Question about Zebra 105SL Thermal Label Printer
Changed the ribbon, but the labels are to light.
What do I need to adjust so the ink on the labels are not to light?
    Scholar:
  • 97 Answers
The DARKNESS setting controls the amount of ink released to the label. The 105 has a range of 1-30, 1 is the lightest - 30 is the darkest. The setting used will depend on the combination of label / ribbon used. There is no "correct" number, always try to use the lowest setting with acceptable print quality.
The DARKNESS can be adjusted from the front panel by pressing SETUP and changing or DARKNESS can be controlled from the software or printer driver. The printer driver or software usually overrides the setting in the printer.
Hope that helps !
Posted on May 07, 2010
Hello, I changed the ribbon. The ribbon and labels
can you adjust the printhead pressure?? if so then do that
Aug 22, 2017 | Zebra ZM400 Thermal Label Printer -...
I am a Reseller and one of my client is having Citizen CLP-7202e. due to the faulty print head we have tried to change the print head and after changing a new print head, printer is not printing...
I have used this type of printer before. Long ago when it was called the C-ITOH. However, never had to change the print head before. I would imagine that if you did - all the adjustments would need changing. Bad Gap would skip labels and bad pressure would make them too light or too dark. If there are any vertical lines (even faint) the print head is damaged. Also, these things are very specific as to media vs ink roller. You cannot use a paper ink roller with mylar labels. Vise versa works but those rolls are more expensive. I am sure you have tested this already but you point pretty exclusively to the "new" print head with your testing. Sounds like you have answered your own question. I would do some continuity tests on the head to see if it carries any current at all. Good Luck!
Jun 14, 2011 | Citizen CLP-7202e Thermal Printer
My prism plus is giving me a indication light that the ink need to be changed. i changed it and it still giving me the same signal
If you call me we can walk though some troubleshooting steps. Make sure that you power down before installing the new ribbon and don't wind the ribbons past the silver leader.
John Norman Max Optical LLC> www.maxoptical.com 610-269-7033
Sep 04, 2010 | Rimage Prism Plus Thermal Label Printer
The Thermal transfer labels are not readable when I print to the Intermec easy coder PM4I. They print too light. I can use the same ribbon and label stock on an Intermec 3400 printer and they print...
You can adjust the darkness level +/- 10. If you adjust it all the way to 10 and it is still too light, there is a print head pressure adjustment screw to the left of the ribbon feed roller.
Aug 19, 2010 | Intermec EasyCoder PM4i Printer
Changed rolls of labels on Zebra GX 420T and now nothing prints
Were the new labels thermal paper? Thermal printers need specially made paper to work right.
May 28, 2010 | Zebra LP 2844 Thermal Printer
Our DEL SOL BARCODE PRINTER won't print..it operates fine but the labels come out blank...any suggestions?
Is this the first time using the printer ? As simple as it sounds, make sure that the ribbon is not on backwards. ribbons have two sides, one with ink, one without. The ink side of course should be facing down to the label stock. If you are not sure which side has ink, just use a label to touch each side. Ink will come up in the adhesive from the ink side.
If the ribbon is on correct, then the next thing to check is the darkness setting usually set from the printer driver or label software. Maybe it's not set high enough for the label / ribbon combination.
Hope that helps !
Apr 23, 2010 | ATSI Holdings Cognitive Del Sol Thermal...
My Z4M Plus printer is not printing the label all the settings are fine no error. The ribbion shows the image but it doesnot print on the Label.
Two possiblities: 1. the darkness is not high enough for the ribbon/label combination. 2. the ribbon is on backwards. if the ribbon is on backwards, you will still see an impression on the ribbon but not on the label. This means all the ink transferred to the printhead which should then be cleaned.
The ink side of the ribbon needs to face down to the label to print so the easiest way to make sure which side has the ink is to use a label or piece of tape and touch it to the ribbon. If no ink comes up in the adhesive then that is the wrong side.
Hope that helps !
Apr 01, 2010 | Zebra Z4Mplus Label Printer
Zebra Z4MPlus not printing dark enough
In your label software there should be a setting option for print darkness (I assume it adjusts the head temperature) In ours (bartender) you can get to it when you select 'print' and a window appears with a 'documents properties' button. Click on this and select options and a darkness bar appears which you can adjust. You may also need to slow the label print speed if the darkness adjustment is not enough. I suspect it isn't in the printers best interest to run the print head at maximum darkness/heat so a sensible balance of darkness and print speed is best.
Another, less likely, possibility is an incompatability between the label material or surface finish, and the ribbon type. We did have a problem once whem Homebase changed their price label design and we had to test a load of other ribbon types until we got one that did the job. A chat with the label or ribbon supplier is always usefull, they sent us several sample bits to test.
Sep 30, 2009 | Zebra Z4Mplus Label Printer
I channged the ribbon and the printer will not print tried several thing but it look like everything goes ok but there is nothing printed on the labels
Check that ribbon is installed correctly. Zebra ribbon only has ink on one side. ink side must be facing label. Use a label to check which side ink is on stick label onto ribbon and peel off.
Jun 14, 2009 | Zebra LP 2844 Thermal Printer
Possible print head failure
to test , press pause botton and turn on (press 5 sec.)
he print a "pause test".
check if print, if stop on ich gap and if come some lines across the print (if apear some lines, need new print head.) this step just pause wen print some labels, and then still print until turn off.
Turn off and turn on the printer to work normal.
To calibrate media, go on the setings to "sensor profile" and/or "run manual calibration, follow the steps. (dont forget to take the ribbon from the sensor.)
let the test run until finish.
May 02, 2008 | Zebra Z4Mplus Label Printer
Zebra 105SL Thermal Label Printer Logo
100 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
