Question about IBM ThinkPad T41 Notebook
IBM Thinkpad laptop wont start up
Hi, i was opening my laptop a few days ago, to see what the problem was with my flickering screen. I look every component apart, and then i put back every component in its correct place. However, when i shut the laptop screws, and i inserted the power adaptor and i pressed the power button, the laptop didn't start up. There were no LED lights or nothing
Any thoughts would be most appreciated
Thanks
Indajay
  • 2 more comments
  • Anonymous Mar 28, 2008
    hi
    i havent tried running the laptop just on the ac adapter, but im not sure that it ill work. Could it be a motherboard failure? really need it to work. Any thoughts on what the problem is?
    Indajay
    hi
    i tried running the laptop via adapter but it didn't work. which section is the power jack or rather what colour is it? so i can have a go at soldering it.
    If that doesn't work, do u think i need to buy a new motherboard?
    cheers
    Indajay
  • Anonymous Apr 05, 2008
    hi
    i tried soldering the jack and i also used my dads battery and ac adapter, see if it worked. However, there still wasn't any power!
    any thoughts on what to do??
    cheers
    Indajay
  • Anonymous Apr 15, 2008
    Hi
    havnt had any luck with my thinkpad at the moment.
    the laptop just doesnt start! no leds, no power. i even tried a working condition battery and ac adapter - but to no avail!
    Any thoughts are most appreciated
    Indajay
    Guru:
  • 377 Answers
Hi dear
Hi RD, Ouch! Have you tried taking the battery out to see if it will run on AC power when the battery is not installed? Sometimes a bad battery can kill the system.
Do you have a meter that you can measure the output of the AC adapter with to see if it is correct? If not, any chance you could swap adapters with someone for a while to see if theirs works on your computer and vice versa? A local shop may also be able to test your adapter to see if it's working.
oke
regards, cropp
Posted on Mar 27, 2008
  • Irwan Darmawan
    Irwan Darmawan Mar 28, 2008
    hi dear
    maybe your problem in power jack,
    try to soldering your power jack,,, to ensure your conecction
    oke
SOURCE:
IBM R40 laptop will not start.
remove the battery and adapter. press power button for 30 sec. then connect the adapter. press power button. if this didnt work. you need to ask for an help of a local tech to check for the video card and cable.
Mar 22, 2010 | IBM ThinkPad R40 2722 Notebook
My R51 thinkpad screen keeps flickering and is quite garbled it blanks out alot and stays black until you hit FN + F7 (the key to switch from laptop screen to desktop screen) in wich case the screen would...
Sounds like the lcd is toast.
Hook the laptop up to an external monitor and see if you get normal video. If you do, chances are it's the lcd. You'll have to replace it.
Jun 19, 2009 | IBM ThinkPad R51 Notebook
Ibm thinkpad t43 backlight inverter issue
Did you say the the video output flickers on and off when you connect an external monitor to the video output. If the inverter is faulty this would not affect the video output and the external monitor would not flicker but if the external monitor flickers it would point to a video card problem.
Jun 13, 2009 | IBM ThinkPad T43 Notebook
Ibm thinkpad lock
Hi, If you are talking about the Boot, HDD, Bios password, then the only one way to recover it is to implement a chip on the systemboard to shorcut the protection or to contact Lenovo for a systemboard replacement. Otherwise you can check out theses 2 tutorials, with few skill you can make it yourself: -http://www.allservice.ro/forum/viewtopic.php?t=47&start=0 -http://marc.info/?l=full-disclosure&m=111234041830357&w=2 More infos on this wiki about the password: http://www.thinkwiki.org/wiki/Maintenance#Recovering_BIOS_passwords. Unfortunalty,there is no other ways other round. Thanks and have a nice day J-
May 19, 2009 | IBM ThinkPad T41 Notebook
Problem with ibm thinkpad r40
The IBM beep code error 1 long 2 short beeps means there is a video card fault. Reseat your RAM because the video card uses some of the RAM. If it doesn't work then the video chip on the motherboard is faulty, the only way to fix is to replace the motherboard - this may not be a cost effective solution.
Connecting an external monitor to the laptop won't work because the video card also sends data to the video port.
Apr 06, 2009 | IBM ThinkPad R40 2722 Notebook
When i turn on my laptop, the screen is blank
It seems to be u have problem with ur RAM ..Try to change it
Nov 29, 2008 | IBM ThinkPad R40 2722 Notebook
Ibm thinkpad laptop wont start
The BIOS/CMOS backup battery is probably due for replacement; that system has a few years on it and the coin cells are good for maybe 5 years.
If you don't have your original user guide, you can get the maintenance manual here:
http://www-307.ibm.com/pc/support/site.wss/MIGR-4PER6R.html
It will contain battery replacement info.
Aug 19, 2008 | IBM ThinkPad A21m 2628 Notebook
LCD/Video Card? on IBM ThinkPad T30
hi, u will have to open the top cover, there u can see the LCD cables going to the MB, clean the connectors at both ends, i.e MB &LCD..let me know
Jan 13, 2008 | IBM ThinkPad T30 2366 Notebook
Thinkpad 600E
IBM Thinkpad error code 19990301 is a Hard-Disk sector problem. Basically your hard-drive is faulty and you need to replace it. This is why it wont boot; because the area of the hard-drive that stores data is damaged.
Sep 20, 2007 | IBM ThinkPad 600E 2645 Notebook
IBM ThinkPad T41 Notebook Logo
295 people viewed this question
Top IBM Computers & Internet Experts
Ekse
Alun Cox
Thomas F. Schneider
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
