Ricoh FT7650 Copies coming out are lighter than the original and adjusting the lighter/darker setting does not help. Can anyone help?
    Scholar:
  • 141 Answers
Maybe your glass is dirty, with alcool and a clothe clean the glass. If you can go undernit go but be carefull for the miror inside.
The Drum may need to be replace to????
Last solution:
If you have a lot of copy (100 000) and more and never get service on it....I think your Developper as to be repalce...and if your not a tech you will not be able to replace it, because you have to calibrate and ajust..... But before that call a tech to see !
Posted on Mar 27, 2008
How to make darker copies
if your referring to photocopying but printout is darker, it doesnt work. canon copiers produce copies like the original or better than the original sometimes. try to scan the file in custom mode and adjust the brightness and contrast and click preview to view the outcome before scanning it then print it later
Sep 30, 2013 | Canon PIXMA MP210 Photo All-In-One Printer
Copies are lighter than original on savin 2055dp copier
This project came out of a thread on Laserpoinerforums where members were discussing ways it could be done, my thoughts were along the line of:
What is "the" Lighter with Laser ? Answer Zippo flip-top, I had to find out if it can be done.
May 17, 2012 | Ricoh Office Equipment & Supplies
My konica 2223 copy lamp is dim resulting to paper jams and blank copies, im just repalce my Power supply board
Check your newly installed power supply board input rating if the same with the old one if yes P51 error common for front door open and can be cleared by closing the front door. Door lock actually connect to the interlock switch at the back beside power supply unit sometimes we just clean connectors if not replace power supply. Now if the light scan with very low intensity the result would be darker and probably will cause you paper jam at the fusing/heater unit but, if blank copies the light intensity is to high. you may adjust or correct it by CVR adjustment/Light intensity adjustment " go to 36 mode off machine hold 3 and 6 while power on release 3&6 after display reads CC, enter address 9-0, start, p- select (0/30 darker 35/55 normal- 60/90 lighter) this adjustment may vary depending on drum coating and optical adjustment/cleaning. I suggest clean first all mirrors before you do it.Hope this may help you sold the problem.
Feb 19, 2012 | Office Equipment & Supplies
Our copier is copying in light shade. how to make it darker
To adjust the default lighter/darker setting
1. On the LaserJet 3015, press MENU/ENTER.
2. Use the < or the > button to select Copy setup, and then press MENU/ENTER.
3. Use the < or the > button to select Def. Light/Dark, and then press MENU/ENTER.
4. Use the < or the > button to adjust the setting. Move the slider to the left to make all of the
copies lighter than the original, or move the slider to the right to make all of the copies
darker than the original.
5. Press MENU/ENTER to save the selection.
Page 48 of the User Guide has instructions for adjusting the light/dark setting during a copy job.
Also see the Troubleshooting section of the User Guide for other possible reasons for light/faded copies.
If your copies continue to come out too light, you may need to clean the insert a new toner cartridge or change brands of toner. I tried several "generic" toner cartridges and refills, but my prints and copies were always faded or streaky. After going back to genuine HP cartridges, I haven't had any print quality problems.
Jul 21, 2011 | HP LaserJet 3015 All-In-One Printer
Replaced drum cartriddge on model AL-1661CS and still has error reading to replace cartridge
After replacing drum catridge you should reset the drum counter in the following way
1.Identify the buttons used for adjusting exposure (darker or lighter copies), amount of copies, clear copies and start copying
2.Now press the following sequence of buttons: [CLR], [AURO], [CLR], [AUTO] all thes one by one
3.Your unit should turn off the numbers in the panel
4.Now press 24 as if asking for 24 copies and press [START].
4.Now press 07 as if asking for 7 copies and press [START].
This should reset your drum and it should stop flashing
RNJ VINOD KUMAR
Sep 15, 2009 | Sharp Office Equipment & Supplies
Streaky copies
It probably has several issues - optics dirty, and drum, and blade failing. I would also imagine that even the Solid "blacks" aren't as black as they could be, and that would be the developer. This machine is in the 17 year old range, and I wouldn't spend dime on it
Mar 29, 2009 | Ricoh Office Equipment & Supplies
Toshiba 2060 Photocopier prints copies that are a bit too dark.
restart the copier while holding down the "0" and "5" keys. you will now be in service mode. enter "5" and press "start" key a number should show up in the display. this is the exposure value - how dark or light the copies will be. 5 is the automatic exposure setting. around 128 is the normal value. the larger this value the lighter the copies are - the smaller the value the darker the copies.
Enter a new number (exposure value) and press the "interupt" key to save the value. Restart the copier and check what the copies look like. Keep adjusting until it looks good/better.
Mar 26, 2009 | Toshiba 6560 Copier
Darkening the copies
Here's information from the HP manual:
Use the copy features
The HP All-in-One enables you to produce high-quality color and black-and-white copies on a variety of paper types, including transparencies. You can enlarge or reduce the size of an original to fit a specific paper size, adjust the darkness of the copy, and use special features to make high-quality copies of photos, including
borderless copies.
Press Copy repeatedly to display the appropriate menu. The following menus are available:
– Number of copies
– Reduce/Enlarge
– Copy Quality
– Copy Paper Size
– Paper Type
– Lighter/Darker
– Enhancements
– Set New Defaults
2. Press the until the appropriate setting appears.
3. Do one of the following:
– To change more settings, press Copy.
This selects the current setting and displays the next menu.
– To start the copy job, press Start Color or Start Black.
To save the current settings as defaults for future jobs
1. Make any needed changes to the settings in the Copy Menu.
2. Press Copy repeatedly until Set New Defaults appears.
3. Press until Yes appears and then press OK.
This should help you.
Feb 20, 2009 | HP Officejet 5610 All-In-One InkJet...
IMAGE TOO DARK ON GEI GRAPHIC ZOOMER POSTER BANNER SYSTEM
First I would give the optical area a good cleaning --- mirrors, lens, etc.. If this device has the 'slide' adjust for the image quality, the slide may have come out of the holder. Try seeming if the slide is seated properly. If this is the 'thumb / circle ' adjust, the POT ( value adjust on the board) may need to be reset. There is always the chance the the board is cracked or has a cold solider joint (pins) for the adjuster. IF you are inclined, that the cover off and check for crack, if no crack heat and re-solider the pins for the adjust switch.
Dec 30, 2008 | Standard Registar SD650 Color Copier
jasbo
jasbo
