Question about Frigidaire FGB24S5A Gas Single Oven
We need to replace the ignitor on a fgf326asf, we
We need to replace the ignitor on a fgf326asf oven, we have the part, but cant figure out how to get to it
The stove Frigidaire Mod. FGF326ASF give an F3 error don't have manual instructions, could you tell me please what that means
Posted on Feb 21, 2011
Why only one side of oven burner will stay lighted fgf326asf
normally you have three types of baking methods.
1. Top only
2. Bottom only
3. Both. -use the setting to this configuration then you will be good to go.
OR
Only one part of your oven is working. THIS can NOT be due to a circuit issue. The other heating wire might be probably damaged. Get it replaced. Will cost you very less about USD5-10.
May 11, 2014 | Bakers Pride Y-600 Gas Single Oven
Tip
Thanks, this was very helpful and got me to open up my oven on my own and saves...
If you have had the unfortunate experience of having the igniter on your gas oven go out at the worst possible time. Then you probably are also dreading the installation of the new igniter. Do not fear the replacement really is no that hard.
The first thing that you need to do is remove the racks from your oven.
Then look around at the back of your oven for the screws that hold the bottom pan down.
Remove those screws and remove the pan. Some need to slide back and then come up others will just pull up.
Remove the heat shield that is over the burner.
Remove the bottom drawer of your oven.
Now you should be able to see the igniter that sits on an angle by the burner tubes with a couple of wires coming out of it.
Removing the screws that hold the igniter is probably the most difficult part with some ovens. Sometimes it is easier to remove the whole bracket that holds the igniter and then remove and replace the igniter out of the oven.
The wires for the igniter will go to a Molex plug. Follow the wires and undo the plug. On many units it will be below the oven in the drawer opening at the top back. You will need to lay flat on the floor and reach back in to do this.
Once you have the old igniter out then you can carefully install the new one. Hopefully when you get it out of the box it will be in one piece yet. I had to get an igniter for an oven I worked on shipped three times before I got one that was not broken.
Any dropping or banging against anything will crack that igniter. BE CAREFUL!!
Check to make sure that you can feed the Molex plug and wires down through to the bottom before fastening the igniter.
Once the igniter is secured and the plug is connected, you can then replace the other parts in the reverse order that they came out.
This all sounds difficult, but really is not that hard. Even a first timer will have it done in less then a half an hour.
on Jul 07, 2010 | Ovens
Oven igniter works but oven doesnt lite. Strong smell of gas also. Stovetop works fine. Whats wrong!!!?
replace the ignitor,even though trhe ignitor glows orange its getting weak and cant pas enough current to open the gas valve to supply enough gas to fire the venturi tube,so it supplies gas but wont ignite this is where your odor is coming from
Jan 06, 2013 | Ovens
Gas oven will not lite but thing in bottom glows do not smell gas
By "thing in bottom" Iam assuming your talking about the igniter. If you are and it is only glowing then it probably needs to be replaced. If you cant smell the gas either thats a worring sign in of itself. I would first replace the igniter and then go from there though. Let me know how it goes!!
Aug 09, 2011 | Amana Ovens
STOVE WORKS BUT OVEN WILL NOT HEAT UP - GAS OVEN
There are 2 high likelihoods as to what your problem may be. When you turn your oven on, does the ignitor begin to glow within 15 to 30 seconds? If it doesn't, there is no power going to the ignitor and the control mechanism is going to need to be replaced. If you have a manual dial thermostat control, you can order this on-line at parstdirect.com. If you control is electronic, you will be required to have an appliance technician come out in order to send the old controller in to be rebuilt.
If your ignitor is glowing when you turn on your oven, but it has a very dull orange glow, you have a bad ignitor and it needs to be replaced. This is the most common problem with older gas ovens. The ignitors just burn out after time and do not draw the amperage needed to open the safety valve.
Replacing the ignitor is a fairly easy procedure. Replacing a dial thermostat control can be a little rough due to rerouting the thermocoupler back through the oven body. Unfortunately, the electronic style oven controls can only be sent in for rebuilding and the company that you use will need to be able to handle "Retforrepr Rebuilds".
May 01, 2011 | Magic Chef 9122 Gas Single Oven
My oven will ignite but will not get hot enough to cook anything properly I figure it is the flow control or the thermostat. Is this right and about how much would the parts cost and how hard is the labor...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Apr 03, 2011 | Ovens
Ignitor lights up bright, but no ignition,no flame and I don't hear the gas turn on like I normally do. Top burners work fine.
Hello, welcome to fixya ! Based on your description I suspect you have a faulty bake ignitor. This may surprise you, or it may not. I think at first it surprises people when the hot surface ignitor glows but the oven won't lite. Since the ignitor "glows" one figures it would appear to be working, that would be wrong. These ignitor's serve 2 functions, 1) need to maintain a set value to open/activate the gas valve, typically around 3.5amps... & 2) ignite the fuel once said gas valve is open. A poor/faulty ignitor may glow & and even ignite the burner intermittently for moments at a time ( thus giving off some heat but never the set amount or not lite at all ) but yet not reach the needed value to open the gas valve/safety valve consistently nor adequately, hence the need to replace the ignitor. Try this and I'm certain you'll be up & running and as they say " cookin' with gas" ! I'd suggest you should refer to your specific model when ordering the part locally or on-line. The most common hot surface ignitor part is #12400035 and it will work in your Whirlpool too. Try places like repairclinic.com, searspartsdirect.com, APwagner.com etc. Thank's for visiting "fixya" for your stove inquiries. Please take a moment while here to rate the solution provided or let me know if you require further assistance and good luck. macmarkus :)
May 23, 2010 | Whirlpool AKZ159IX Oven
IGNITOR COMES ON OVEN DOES NOT
Hello there:
Normally if your ignitor is coming on in the specified time usually around 45 to 75 seconds
this would indicate that the thermostat is defective and needs to be replaced.
However if the ignitor its taking longer that this this would indicate that the ignitor is getting weak and should be replaced.
I would recommend replacing the ignitor along with the thermostate to ensure that you are using new parts you will get better performance with new parts ok
Hope this is very helpful for you
Best regards Michael
Mar 08, 2010 | Frigidaire Ovens
Our stove was not heating up, but the electric pilot was glowing red, we replaced the gas valve, and it still will not heat up....what do you suggest?
Hi, The problem may not be so obvious. It sounds very crazy but the problem can still be with the ignitor even though it is glowing and heating up. The gas valve will not turn on unless the ignitor pulls a aet number of amps. of power. When theignotor ages it can stop drawing the same amount of power and the gas valve won't turn on because it thinks that the ignitor is not owrking correctly. I went through this with a couple of different ovens, the first one really took me awhile to figure out. Change the ignitor and your oven will work again!
Nov 16, 2009 | Ovens
Oven will not light
One of the Ignitor/orifice assy.,electrode is bad expecially the one your wife have to light.The circuitry is ok,but change that bad ignitor/orifice assy electrode.
Part number is Item # 833121: check it out @ www.repairclinic.com
Jul 04, 2008 | Frigidaire FGB24S5A Gas Single Oven
Frigidaire FGB24S5A Gas Single Oven Logo
161 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
