Question about Garden
Carburator cloged with old gas will not start how do i resolve this problem
  • 198 Answers
Take the carb apart and clean it thoroughly in solvent
Posted on May 10, 2010
6mo. old wont start checked gas in float bowl spark plug dry, and sparking, comp. test 50psi????throttle open when testing
you need to rebuild carburator. its very easy pay attention to what you are doing .blow out all holes in carburator with carb cleaner then air reasimble.
Mar 16, 2015 | Garden
1997 chevy pick up will start when we add gasoline directly in to carburator but after it runs out of gas it dies
this is a fuel injected motor not a carburatored motor.if it only runs when you pour fuel in the throttle body then you have a fuel supply problem that needs to be checked out,you may have a plugged fuel filter and a bad fuel pump.
Sep 01, 2011 | 1997 Chevrolet K1500
How do i drain old gas from the motorcycle
you will need to remove ur seat in order to get to the bolt or clip down that holds the rear of the petrol tank to frame.make sure the fuel tap is off & remove the fuel line going from tank to carburator then remove tank & empty the old gas out.there should also be a drain bung/bolt on bottom of ur carburator bowl,undo this let all gas empty out,then re-tighten & then reverse steps to put tank back on.Fill with fresh gas try start,check for any leaks & should be good to go!
Jan 04, 2011 | 2007 Yamaha XT 125 X
Carburator is gummed up I can remove the carburator but after that im lost I removed the screw from the bottom of the cup drained the old gas shot some carb cleaner in there opened the gas line put the...
leaving fuel in a bowl will cause corrosion in the jets and jam the needle and seat operation
take the carby off the machine and go to a shop that can overhaul the unit
Jun 29, 2017 | Karcher 2500 PSI Pressure Washer
Will not start at this time. when i put gas in the carb. it start and run for a few seconds and then it goes dead.
It must be some problem with the fuel line. check and see that there are no kinks in the line, then check the fuel filter if it looks dirty it might be cloging the flow of fuel. Then I would recomend taking the carburator off and cleaning it out, i would try to blow air throgh the jet where the gas tube connects too. this should give fuel to the engine and it should run.
Apr 19, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Toro lawn mower wont start
pour alittle gas in carburator & then try starting see what happen if it starts & then dies then you have a carburator problem
Nov 09, 2009 | Toro Lawn Mower With Toro Power Tools
TB20CS gas trimmer, primmer bubble won't pull in gas
The carburator has a sereis of one way check valves that get cloged very easily.
If you remove the carburator and clean it out with a simple cleaning solution you should be able to clean it up.Do not use compressed air.
Aug 03, 2009 | Troy Bilt 17 Inch 29 Cc Gas Powered...
Gas peculating in carburator and running into motor.
there is exhaust that runs from head to head under carburetor . there should be a damper that opens when cold and closes when hot . when it stays open after motor reaches operating temperature gas in bowl boils and gas is a vapor instead of a mist and causes motor to run lean .
Apr 17, 2009 | 1988 Ford Thunderbird
86 CJ7 will run but will not idle.
Clean the idle control valve. located just inside the hole where you remove the aircleaner duct work. use brake cleaner or carburator cleaner.run at about 1200 rpms and spry directly into the valve.
Dec 19, 2008 | 1986 Jeep CJ7
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
