Question about Microsoft Windows XP Professional for PC
In my system c drive is out of memory with out doing format can i increase my c drive"s memoty
    Brigadier General:
  • 10,406 Answers
The only way is to purchase another internal disk-drive, connect it, and move some of your documents from your old disk-drive to the new disk-drive.
Delete all files/folders from the 'C:\WINDOWS\TEMP' (not from 'C:\WINDOWS') folder.
Run the "Disk Cleanup" accessory, to remove some unnecessary files.
Empty the Recycle Bin.
Posted on May 07, 2010
When increase the memory card 2gb to 4gb using drive increaser but while formating it while showing only 2gb why?
Older systems, only can format 2 Gbyte in FAT-16. In 10 years, we grew from 512 Mbyte cards to 512 Gbyte for cards. The systems sold in this time, did not change. After SD, came SDHC and since 4 years we have SDXC (above 32 Gbyte)
When you are lucky, you can use a card with more capacity, but your device will not be capable to use more that the 2 Gbyte it was build for.
Feb 03, 2015 | Electronics - Others
Tip
FORMAT ERROR IN MP3 PLAYER
if You are experiencing "Format Error" messages when adding or accessing music/videos on your player. this could be as a result of a corrupt memory region or not having the required or supposed memory size of the player(actual memory)
what you do you should format:
formating Ensures that what you have bought, is of the actual memory capacity.
. 1. You will not lose any firmware/theme related files.
2. You will not accidentally kill your player whilst doing so (unless you unplug or disconnect your player during the format process).
follow the step below to guide you
STEP 1
Back Up All Your Data Before Proceeding! This Guide Will Clear Everything In Your Player's Memory Chip!
Install MP3 Utilities, any version will do. It usually comes on the CD with the player, or you can download version 3.68
Here, or version 4.03 Here, or version 4.05 Here. Any one of these will do. The Disk Tool Utility is the same.
STEP 2
Start up MP3 Utilities Disk Tool.
You will be shown a screen like this:
Ensure that you select LOW Format Type.
Next, go to the Partition and Encrypt tab as shown below.
Now, slide the Partition Slider all the way to the Right.
You will notice the "Setting encrypted disk capacity" increases, it is normal.IMPORTANT.IF YOUR MP4 PLAYER IS LIKE 2GB OR MORE MAKE SURE THE PARTITION AND ENCRYPT TAB WHEN YOU INCREASE IT SAYS YOUR PLAYERS MEMORY.FOR EXAMPLE.IF YOU HAVE A 4GB MP4 PLAYER AND YOU ARE SLIDING THE PARTITION AND ENCRYPT TAB MAKE SURE THAT WHEN THE NUMBER INCREASES IT SAYS SOMETHING LIKE 4000MB.IF IT DOESN'T DO THIS DO NOT REPEAT DO NOT DO THIS ENTIRE PROCESS.
*NOTE* Ensure That You Do Not Click The "Set Username And Password", Leave It UNTICKED.
Next, click on Start to begin the format and partition process. You will be presented with a dialog box like below, click on Yes to proceed.
It will take a few moments for the process to complete. You will notice that your player would disconnect from the computer, and then re-connect back again.
You will be presented with the "Complete setting disk partition!" dialog box like below.
STEP 3
Go to My Computer and check that now you will two memory drives for your player. You might need to click Refresh or press F5.
One of which would be small (about 17MB), and the other would be the remaining memory capacity.
Do not worry if it does not appear, just continue to with the guide.
then go back to the Partition and Encrypt tab.
Slide the Partition slider to the Left, and click on Start.
repeat the process and the "Complete setting disk partition!" dialog box would appear.
Check in My Computer that now you will only have One single memory drive for your player. Right click on it and select Properties, this is your actual real memory capacity.
Now check your player's Memory Info for the correct memory display.
To access this, go to your player's SYS TOOL >> MEMORY INFO.
Your player should display the actual memory size that you have just checked.
Check if the percentage is at 0%. If it is, you can skip Step 4 below, and continue to Step 5.
STEP 4
If your player's Memory Info does not show 0%, you will need to complete the below procedure.
Right click on your player's memory drive, and select Format.
Now a new windows format screen would appear.
Select FAT in the File System dropdown menu.
If after completing Step 3, your player really does have 4GB of memory, then you need to select FAT32 instead. As FAT only supports upto 2GB.
Click on Start to begin on the format process.
A warning will appear for the format, click on OK to continue.
Wait for a few moments while Windows formats your player.
When completed, check your player's Memory Info again, it should display 0% now.
STEP 5
Once completed, start copying music/video files to your player and enjoy enjoy your player
on Dec 19, 2009 | Audio Players & Recorders
My computer says i need more memoty i have 1gb should i buy moore or get a new computer. what would you recommend for about 500 thanks
hello,
  • are you sure it refers to memory module increase ?
  • what computer model do you have ?
  • what OS are you using ?
  • if your computer is P4 , buyinmg a new computer depends on what you need it for ?
let me know i will help you
Nov 22, 2010 | Computers & Internet
I have a TDK 4 gb pendrive .... i formated my pendrive... ma flash lock is missing and ma storage has been reduced to 2gb.... i want to increase ma storage how do i do that..???
FAT32 file system supports only up to 2GB of space, and more likely you have formated the drive as FAT32. When you plug the flash drive in the USB, right click on drive letter associated with the flash drive, select Format and on the next screen under File System select NTFS.
Nov 14, 2010 | TDK (CD-RW74HSFXS5) Storage Media
I want to format my phone memory.im using N79.
just delete all items frm memoty it will delete it
Nov 15, 2009 | Nokia N70 Cellular Phone
How do i combime two hard drives to increase memory ?
RAM (Random Access Memory) are memory chips that the computer uses to run programming on the computer. This can be upgraded to the limit the computer will support, a good reference for capability of your system and a good source for purchase at www.crucial.com
The Hard Disk Drive, is like a computer filing cabinet where you install programs and store data on your system.
I assume, you are talking about combining 2 hard drives to create more disk space on your system. This is done by setting up a RAID (Redundant Array of Inexpensive Drives) To do this you will need a computer that supports RAID or install a RAID controller and configure 2 or more drives to create an array.
http://reviews.cnet.com/4520-11319_7-6386531-1.html?tag=rb_mtx;wp_body
Oct 18, 2009 | Computers & Internet
I delete things but available space doesn't increase
1.
Update Your Windows Operating System.
2.
Check your computer.
with antivirus and antispyware program.
3.
HP USB Disk/Drive Format Utility is a Windows based software
used to format drives to FAT, FAT32 and NTFS partition types.
3.a) Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW_2.2.3_MASTER.exe
3.b) Format
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
Oct 01, 2009 | Memorex 32573060 Rotodrive 3pk - 1gb Media
Memoty full mesage
this happens quite abit with Samsung devices. Try to make sure you can move your pictures to your computer. Then, reformat your card.
  1. Insert a memory card into the microSD slot, located on the bottom left side of the handset
  2. From the standby screen, press the left soft key for Menu
  3. Select Fun & Apps (6)
  4. Select Files (1)
  5. Select Memory Card
  6. Press the left soft key for Options
  7. Select Memory Card Info (5)
  8. Press the left soft key for Format
  9. Press the left soft key to confirm Formatting the Memory Card
You can also reset the MMS option on your Samsung with this star/pound code:
Enter *2767*667#
E2P MMS Reset Is Displayed When successful
Feb 02, 2009 | Samsung U900 Soul Cellular Phone
Various memory stick in my pocession
check the manual of the mother board of your PC if it is accept that kind of memory if so then try it. because some board cannot accept that kind of memoty
Jan 07, 2009 | Microsoft Windows XP Home Edition
Microsoft Windows XP Professional for PC Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
