SOURCE: scanner inserts vertical line on some documents
Clean the glass with IsoPropyl Alcohol. Dont use any other solvent. A speck of dust stuck to the glass can give a continuous line in the output
S. Mohan
SOURCE: Ballasts for Creoscitex Eversmart Jazz+ Scanner
You might be able to get parts from a company called CPS based in Cheltenham there telephone number is 01242285103 they mentioned that they had a couple of scanners for sale
SOURCE: I have vertical lines in my photos when i scan them
If the lines are in the same location for all scanned outputs, it is clearly dust on the scanner glass. Clean it thoroughly.
S. Mohan, India
SOURCE: Eversmart Scanner - Base Glass Recognition Process Failed
I have the same problem any fixes?
SOURCE: creo eversmart supreme Mrk 1 solid red status light
There's either a problem with the power supply or the control board, most likely the control board. Have you tried running the diagnostics yet?
-Ryan
omnicow at gmail dot com
This article provides the self-diagnostic
steps necessary to evaluate top-to-bottom streaks that appear when
copying or scanning.
Important! This is seldom a scanner hardware failure.
The main reason for this anomaly is debris or marks on the scanner glass that is used for Auto document feeder (ADF) page scans.
Printed or Scanned Page Illustration
Who should consider this article?
Any user of an MFP or All-In-One printer experiencing the following symptoms:
Think of it this way:
Suggested Diagnosis and Fix
Step
Action
Locate the portion of the glass designated for ADF scans.
HINT: The glass location differs by model. This area is often separate from the scanner flatbed. Please reference User's Guide for more information if you are having a difficult time locating this designated area.
Perform a visual inspection for any of the following recurring culprits:
Other Possibilities
If...
Then...
Vertical lines appear only when printing...
Consider other printer-related topics such as toner cartridge, charge roll, photoconductor, transfer roll, or fuser. Contact Lexmark Technical Support.
Vertical lines appear when you lay the page on the flatbed...
Vertical lines appear on ADF-fed printed copies, but
they do not appear on scan-to-network [e-mail, FTP, folder (PC),
solutions]...
