Question about Homelite Garden
When pulling startercord there is a clanging noise andthe achain adjuster screw works itself loose
  • 3 more comments
  • brenda_ray May 07, 2010
    model is homelite 33c c with 14 inch chain sorry I am not very mechanical minded but thankyou for your help
  • dontbother10
    dontbother10 May 11, 2010
    Just adding this we can continue Brenda. Did you take off the clutch cover? Was it stuck on the saw? Is the chain outboard or inboard of the clutch drum? Model number not engine or bar size. Stay with me we will get through this.
  • dontbother10
  • dontbother10
    Clutch cover is not properly installed?
  • dontbother10
    Brenda is it possible the chain brake is tripped and the clutch is not properly installed? Please post back below with a model number UT-5Digits.
    President:
  • 2,220 Answers
I added this so we can continue Brenda.
Posted on May 07, 2010
    Brigadier General:
  • 4,088 Answers
Remove the bar and chain--start the engine--do you get the same noise? If so, then remove the entire starter mechanism--look for loose/damaged parts, especially anything related to the components that engage the flywheel/crankshaft when the cord is pulled. Normally, the chain adjuster screw is important only while adjusting the chain--once the bar clamp screws/nuts are tightened, the adjustment screw is tightened so that it won't back off. Hope this helps!
Testimonial: "hello thank you for the imfo. my technical buddy is visiting weds.12/5/ so I shall passon your tips thanking you I hope this cures the problem .Ishall get back to you service has been A.1 fantabulosa ! as we say in souf london"
2011 FLHX 103 H D,I am getting a loud clang when shifting gears,at times 2nd an 5th gears may be much quieter for some reason, when coming to a stop when the clutch is pulled all the way in i hear a hum...
Your diagnosis could be correct though few vehicles these days have an adjustable clutch.
A loud clang isn't a noise commonly associated with clutch problems.
I advise you to take your car to an experienced person who would be happy to provide an almost instant diagnosis - this would be quicker and easier and save me a great deal of writing...
Nov 05, 2017 | Cars & Trucks
The agitator seems loose on my Maytag top loading machine.. model LAT9206BAE it started this after one of my kids overloaded the machine.. works fine but makes a loud clanging noise while washing.. almost...
Use a 1/4 inch nut driver to tighten the set screw to the agitator shaft. It is about 3 inches up from the bottom of the agitator on the side of the agitator.
Dec 28, 2010 | Maytag Washing Machines
Engine clanging funny when started
Noises coming from the inside of an engine are not good. Someone needs to pull the right side engine cover and look at the clutch, crankshaft drive gear and kick gear. It sounds like something has come loose.
Sep 13, 2010 | 2004 Yamaha YZ 125
Clanging noise rear and rear don't pull
The axle probably lost a keeper ring on the inside of the differential and the pieces may be going through the differential and ring&pinion gearing making the noises you hear. You will need to drain the oil out, find the broken pieces, and inspect all gearing for broken/damaged teeth, and for any noisy bearings. Flush the case out with cleaning solvent. Re-insert the loose axle after cleaning and inspecting it well--especially the interior end. Replace the keeper (new) on the axle end inside the differential spider gearing. Inspect the brakes on the loose axle side for any oil deposits and for any damage that might have been caused when the axle came out. If the differential is badly damaged, it might be cheaper to find another rear end in a wrecking yard. Hope this helps!
Dec 26, 2009 | 1997 GMC Suburban
Noise from rear suspension on 2003 Honda Odyssey.
a clunking clanging noise sounds very much like your stabilizer bar end links and bushings. you have a thin rear "sway" bar on the rear of your odyssey. this can cause a whole lot of noise. grab each side and pull/push. if it feals loose, replace the end links and bushings.
Oct 25, 2009 | 2003 Honda Odyssey
My Maytag gas dryer makes a loud rattle and clanging noise.
Prob. some failure of a bracket or loose inside...
Have a local tecnician check it out.
i think that ll be best cause i can't imagine that will be an easy fix.
I hope this is useful, and greets,
Olivier.
Oct 21, 2009 | Maytag Neptune MDG5500AW Gas Dryer
On my 2000 blazer. every time i hit the gas pedal i here a clanging noise, and if i hit the breaks hard i here the same clanging noise. what could this be??
Sounds like something loose is swinging with the stop and go momentum. Look underneath for something loose, like exhaust. Have someone listen close by while you drive it slow in forward and reverse, to try to pin point it.
Jul 31, 2009 | 2000 Chevrolet Blazer
My 2 yr old Kenmore freezer has developed a rattle when the pump turns on, not always and it seems to be keeping cold am I in trouble?
There is probaly a loose screw in the pump. You should get it fixed before it gets worse.
Jul 07, 2009 | Freezers
Front End Noise
Sounds like a bad motor mount.
Sep 11, 2008 | 1997 Ford Escort
Hobart N-50 mixer clangs on 1st and 2nd speed
CE is the marking that shows its european conformant.  I think the difference is mostly in terms of the no volt interlock switch.  This means the KA style N50 bowl won't work with the CE models - too low.
Jun 03, 2008 | Hobart N50 Stand Mixer
Garden Logo
106 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
