Question about Haier HP42BB 42 in. Plasma TV
Need a main or ssb module for haier model hp42bb
  • Haier Master
  • 8,457 Answers
Tries websites like Shopjimmy.com,Ebay.com for searches.They have huge inventory of refurbish boards for LCD,Plasma tvs.
Posted on May 07, 2010
I have no sound in my haier plasma tv
Something to do is does set have sound on any input (like a dvd player connected to a rear input?
Also in the setup or audio menu are the speakers switched to OFF?
Oct 25, 2012 | Haier HP42BB 42 in. Plasma TV
No picture appear only sound
Replace the Main board/SSB signal .
Encompass Parts Distribution 1-800-638-3328
PTS rebuilt boards 1-800-844-7871
Jan 12, 2011 | Haier HL22R 22 in. LCD TV
How to adjust frequency on transmit??? Galaxy
hELLO THERE
hERE IS SOME MODIFICATIONS FOR THIS RADIO
Galaxy Mods DX 2527 - VR 1....AM/FM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 7....SSB Carrier Balance, VR 8....RF Meter, VR11...Driver Bias, VR12...SSB ALC, VR13...Hi Power, VR14...AMC, VR15...AM Low Power, VR16...SSB Low Power, VC 1....10.240, VC 2....10.240. DX 2517- VR 1....AM/FM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 5....FM Deviation, VR 6....SSB Carrier Balance, VR 7....TX Offset, VR 8....CW Beep Level, VR 9....RF Meter, VR10...Final Bias, VR11...Final Bias, VR12...Driver Bias, VR13...SSB ALC, VR14...AM/FM High Power, VR15...AM Modulation Meter, VR16...AM Modulation, VR17...SSB Power, VR18...AM/FM Low Power, VR601..13.8 Volt Power Supply. DX 22B- VR 1....AM/FM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 7....SSB Carrier Balance, VR 8....RF Meter, VR11...Driver Bias, VR12...SSB ALC, VR13...High Power, VR14...AMC, VR15...AM Low Power, VR16...SSB Low Power, VR21...TX Offset, VC 1....10.240, VC 2....10.240. DX 11B- VR 1....AM/FM S-Meter, VR 2....SSB/CW S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 5.....FM Deviation, VR 7....SSB Carrier Balance, VR 8....RF Meter, VR10...Final Bias, VR11...Driver Bias, VR12...SSB ALC, VR13...AM/FM High Power, VR14...AM Modulation, VR16...CW Tone Level, VR20...Final Bias, VR21...TX Offset, VR601..13.8 Volt Power Supply, VR803..AM/FM Low Power. DX 77HML, DX 88HL, and DX 99V- VR 1....AM/FM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 5.....FM Deviation, VR 7....SSB Carrier Balance, VR 8....RF Meter, VR10...Final Bias, VR11...Driver Bias, VR12...SSB ALC, VR13...AM/FM High Power, VR14...AM Modulation, VR16...AM/FM Low Power, VR20...Final Bias, VR21...TX Offset.
Unmarked VR in R189..AM/FM Medium Power for DX 77HML only. DX 33HML, DX 44V, DX 55V, DX 66V, and DX 73V- VR 1....AM/FM S-Meter, VR 4....AM/FM Squelch Range, VR 5.....FM Deviation, VR 8....RF Meter, VR12...Low Power AM Modulation, VR13...AM/FM High Power, VR14...High Power AM Modulation, VR16...AM/FM Low Power.
Unmarked VR in R188..AM/FM Medium Power (DX 33HML only)
Unmarked VR in C139..Med Power AM modulation (DX 33HML only) DX 949,DX 959- VR 1....AM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM Squelch Range, VR 6.....SSB Carrier Balance, VR 7....TX Offset, VR 9....RF Meter, VR10...Final Bias, VR12...Driver Bias, VR13...SSB ALC, VR14...AM High Power, VR15...AM Modulation Meter, VR16...AM Modulation, VR17...SSB Power, VR18...AM Low Power, VC1....10.240. DX 2517 and DX 2527-
Symptom:Buzzing or motorboating sound in either the transmit or receive.
Problem: TR602 is oscillating
Cure: Replace C602 with a .01uF cap {Cap is located in the power supply board}.
RG 66,99,DX2517 Replace Q54 2SB754 60watt 7A with a higher power 2SB817 100 Watt 12A. Derating of this component will cool operation, provide better voltage stability,decrease wobble, allow voltage increase to 14.5 volts comfortably. (replace 10 volt caps in this section of the radio to a minimum of 16 volts before increasing supply voltage to this level)and provide faster swing rise time, Replace Q37 2SA473 to a 2SA1012-0 or ECG153 this will improve the clarity and volume of the modulation and it will also run a lot cooler.
Nov 12, 2009 | Galaxy Radios DX-949 40-Channels Base CB...
Watched dvd now cannot get back to cable tried input
If all the other functions work on the tv remote, then turn the tv off, then un-plug it for 10 minutes. Plug it back in and turn it on. If the input button still doesn't work then go into the tv menu and try and change it there. Let me know how it turns out?
Jun 04, 2009 | Haier HP42BB 42 in. Plasma TV
No modulation in AAM only mode. Needing a schematic.
if the transmitter produces power output with modulation on SSB but NOT ON AM then the AM Pass Regulator is defective, more times than not.
May 24, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
Nothing works
i had exactly the same problem but not anymore. i called the haier co. and they told me to order a new remote control so i did. i got my new remote and i turned my tv on and pushed the tv/use and it worked thank god. so maybe you could try it. remote control only 20.00 good luck!
Mar 14, 2009 | Haier HP42BB 42 in. Plasma TV
My 42 inch Haier Plasma has a no signal on screen it's only a year old can someone help I bought a new remote and that did not help ?
i had the same problem and i bought the new remote control and it did work at first i thought it was going to do the same thing but then i pushed the tv/use button and it worked perfectly.
Mar 13, 2009 | Haier HP42BB 42 in. Plasma TV
My plasma screen reads no signal and not available
I am sorry. I have searched and searched and e-mailed and phoned about 20 plus people about this question. No one can come up with one straight answer. Haier themselves don't even know. I would suggest taking it in because it doesn't sound like a self-fix problem.
This is the most help I can give you.
http://www.nytechtvrepair.com/haier_tv_repair.html
Jan 16, 2009 | Insignia LCDTV26 26 in. Television
Haier HP42BB 42 in. Plasma TV Logo
117 people viewed this question
Top Haier Televison & Video Experts
Jaime Hernandez
CoppellTVRepair.com
Are you a Haier Televison and Video Expert? Answer questions, earn points and help others
