Question about Kenmore Dishwashers
The power cord in my install kit for the Kenmore 1344 dishwasher, isnt color coded. The power cord is 3 leads of course but the manual says nothing about which lead to connect to the color coded wires coming from the DW. halp?
  • 8,197 Answers
It does not matter what lead goes to the white or the black. You just need to make sure that you have the ground in the right place. If it is a flat cord then the center wire is the ground and if it really matters the lead on the right of the ground is the hot/black.
Posted on May 07, 2010
Kenmore 66517514202 dishwasher has no power dead no lights nothing
Does the wiring come up through the door at the bottom to the control panel? Check for a broken wire
May 21, 2012 | Kenmore Dishwashers
We were recently given a kenmore dryer, without a power cord. How do I attach the 3 wire power cord that I bought to relace it?
Attach the power cord as follows:
1. Remove the cover on the terminal block on the back of the dryer.
2. Match the corresponding wire colors as follows:
a. RED - HOT (120VAC)
b. BLACK - HOT (120VAC)
c. WHITE - Neutral (0 VAC) - should have a ground strap attached, tying it equipment ground.
3. Make sure you use the power cord strain relief clamp when installing the power cord to prevent chaffing of the insulation and wire strain which can lead to broken wires.
NOTE: If the wires are not color coded, the outer two wires (left and right) are the HOT leads. The center conductor is Neutral.
For clarification purposes, the following link explains dryer power cord configurations/installation in detail:
http://www.fixya.com/support/r3575913-installing_a_220_vac_appliance_cord
If you have any questions, please post back and let me know. I hope you find this information helpful.
Mar 17, 2010 | Dryers
Kenmore dryer 3prong cord installation diagram
if its a" flat cord" what-ever color jacketed 3 wire cord, the 2 outside wires are your 2 hot power wires they go to L1 and L2 on your dryer,the center is the N neutral wire and goes to the N terminal,usually the L1 and L2 are a gauge larger than the neutral: HINT: the center is normally neutral on both the cord and machines terminal board in the back of the dryer,there usually is a diagram on the dryer on how to install the input power at the place you hook up power
Feb 07, 2010 | Kenmore 62602 Electric Dryer
Plug does not go into outlet. Three blade plug with one "J" shaped blade. The outlet has three straight hole to acommodate three straight blades.
Replace the power cord to accomodate the outlet you have. You can purchase them at any hardware store for about $20. This is the easier option than trying to replace the outlet. To replace the cord follow these steps:
1. Remove the access cover on the terminal block on the back of the dryer. This is where the existing power cord is installed.
2. Remove the existing power cord from the terminal block.
3. Remove the power cord restraining clamp (if equipped). This secures the power cord at the entry point on the back of the dryer and prevents it from stressing the terminals and prevents chaffing of the outer insulation on the power cord. NOTE: Its a good idea to have this installed for safety reasons.
4. Remove the old power cord and install the new one following this color scheme at the terminal block:
RED (Hot) - 120VAC
BLACK (Hot) - 120VAC
WHITE (Neutral) - 0 VAC - Should be connected to the terminal block and grounded to the equipment cabinet via a grounding strap.
NOTE: If the power cord or wires at the terminal block are not color coded, the outer two wires (LEFT and RIGHT) are the two hot leads. The center conductor is Neutral.
If you have any questions about this repair, please post back and let me know. I hope this helps you.
Dec 22, 2009 | Dishwashers
Do you have to install plug on tappan dishwasher? or is it hidden somewhere? Installing new dishwasher and cannot locate plug
Most dishwashers do not come with a power cord installed. The reason is because some homeowners choose to hardwire the applaince rather than putting a power cord on it and plugging it in. If you plan to use a receptacle, then you need to purchase a three prong power cord. You can find them at any hardware store or appliance parts retailer. The junction box to install it is located behind the lower toe panel directly below the door on nearly all dishwashers. With the toe panel removed, you should see a small silver box. Remove any access screws and open it to find the wires to install the power cord. The color code for installation is as follows:
Black - HOT lead (120 VAC)
White - Neutral (0 VAC)
Green (or Bare Copper) - Ground
Match the wires to the corresponding colors and attach the ground wire to the ground lug on the appliance. If you have any questions, please post back and let me know. I hope this helps you.
NOTE: If you are using a receptacle for the dishwasher, it is recommended that it be a dedicated outlet. That is, to prevent overloading, nothing else should be on the same circuit.
Oct 01, 2009 | Dishwashers
I have a Kenmore Diswasher model. 587.15103801 - My question is - can I wire a 3 prong power cord to it? If so, what do I need to purchase? Thanks
The dishwasher SHOULD have a three prong cord, or be hardwired using using a 3 conductor electrical wire capable of handing 15 to 20 amps (12 or 10 gauge wire). If you desire to use a cord with a plug on the end, you can purchase a power tool replacment cord rated at 15 amps or higher from the hardware store (I have found power tool replacement cords to be very durable). Make sure you purchase one that is long enough the accomodate pulling the dishwasher out from under the counter, if required. The power cord is installed in a junction box behind the lower toe panel that's located directly below the door. The wire color coding is as follows:
BLACK - HOT (120 VAC)
WHITE - NEUTRAL (0 VAC)
GREEN - GROUND
Match the color wires with the wires inside the dishwasher junction box and twist together using wire lugs. Attach the ground wire to the appropriate ground lug.
If you have questions, please let me know. I hope this helps you.
Aug 27, 2009 | Dishwashers
Electricity plug
Here is a little video to show exactly what to do. If you have an outlet to plug your dishwasher into just add a power cord to the connecting wires. Otherwise do as it shows in the video and hook the dishwasher up to a power cable coming from the electrical panel.
May 04, 2009 | Kenmore 1621 - Multiple Color Dishwasher
Kenmore dishwasher power cord.
The green is the ground wire. Attach it to the screw inside the junction box.
Feb 20, 2009 | Kenmore 24 in. 16032 Built-in Dishwasher
What type of powercord and outlet does this dryer require? Electrician installed a 220 outlet.
ELECTRICAL REQUIREMENTS
ELECTRIC Dryer
CIRCUIT - Individual 30 amp. branch circuit fused with 30
amp. time delay fuses or circuit breakers.
Use separately fused circuits for washers and dryers, and DO
NOT operate a washer and a dryer on the same circuit.
POWER SUPPLY - 3 wire or 4-wire, 240 volt, single phase, 60
Hz, Alternating Current.
POWER SUPPLY CORD KIT - The dryer MUST employ a 3-
conductor power supply cord NEMA 10-30 type SRDT rated at
240 volt AC minimum, 30 amp., with 3 open end spade lug
connectors with upturned ends or closed loop connectors and
marked for use with clothes dryers.
WARNING – Risk of Shock. Appliance grounded to neutral
conductor through a link. Grounding through the neutral link is
prohibited for (1) New branch circuit installations (2) mobile
homes; (3) recreational vehicles; and (4) areas where local codes
do not permit grounding through the neutral, (1) disconnect the
link from the neutral, (2) use grounding terminal or lead to
ground appliance in accordance with local codes and (3) connect
neutral terminal or lead to branch circuit neutral in usual manner
(if the appliance is to be connected by means of a cord kit, use
4-conductor cord for this purpose). USE COPPER CONDUCTOR
ONLY. The dryer MUST employ a 4-conductor power supply
cord NEMA 14-30 type SRDT or ST (as required) rated at 240
volt AC minimum, 30 amp., with 4 open end spade lug
The complete installation manual is at ftp://ftp.electrolux-na.com/ProdInfo_PDF/Webster/134917700es.pdf
Jan 28, 2009 | Frigidaire FEQ1442ES Electric Dryer
Kenmore Elite Dishwasher Problem
The dishwasher should have a thermal fuse mounted to the control board behind the operator console4.gif. It is a small silver colored device4.gif attached to a white plactic bracket. In some model dishwashers the wrong gage wiring was used causing the wires to heat up and trip the thermal fuse. There was no apparent risk of fire or anything like that, but the thermal fuses didn't tolerate the heat differential too well. A fix for the problem was to purchase a thermal fuse replacement kit (found at most appliance repair stores) that had thicker wires. The part number for the thermal fuse kit is 959376 and the price is $16.85. You can find it at repairclinic.com. Order on line and have the part shipped directly to you. Now...to access the control board perform the following:
1. Turn off the main breaker to the dishwasher. This is important. Even though the dishwasher is not running, the control board still has live voltages present.
2. Open dishwasher door and remove the top screws that hold the console in place. You shouldn't have to remove the lower screws unless you plan on removing the entire door panel.
3. The control panel should pull off from the front enough to where you can access the control board. There is a thermal fuse mounted on the board with two wire leads going to it. The fuse is silver in color and mounted to a plastic bracket which is mounted to the control board.
4. Cut the wires on the old fuse and splice the new fuse kit to it. Leave plenty of wire to accommodate. There will be instructions included with your replacement kit. Ensure you follow the direction thoroughly and tighten the wire lug screws securely.
NOTE: Do not attempt to reuse the existing wires by simply unplugging the old fuse and replacing it with the new one (been there). The fuse will eventually blow again. Follow the instructions provided and you can't go wrong.
If you have any further quesitons, or if you run into trouble during your repairs, let me know. Good luck to you.
PS If you do not wish to order on line, take the part number I provided you to any major appliance repair shop4.gif and they SHOULD have the part available. This is a known problem and a common fail item.
Dec 15, 2007 | Kenmore 24 in. 17482 / 17484 / 17489...
Dishwashers Logo
133 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
