Question about Nikon D3000 Digital Camera
I cannot get my camera to turn on. The battery is fully charged, but when I switch it on, nothing happens!
  • eeb9494 May 07, 2010
    The camera is brand new. i just got it yesterday. I will try cleaning the connections, but I am afraid it could be something else.
    The camera is brand new. I will try this, but I think it could be something more.
    President:
  • 2,761 Answers
This problem is frequently due to a buildup of corrosion on the battery terminals and contacts in the camera. The buildup may or may not be visible, and it happens often if a camera is not used regularly.
Remove the battery, then wipe all contacts firmly with a clean dry cloth. Heavy corrosion may require cleaning with a fine wire brush, steel wool, or sandpaper. After cleaning, make sure that no residue remains in the battery compartment, reinstall the batteries, and give them a good charge.
If this does not cure the problem, check the "charged" batteries with a voltmeter, try them in another device, and/or try other batteries in your camera. If your camera battery is more than a year old, chances are that it needs to be replaced.
HINT: Always remove the batteries if your camera will not be used for a week or more. Doing so will extend the life of the batteries and prevent damage to the camera.
Bill B
Posted on May 07, 2010
  • Bill Buchsbaum
    Bill Buchsbaum May 07, 2010
    Sorry - didn't realize that the camera was brand new. It's possible that the battery is defective, or that the charger is not working properly. Either way, I would return the camera for an exchange.
    Bill B
Mark iii 5D will not turn on- battery is fully charged. I have tried taking the memory card out, battery out, lens off, etc and then replacing all of the above and restarting, but nothing happens.????...
And you are sure the fully charged battery also has enough capacity to power the camera? or it only reached a certain voltage so the charger says it is charged?
Also did check the contacts on the battery and in the camera?
Make sure the battery has enough power, by measuring the voltage with a multi meter. The voltage should be higher than what is printed on the battery.
Mar 15, 2015 | Cameras
Optura 60 cannot be turned on
Whether you think the battery is fully charged or not this sounds like a defective battery problem. Have the battery checked.
May 05, 2017 | Canon Optura 60 Mini DV Digital Camcorder
My digital camera doesnn't turn on, i try to charge but nothing happened i can't turn on.
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera.
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Without the memory card,turn on your camera.
If issue persists, call 1.800.235.6325 for repair.
Thanks.
Neerak21
Sep 28, 2009 | Digital Blue EasyShare MD1063 Digital...
Camera won't turn on.
Make sure the battery contacts are clean. The rechargable batteries looses their charge even when they are not in use. It is important to fully charge the first time the rechargable batteries.
Dec 14, 2008 | HP Photosmart R707 Digital Camera
Sony dsc-s600
1= Use rechargeable battery cells and must be fully charged.
2= Check battery terminals in camera battery compartment. Must be cleaned and shiny.
3= Sony camera DCS-S600 won't charge batteries through USB cable plugged in PC. You need external battery charger to charge battery cells.
Oct 22, 2008 | Sony Cyber-shot DSC-S600 Digital Camera
i have the same problem with this camera! ahh help!
Apr 14, 2008 | Casio EXILIM EX-Z1000 Digital Camera
Camera will not power on or off and battery is fully charged
The symptoms you describe sound very much like a failing battery. How old is your battery? Rechargeable batteries are only meant to last for a couple years, regardless of use.
Apr 03, 2008 | Canon PowerShot SD400 / IXUS 50 Digital...
The batterys are charged, but nothing happens when I turn it on.
This camera and the model before it have a problem with inrush current opening a safety fuse on the DC-DC converter board. If this is the case, JVC will replace the SMD fuse with a modified part number, this should resolve the problem. Please be sure the camera is off before attempting to change the battery, this can also cause this problem. Good Luck. Joe Weibel customelectronics.org
Feb 25, 2007 | JVC GY-HD100 Mini DV Digital Camcorder
Nikon D3000 Digital Camera Logo
52 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
