, restart your computer while the external hard drive is still connected to the system's usb port.
It's also important to try it on different usb ports or on another system to make sure there's not internal problem or connector/cable problem with it.
Good luck.
Thanks for using FixYa.
Aug 10, 2010 | EliteGroup ECS P4VXASD2 VIA P4X266A...
My cruzer micro 2.00 gb pen drive is not recognised by my computer which is vist operating system
Plug it in and see if it shows up in Disk Management.
If it is there, right click and change the drive letter, try a letter futher down the alphabet.. like u
Sometimes usb devices suffer from drive letter conflict
Aug 02, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I have about 39gb of family pics and music saved on my freecom 250gb external hard drive and I have had to reboot my system with a backup file using ACER e-recovery management. since then my external hard...
In the control panel, go to administrative tools, open computer management. On the left side, there will be a "Disk Management" section, use that to assign a drive letter to your hard drive.
Sep 30, 2009 | Acer Aspire™ T180 PC Desktop
Hard drive not recognised
It may not appear like your other drives eg. C: d: etc
it may appear as a removable drive lower down in the list.
Or you may have to add a drive letter
To add a drive letter in XP
Go to control panel, administrative tools, computer management.
Now select disk management, your drive should show in here
right click on it and click change drive letter and paths
now click add at the bottom of this box and just click ok
You should now be able to see it fine
Aug 24, 2009 | Iomega 1TB Desktop USB 2.0 Hard Drive
Usb port didn't recognise My Passport Essential 160
Front panels of computers (earlier motherboards) dont fully support USB devices, better to connect it at the back of you PC. Also find in BIOS if USB2.0 SUPPORT is enabled. If any of your USB is damages (pins have same connection) other next to it won't work.
Jul 29, 2009 | Western Digital Passport® 160 GB USB 2.0...
My maxtor 500gb driver won't work. The power light shows that it is on, though my computer nor any other also don't recognise it and the drive letter doesn't show up
Make sure that the SATA wires are fastened securely. Download the current driver for your particular hard disk drive and operating system and install. Write back if neither one fixes problem.
Nov 25, 2008 | Computers & Internet
DSC-F505 does not show as a disk drive
dmangadu
It sounds like the drive letter that the camera wants is already assigned to another device. The link below will help you change the drive letter.
http://www.fixya.com/support/r4183994-change_drive_letter_in_windows_xp
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Feb 15, 2008 | Sony Cyber-Shot DSC-F505 Digital Camera
Fujitsu Siemens (MAN3184MCB) Hard Drive Logo
451 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Lee Durbin
Lee Durbin
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
