Question about Dryers
Dryer does not want to start. I Have checked all fuses continutity present. I replaced the timer, still no start. The door light stays on. I can not find a door switch. I have a whirpool dryer mod # LER 8648PG0
  • jorge9053 May 07, 2010
    Found it. The switch seems to work okay.
    The door is just not making contact.
    I put tape to hold it down and presto.
    The dryer is working. Thanks for your assistance.
    President:
  • 1,218 Answers
Good day,
If the light is staying on when it should not, then it or it's activator is bad.
The door switch could well be the whole problem.
Remove the lint filter, the 2 screws under it, then with a screw driver, pop up the front of the lid.
You should have no problem seeing the switch, and how it's mounted.
It is mounted on the front panel.
Posted on May 07, 2010
I have a Kenmore 800 model no. 110.69822801 dryer that stopped during a drying cycle. It would not start. I found helpful tips from your site and decided the door switch was faulty. I bought a new switch...
Check the thermal fuse, check the belt switch. If these are OK, check the timer. The timer troubleshooting guide may be located within the control panel. If the dryer still doesn't turn on, check motor winding continuity, and finally control board. Perform these checks with dryer unplugged. Most likely causes: Thermal fuse or timer. If thermal fuse is problem, clean dryer duct after fuse replacement.
Dec 18, 2014 | Kenmore Dryers
Dryer will not come on at all. working fine on last load
check house fuse/circuit breaker
door switch
if an electric dryer the thermal fuse as they are often wired into the motor run circuit
check for power to the motor in start and run circuit, if present motors spent.
if not present trace back to timer and verify timer is sending power, if not timers spent.
more likely circuit breaker, door switch or thermal fuse if electric dryer..
hope this helps,
best of luck,
ttfn
Oct 27, 2009 | Kenmore 64902 Electric Dryer
I have a RES7745RQ electric dryer. The timer
HI, check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
2. Door switch / Door switch actuator lever
The dryer will not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
4. Timer
Replace if defective (note: uncommon problem).
**The most common issue here will be a defective Thermal fuse, but if all is ok with the above stated areas, replace the start switch.
Aug 19, 2009 | Dryers
Heating element stays on when dryer is off.
I would advise to inspect the high limit thermostat. this device may be defective. this will cause the element to continue to operate when the unit is off as well. If the thermostat is operating correctly, replace the timer.
Aug 12, 2009 | Maytag PYE2300AY Electric Dryer
Whirlpool dryer ler7646lez, nothing happens when pushing start button, 240 volts present at pigtail, good continuity to timer, no drum light or any response from dryer.
check that the door switch is operational also there is a white fuse on the back of the unit on the left side after you remove the back panel it should have a closed circut if not replace it
Aug 09, 2009 | Dryers
Dryer wont start
First I would check the door switch I could have broken off or quit working if that is ok then there is a white thermal fuse on the blower housing behind the back panel check with a ohms meter to see if it is good it has two wires going to it
Mar 30, 2009 | Maytag Dryers
Maytag dryer timer keeps running
Your dryers timer contacts have fused to gether.
The only repair is to replace the timer.
Mar 25, 2009 | Dryers
Dryer will not stay on and has power to it
The problem you've described appears to be the DOOR SWITCH (Very likely and very common).
The purpose of the door switch is to prevent injury when the drum is rotating. Thus, if the door is open or the door switch "thinks its' open" (broken), the dryer will not turn on for safety reasons.
Depending on your "handy" skills, the door-switch is pretty simple to replace and costs about $10-$15 or so. I would access the inside of the dryer; observe the metal trip level (not on all models), depress and test the switch for continutity; or replace as necessary.
Feb 01, 2009 | Dryers
Dryer doesn't turn on
1. No power to the dryerMake sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
The dryer would not start with a broken door switch. Replace the door switch if found defective.
3. Thermal fuse
4. Timer
Nov 13, 2008 | Kenmore 659 Electric Dryer
Dryer won't start
your light should be working regardless of badtimer even, id check the incoming power supply, adn the connection behind the unit itself
Apr 12, 2008 | Maytag Performa PAV2200
Dryers Logo
20 people viewed this question
Top Dryers Experts
