Question about Toshiba TLP S30 Multimedia Projector
It wont show a picture on the wall just green from the lense
  • zaine khan May 11, 2010
    sounds like the main board has been burnt-out,try replacing it.
  • 144 Answers
Replace the main board
Posted on May 08, 2010
TV projects red blue and green lights onto wall
If you project it on a distant wall the convergence will be way off since the tv was designed to project it just a few feet at most onto the screen. So you would have to do some manual adjusting... As for the screens you need the two layers...if one is broken get a broken model like yours on Craigslist for parts or check with www.TvRepairKits.com for screens...they are stocking some
May 20, 2013 | Toshiba 57H83 57" Rear Projection HDTV
Nikon l810 doesnt switch on, green light comes on then goes off
you may need to set the timer longr to take the picture also be sure to open the lenses or remove the batttery yt reset be sure to used right can of batterys
Aug 27, 2012 | Nikon COOLPIX L810
My 52in hd tv wont show a picture and when you cut it on it just light up red but no picture and i cant get to adjust the convergence on the menu.
If the screen is a bright red its indicating an issue with the CRTs could be the red has shorted or the coolant in the blue and green is needing replacement which makes the red Dominate. Looking into the blue and green lenses will verify if its a coolant isssue or not. The convergence issue is most likley failed convergence ICs and the associated 6.8 ohm resistors need replacment.
Aug 20, 2011 | Philips Magnavox 51MP392H Rear Projection...
My sony rear projection tv flickers green then shuts down ,any help
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service
Jul 19, 2010 | Sony KP-57WS500 57" Rear Projection...
Picture is not focused, color is off. When we
this sounds like the convergence ic's need to be replaced that should fix the problem
Jan 25, 2010 | Hitachi 57F500 57" Rear Projection...
After the lamp expired I have two red spots in the picture
There is only 2 things that will cause this and one is Dirt on optical Lense OR Light Engine is going BAD if light engine is it it will start showing more spots along with tiny DOTs and color on picture will be green and purple in different areas.
Aug 18, 2009 | Panasonic PT-40LC12 40" Rear Projection...
Describe your Fuji Finepix Z20fd Digital Camera When I turn on my camera which is a Fujifilm Finepix J20 it says card protected and it wont allow me to take or remove any pictures. How do I get it off? I...
This Camera is the best. It takes high quality pictures and is so easy to work it has video,self timer,regular camera,and can change to b&w,sepia,negative, and many more! it has a very bright flash and is so thin its unbelieveable! and you wont ever have a problem with the lense gettin stuck because the lense dosent come out all you do is slide the front cover and its turned on!!! I LOVE IT!(They come in pink,blue,green,red,and black i believe)
Jul 26, 2009 | Fuji Finepix Z20fd Digital Camera
Minolta G500
your lens mechanism is stuck up! try pulling the lens with slight force, if you are lucky the culprit that is blocking the mechanism will get loose. If you are not lucky theres no way you can remove or fix the problem than sending it to the authorized service center. =-(
Aug 24, 2007 | Konica Minolta DiMAGE G500 Digital Camera
Toshiba TLP S30 Multimedia Projector Logo
46 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
