Question about Sony KP-46WT510 46" Rear Projection HDTV
Does not turn on. Yes, I checked the plugs and outlets. Is it a fuse in the TV?
  • zapdbf May 11, 2010
    does the power light blink, if so how many times does it blink before it repeats a pattern?
  • 160 Answers
It is the power supply that needs to be replaced if there are no lights at all on the tv. You will have to speak with a service tech to have it repaired.
Posted on May 07, 2010
Tv wont turn on
Can you plug a lamp and it lights in that outlet? YES? Any fuse or reset on the TV. Probably NOT. Unplug for 5 minutes and plug it back it for a possible reset the CPU. ALL NO? Call the man or break out your electronic service tools.
Sep 11, 2013 | Samsung Televison & Video
Spectroniq tv doesn't turn on, lights off.
The fuse is inside--power cord should go almost direct to it--beyond that if fuse good is power supply for the set.
Nov 06, 2012 | Televison & Video
Have lg tv model 26ld350 and will not power on. Have checked outlet and power cord and they are ok. Does this tv have a fuse? Appreciate any assistance.
Yes,the power supply board have a fuse near the edge of the board.That the board,where the power a/c cord plug into it.
Mar 25, 2011 | LG 26LD350 26 in. TV
32" xenius tv: No power after switching on and off by the wall, can you help?
Check Power On Outlet Wall Unit Plug Lamp into Wall Outlet See if you have Power.. If Yes... Check on the back of you tv set look for Fuse Panel Check Fuse if it burt out.. If No . Issue with Main Board Pannel Inside Fail To Innitiate To Pre Start Logic Relay Security Swich To Avoid serious damage inside TV...Please Refer To Certified TV Repair... Good Luck
Oct 07, 2010 | Televison & Video
No power
If your television has no power, try the following:
1. Check the power cord for breaks, tears, or exposed wires .
2. Check to be sure that the power cable is fully inserted in the outlet and that the outlet is working.
3. Go to your fuse box or circuit breaker box and check the fuse or circuit breaker of the circuit your TV is plugged into. Replace the fuse or reset the breaker if necessary.
4. Replace the batteries in the remote control, and then try turning on the TV using the remote.
5. Unplug the TV, wait five minutes, plug the TV back in, and then try turning on the TV.
If the recommendations above do not resolve your problem, most likely the power supply in your TV has failed and your television needs service.
Thank you !!
Jun 04, 2010 | Hitachi 55PMA550 55 in. HD-Ready Plasma...
Ilo tv will not turn on. I was able to unplug the tv, plug it back in and then it would turn on. Now, nothing works.
is there power came from your outlet if yes then check your power filter fuse if OK then check your audio board because it act as output and crossover power that is depend only if you have red light on,also check your power supply board for blown capacitors. also get another opinion good luck.
Apr 28, 2010 | iLO 2600 Television
Rca f36650yx01 will not turn on
I feel foolish asking this but have you plugged it in? If you have it plugged in are you trying to turn it on with the remote? Have you tried to turn it on by pressing the on switch on the tv? Does the outlet work?
There could be any number of reasons for this. If the outlet has power (you can check this with any electrical device you have, plug it in and turn it on). So if the outlet has power AND the remote has fresh batteries AND the tv is plugged in to the outlet but still will not turn on even after pressing the switch on the tv...then you may have a blown fuse on the power input line into the tv. Take the tv to your local repair shop and ask them to look, if the fuse is blown they'll replace it and voila, your tv is fixed!
Please do not try to do this yourself, there is over 10,000 volts available at the flyback transformer even with the tv not plugged in.
Sep 07, 2009 | RCA F36650 36" TV
19' flat screen tv
iDoes your tv turn on ? if yes check to see if ther is a fuse in your tv.
If your tv dosen't turn on check the ac cord and your ac outlet.
If you are not familar with taking off the back of the tv call
a repairman.
Lou Margo
Allied Electronics
Dec 07, 2007 | Televison & Video
Sony KP-46WT510 46" Rear Projection HDTV Logo
41 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
