Question about Foxconn WinFast K7S741MG Motherboard for AMD Socket 462 CPU (K7S741MB6L)
Cant access USB Ports
After I have format my PC the USB Ports doesn't seem to work at all. I have tried plugging in the USB but it doesn't react and after checking it out on the Device Manager, the USB is not included. Please help me out on this problem. My pc is Pentium 4 and the Motherboard is PM800-M2 ECS.Thank u Very Much for your help...
usb dont appear in the device manager and my motherboard is winfast k8m890m2ma-rs2h i also cant find the driver installer in the cd.. pls help
  • 2 more comments
  • noel06 Mar 28, 2008
    hey i found the Cd but which driver should i install is it the chipset? but when i tried to install it this one appeared "dll function call crash ISRT.calldllfn" and the wizard was interrupted before via setup program could be completely installed.the system has not been modified. i also tried the site but it has the same result. pls help
  • noel06 Mar 29, 2008
    my friend said that my windows was a plug and play and i dont need any driver?
  • noel06 Mar 30, 2008
    yes maybe my problem is with my motherboard or usb port. because none of them work. i also try the installshield you said but when i try to install the cd the same result happens. by the way thanks for helping pal.! ^^
  • Anonymous May 11, 2010
    did you build this computer yourself? have you checked the internal connections on the motherboard, also which ones are you using (front panel or rear)?
  • 242 Answers
Using XP?
You can download latest driver for your motherboard here
Posted on Mar 27, 2008
  • Thx_nb Mar 28, 2008
    The driver that should work is this one. Could be the same as the one on your cd, but this is the latest from the website...
    The errormessage you get, seems to be an error in the installer.
    Make sure you have the latest windows installer or macrovision installshield. The error seems to be in the installer that is used...
    If it is InstallShield check this out about how to get the latest version.
    Hope it helps
    Success!
  • Thx_nb Mar 29, 2008
    Plug and Play means your computer has or can retrieve drivers for the most common devices.
    Plug and play works fine for most external devices, but for most system
    devices, like motherboard, graphics card and so on, you'll need to
    install the drivers to configure them correctly.
    Is there any other USB-device that does work in your USB-ports? If yes, the problem is in the device.
    If not, the problem is with your USB-ports. These should work correctly, but it can be that they don't if you haven't installed the drivers of your motherboard. If the drivers are installed, and it still doesn't work, I think your problem is with the motherboard/usb-ports itself and you should have a technician look after it...
Please I need a motherboard thank you
Posted on Apr 18, 2008
SOURCE:
I cannot get my keyboard or my mouse to work with my dell computer. what can i do?
Please add more information to get specific assistance. Are these wireless devices? If wired, do they use USB or PS/2 connections.
For wireless devices, try replacing the batteries and resynching to the receiver. (You may want to check putting the receiver in different USB ports.)
For wired devices, disconnect and reconnect. For PS/2 devices, you will need to restart the computer to check if the devices work. For USB devices, try connecting to different USB ports.
Next step, try using a different keyboard and mouse (that work on another computer (stick to USB or PS/2 to match the current pair)). Try a wired set if the problem is with a wireless pair. If those work, continue diagnostics on the wireless keyboard and mouse. Check if the mouse and keyboard work on another computer. If they don't work with another computer, replace them.
If another USB keyboard and mouse pair don't work in any port, your USB ports may have failed. Check if even one port works enough to access the Device Manager. (Start > Control Panel > Hardware and Sound > Device Manager (Win7); similar directions in other versions of Windows) Check for a problem with the drivers (For USB ports, scroll down to the USB drivers and look for a triangle with a yellow exclamation point or red x). Try to update the driver or roll it back. If that doesn't help and one USB port works, a USB hub may solve the problem.
Otherwise if the USB or PS/2 ports do not work with any devices and the driver fix doesn't work, then I'd suspect a problem with the ports on the motherboard. Replace the motherboard/computer.
I hope this helps.
Sep 12, 2011 | Dell Computers & Internet
Hp pavilion dv1000. All 3 USB ports not recognising any device
go to device manager and from there try updating the usb drive from there
Feb 28, 2008 | HP Pavilion dv1000 Notebook
External Hard Drive stopped working
u might have to format it in safe mode or buy a new one, if you try it on some one elses comp. and it works it ur comp. but it is most of the time a software issue
May 08, 2010 | Toshiba 120GB USB 2.0 Portable External...
Trouble accessing files on usb
It is probably a driver error on your operating system. I suggest trying a couple different ports- if that doesnt work try a different computer. If that doesnt work most likely your drive file system is damaged and needs to be formatted. Good luck!
Sep 23, 2009 | Dane-Elec DaneElec 4GB USB Drive Red Hard...
My mass storage device & usb plugs wont work
You need to find out what motherboard you have or if your computer came with a disk. You need to load the driver of the motherboard so you can access your usb ports.
Dec 12, 2008 | Toshiba Satellite A135-S2276 Notebook
USB ports suddenly not functioning
hi, see if you have installed any new devices/hardware to see if its conflicting, often grafics cards conflict usb devices, also just check that in the setup(when you boot up)that the usb ports have not been disabled or usb keyboard support hasn't been enabled/disabled. good luck!!
Apr 01, 2008 | EliteGroup nForce3-A Motherboard
Sandisk 1GB Cruzer Titanium Flash Drive
try partioning then formating if dont work its corrupt
Feb 24, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Acer 5100 laptop USB ports freezing touch pad
Maybe your thumbdrive is the problem try to format the thumbdrive first
Jan 22, 2008 | Computers & Internet
Run the cd that came with your MB. It has them on it.
Jan 01, 2008 | EliteGroup PM800M2 Motherboard
I am not able to use my san disk 2 gb on my office system on xp
Just a few questions about your system and we should be able to resolve your problem fairly quickly. Firstly is your xp a service pack 2 installation, secondly is your usb ports usb 2.0, and finally does other usb devices work properly when plugged into the same physical usb port on your pc?
Scan disk drives have the driver and application software on a partition built onto the drive thats not accessible for write access, meaning you cant format that partition. Other systems see that partition just fine, but it seems your system is having trouble doing so. Theres a few reasons for this trouble. If you can provide me with the detail i need about your system im shure we can resolve your issue promptly.
Nov 29, 2007 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Foxconn WinFast K7S741MG Motherboard for AMD Socket 462 CPU (K7S741MB6L) Logo
295 people viewed this question
Top Foxconn Computers & Internet Experts
Ekse
Alun Cox
Thomas F. Schneider
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
