Question about Hitachi EC12 Portable Electric 2hp Air Compressor, Oil Lubricated
Pump humms and barely turns. Fan blade caught wire caused huge spark. wire has been replaced.pump does not really seem to get going and trips safety after a minute of running.
  • 374 Answers
Hi there!
short circuited at start damage motor compressor
if you have a service center for motor compressor have checked this one, motor compressor has thermal overload protection mostly on single phase motor inside the motor,in the absence of overload protector the winding of motor on start and running maybe shor circuited.this should be rewind by motor rewinder.check the cost of motor rewind to a brand new motor.have choose n it.have a nice day fix my rate.
Posted on May 08, 2010
Why does the breaker keep tripping on this 2.0hp exhaust fan motor
Christopher, motors starter/capacitor could be faulty, wire circuit/breaker could be insufficient. motor could be faulty or wired incorrectly. Have motor checked out and ensure you are wiring correctly.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
LEESON Electric Motor Trouble Shooting Chart
Motor trips breaker Why
http://www.garagejournal.com/forum/showthread.php?t=256105
Jun 03, 2016 | Heating & Cooling
I have a Trane AC unit, model HIDE036506A which is about 14 years old. The fan and compressor all of a sudden stopped. I can start the fan by hand but the compressor sounds like it wants to start but...
sounds as if the fan motor is getting hot and going off on internal overload (safety). - which causes the compressor to heat up and also go off.
When this happens the usual 'fix' is to replace the motor although you can try replacing the capacitor.
Since you only see one (capacitor) it's possible it's a 'dual capacitor' which means it's the serving the compressor AND the fan motor.
I would replace the fan motor.
Note: I've seen 'shorted' fan motors before - where the blade just barely turns and you would not want to touch the blade because it will give you an electrical shock.
I would be very careful touching the blade of that motor with the power on.-
Jun 01, 2011 | Heating & Cooling
Noise from condenser fan. I cleaned the blade and the surronding area. Put some w-d 40 but the noise is still there. It is cold. Should I replace the motor? how hard is it to do? kenmore coldspot...
Go to www.searspartsdirect.com enter your model number and select model number search.
Here you can see a diagram of the unit. The fan motor cost 95 dollars.
It depends on the type of noise it is making.
These motors when failing tend to hum when trying to start which is a sign of a dry bearing.
Rattling sounds or ting ting ting sounds are either a lose fan blade (check the cheap retaining clip on the front of the shaft .. it may have wiggled forward causing the blade to wobble) or a lose mounting screw.
Also I can't tell from the diagram how close the fan is to the drip tray(tray evaporator) These fans not only aid in removing heat from the condenser.. they help evaporate the water in the drip tray.
If you remove the motor.. have it tested before replacing it. At a hundred bucks it's worth a trip to a good electric motor shop.They generally will test it for free.
If you are able to determine the voltage and hook it up out of the cabinet you may save yourself a trip.
Chances are it's a lose mounting screw or that front blade retaining clip.
Best of luck!
Apr 30, 2011 | Kenmore 64254 / 64252 / 64259 Top Freezer...
2000 chevy express 1500 van having starting issues
Start with fuel system. Listen for fuel pump humm at fuel tank No humm check wiring to pump for power. Then check for spark at plugs and wires. Remove wire from coil and hold near engine and see arch when you crank. No arch. Replace ignition Modular inside distributor cap or cap or rotor
Feb 04, 2010 | 2000 Chevrolet Express Cargo
I am not getting power to my fuel pump. the truck was running fine until i replaced my spark plugs and wires, then the next morning my truck wouldn't start. I've replaced the fuel pump, filter, relay, fuel...
on a lot of ford products there is a switch that goes from the fuel pump to the inside of one of the bedsides.
what this is, is a shock switch that turns the fuel pump off if it absorbs a hit.
its a really dumb safety feature but its effective.
there is a red button on it that u have to press to make it active again.
sometimes they just trip for no reason.
Jan 11, 2010 | 1990 Ford F150
5hp brigs &straton engine wont start. when itake out spark plug attach wire and lay pug against block and pull starter ican feel electricity getting to top of pug but there is no spark or arc at the...
try just the wire itself. make sure there is a bare spot on the block and see if there is a spark... if so it is possible that the spark plug is defective (it does happen)
robert
Oct 02, 2009 | Garden
I have a goodman Air conditioning unit CKL49-1. The fan motor connects to the top lid. Recently the metal cracked and broke and the fan fell down inside. I purchassed a new lid mounted the fan back on to...
Sounds like it is overloading and tripping the circuit breaker (that thing that pops up). More than likely when the fan fell down it stopped the blade from turning which caused the motor to overheat, melting the windings insulation which caused them to short out which causes the circuit breaker to trip.
Sorry, you are going to have to get a new motor to go with the new lid.........
Sep 03, 2009 | Goodman CKL49AR49 Air Conditioner
Pond pump trips circuit breaker
The circuit breaker trips because there is an electrical short in the pump itself or in the wire feeding the pump. A cause of this could be a bare wire, or a crack in a wire. Remove the pump and put it in a five gallon pail of water and test it. If it still trips the breaker you will know the problem is in the pump or the cord to the pump.
May 02, 2009 | Beckett Corporation Beckett Professional...
Hitachi EC12 Portable Electric 2hp Air Compressor, Oil Lubricated Logo
240 people viewed this question
Top Hitachi Air Tools & Compressors Experts
John Trevino
Jim Thurston
Are you a Hitachi Air Tool and Compressor Expert? Answer questions, earn points and help others
