Question about Samsung SGH-S5230 Cell Phone
Help When I receive a call and i press the answer button, sometimes the phone just does not "want" to answer and although it stops ringing i can't answer. Also, sometimes when i speak at the phone i can't hear the other person at all. I've changed my software twice and i did not have any result
  • 343 Answers
Please clean the cell phone you only have to open
Posted on May 07, 2010
How seup fax ring
Before selecting the ring to answer, under stand what it is..
Press Menu button, scroll to fax set up with help of arrow keys, press ok button, scroll to answering mode. Select desired "auto, manual, fax & tele/fax.
What are these?
Auto: Auto aromatically tele mode will coverts in to fax mode irrespective of selected ring count. suppose if ring count selected as 4, printer will ring 4 times then stops ringing & converts in to fax mode. It doesn't matter whether it's telephone or fax.
Manual: Printer always telephone mode. To convert in to fax mode, need to press fax button while ringing.
Tele/Fax: Printer detects the incoming call type as tele(analog)or fax(digital) accordingly its will act. If its fax , line converts in fax mode with out any ring(silent detection), prints the received fax.If its telephone,printer rings as tele phone.
* In auto mode only you need to select desired ring to answer(2-6 rings)
There fore first you need to select "auto"mode, then scroll to ring to answer, press ok then select desired ring count, press ok to confirm..
Aug 23, 2014 | HP LaserJet 3050 All-In-One Printer
Canon MP830 has stopped receiving faxes. When the fax phone number is called it rings but the fax does not pick up.
Can you still send fax? if sending and receiving are not working you can try to update or uninstall/reinstall the software for this unit..
Hope that helps.............
Aug 15, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Hi my hp 640 will not answer a fax call, but will answer only if we pick up the hand set.
Issue When the all-in-one product is sharing a phone line with voice calls, some calls are interrupted by fax tones. Follow the steps below to solve the problem.Step one: Check the Rings to Answer setting If Auto Answer is enabled, the HP fax product will answer the phone line when the number of rings reaches the number of rings specified in the Rings-to-Answer setting. When voice calls will be received on the same phone line as faxes, set to rings-to-answer to 6. If you do not want the fax to answer automatically, either turn off Auto Answer from the front panel and receive faxes manually (this may result in lost faxes) or subscribe to a distinctive ring service from the phone company (if available). Refer to the Answering faxes manually section below to learn how to answer faxes manually or refer to the Using distinctive ringing section below for more information about using distinctive ringing. The Rings-to-answer setting for the HP Officejet 500 and 600 series products can only be checked or set using the all-in-one software on the computer. The Rings-to-answer setting for the HP Officejet 500 and 600 series products can only be checked or set using the all-in-one software on the computer. Follow the steps below to check or change the setting for all models except the HP Officejet 500 and 600 series:
  1. Depending on the model, press either Menu , Setup , or Fax Setup repeatedly until Basic Fax Setup appears in the display.
  2. Press Enter (or Start or OK ).
  3. Press the right arrow button repeatedly until Rings to Answer is displayed, and then press Enter .
  4. The number of rings before the HP fax product answers will be displayed.
    • The setting is correct if it is 6. Press Cancel or Stop (Stop Fax) to exit the menu.
    • If the number is not 6, press the right arrow button until 6 appears in the display and then press Enter (or Start or OK ).
Aug 30, 2011 | HP 640 Inkjet Fax Machine
Which port to use for fax???? sonyajohnsonrn@yahoo.com
Followup the steps to setup the printer to send/receive fax.
Connect the phone line ( wire ) to Line 1 Ext at the back of printer port.
The connection is from the Phone socket to printer.
Press the Auto-Answer button on the front panel of the printer to enable automatic fax receiving.
If your no. of rings on voice mail or Answering machine is 4, you need to set 6 Rings to Answer on printer to receive the fax or else the printer will start accepting all the voice mail calls.
Press the Setup button on printer front panel
Scroll till you find Basic Fax settings Or Advanced Fax settings - Press OK
Choose the option Rings to Answer - Press OK
Set the No. of rings. - Press OK
Your printer is ready to send/receive Fax.
* Please rate this solution with Thumbs up and comment to help us improve providing support
Dec 02, 2010 | HP Photosmart C7280 Laser Printer
I have no sound from the earpiece when ringing a number, although it does ring out OK. It rings and receives calls Ok but I cannot hear the caller, except by putting it to loudspeaker. In all other...
sir while you answering the call press the volume button to increace the sound [or] give to the nokia service center for replacing the new earpiece mic for getting better volume................
Nov 26, 2010 | Nokia 6700 Classic Cell Phone
HOW DO I GET MY FAXES OUT OF THE MEMORY?
Receiving a fax
Receiving a fax automatically
1 Make sure the printer is on and is connected to a working phone line.
2 Make sure that Auto Answer is on.
To check if Auto Answer is on:
a From the printer control panel, press (tool icon).
b Press the arrow buttons until Fax Setup appears, and then press ok.
c Press the arrow buttons until Ringing and Answering appears, and then press ok.
d Press again.
Check to see if Auto Answer is set to On.
e If Auto Answer is not set to on, press the arrow buttons until On appears, and then press to save the setting.
3 Set the number of times the telephone rings before the printer automatically receives faxes:
a Press the arrow buttons until Pick-up On appears, and then press ok.
b Press the arrow buttons until the setting that you want appears, and then press to save the setting.
When the number of rings you set is detected, the printer automatically receives the incoming fax.
Receiving a fax manually
1 Make sure the printer is on and is connected to a working telephone line.
2 Make sure that Auto Answer is off.
3 To receive the fax, press (green botton) or press * 9 * on the telephone after you answer it and hear fax tones.
4 Hang up the telephone.
The printer receives the fax.
Receiving a fax with an answering machine
1 Make sure that Auto Answer is on.
2 Make sure you have set the number of times the telephone rings before receiving a fax automatically.
When a telephone ring is detected, the answering machine picks up the call.
• If the printer detects a fax, it receives the fax and disconnects the answering machine.
• If the printer does not detect a fax, the answering machine receives the call.
3 Set the answering machine to answer incoming calls before the printer does.
For example, if you set the answering machine to answer calls after three rings, set the printer to answer calls
after five rings.
Forwarding faxes
Use the fax-forwarding feature if you are going to be away, but still want to receive your faxes. There are three
fax-forwarding values or settings:
• Off—(Default)
• Forward—The printer sends the fax to the designated fax number.
• Print & Forward—The printer prints the fax and then sends it to the designated fax number.
2 Press the arrow buttons until Fax Setup appears, and then press ok.
3 Press the arrow buttons until Ringing and Answering appears, and then press ok.
4 Press the arrow buttons until Fax Forward appears, and then press ok.
5 Press the arrow buttons until Forward or Print & Forward appears, and then press ok.
6 Enter the number to which you want to forward the fax, and then press ok.
Aug 12, 2010 | Lexmark X5650 ALL-IN-ONE PRINTER
Canon mf4150 -- fax has a mind of its own?
Hi ...
The problem is with receive mode settings ... Following the below instructions and you can change the receive mode settings which will resolve the problem.
Setting the Receive Mode
  1. Press <Additional Functions>.
  2. Use <la.gif> or <ra.gif> to select [5 FAX SETTINGS], then press <OK>.
  3. Use <la.gif> or <ra.gif> to select [3 RX SETTINGS], then press <OK>.
  4. Use <la.gif> or <ra.gif> to select [3 RX MODE], then press <OK>.
  5. Use <la.gif> or <ra.gif> to select the desired receive mode, then press <OK>.
    round_note.gif - For [AnsMode], make sure an answering machine is connected to the machine. If [AnsMode], [FAX/TEL], or [DRPD] is selected, you can select some settings as below:
    [AnsMode]
    --- [AnsMode CHK TIME] (select time from 10 to 30 seconds for the answering machine to start playing outgoing message after receiving a call)
    --- [FAX DETECT TIME] (select the duration from 10 to 70 seconds for the fax to detect)
    [FAX/TEL]
    --- [RING START TIME] (select the time from 0 to 30 seconds for the phone to start ringing after receiving a call)
    --- [F/T RING TIME] (select the duration of ringing from 10 to 45 seconds)
    --- [F/T SWITCH ACTION] (select the action the machine will take after the ringing ends, Receive or Disconnect)
    [DRPD]
    --- [NORMAL RING]
    --- [DOUBLE RING]
    --- [SHORT-SHORT-LONG]
    --- [SHORT-LONG-SHORT]
    --- [OTHER RING TYPE]
  6. Press <Stop/Reset> to return to the standby display.
Jul 17, 2009 | Canon imageCLASS® MF4150 All-In-One Laser...
Canon MP530 receive fax issues
Receive Mode Settings Select from the following receive mode options to suit your needs. Once you've decided on which receive mode to use, follow the below instructions to set the receive mode using the operation panel. Receive Mode Setting
  1. Press the <FAX> button to enter Fax mode.
  2. Press <Menu>.
  3. Press the right or left arrow button to select [Receive mode settings], then press the <OK> button.
  4. Press the up or down arrow to select the receive mode that best suits your needs, then press <OK>.
Types of receive mode
Select the receive mode according to your needs.
Receive mode
Purpose
FAX/TEL AUTO SW When you want to receive faxes automatically as well as voice calls. FAX ONLY MODE When you want to receive only faxes automatically with your machine, or have a dedicated telephone line for FAX use only. DRPD When you have subscribed to a DRPD service with your telephone company. MANUAL MODE When you receive mainly voice calls and sometimes faxes, or want to receive faxes manually. ANS.MACHINE MODE When you want to receive voice messages on your answering machine and receive faxes automatically. FAX/TEL auto switch
FAX :
The machine does not ring but will receive the fax automatically. Voice call :
The phone attached to the machine will ring. Pick up the handset to answer the call. Note:
  • Ring start timing and Telephone ring length can be specified in FAX/TEL auto switch in the Receive mode settings.
  • If you want the telephone to ring when it receives a fax, connect a telephone to your machine and enable the Incoming ring settings in RX settings.
  • The phone attached to the machine may not ring depending on the telephone type you are using.
FAX only
FAX * :
The telephone does not ring. The machine will receive the fax automatically. Voice call :
You will not be able to answer the call. * If you want the telephone to ring, connect the telephone to your machine and enable the Incoming ring settings in RX settings menu.
DRPD
FAX :
Your telephone line will ring according to the ring pattern you have chosen and receive the fax automatically. Voice call :
Your telephone line will ring according to the ring pattern you have chosen. Pick up the handset to answer the call. Note: Specify the FAX pattern in the DRPD: Set FAX ring pat. in RX settings menu.
Manual RX
FAX :
The telephone attached to the machine will ring. Pick up the handset and if you hear a beep tone, press the <Color> or <Black> button on the machine to receive the fax. Voice call :
The telephone attached to the machine will ring. Pick up the handset to answer the call. Note: If you are far from your machine, you can use the remote receiving function to receive faxes. Pick up the handset of the telephone connected to the machine and press 25 (the remote receiving ID).
Ans. machine connect
FAX :
First the answering machine connected to your machine will respond to an incoming call, and then the machine will receive faxes automatically. Voice call :
The answering machine connected to your machine will respond to an incoming call. Note:
  • Set the answering machine to answer on the first or second ring.
  • The entire message should be no longer than 15
Nov 24, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Fax
HI,
u need to make change to answer ring pattern from the front panel of unit .
Set the fax function to answer the phone automatically by pressing the auto answer mode button on front panel .
Thanks
Jun 04, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Motorola H350 - Incoming calls
there is nothing you can do about the delay as it's the time it takes for the bluetooth to send the signal to your earpiece to tell it the call is answered, the only way to stop any delay is to set your phone to auto answer in the bluetooth headphone settings or in the call settings.
Aug 07, 2007 | Motorola Mobility H350 Wireless Headset
Samsung SGH-S5230 Cell Phone Logo
57 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
