Question about Texas Instruments TI-89 Calculator
My calculator is stuck on an Error. It says Attribute 0x4 of object 0x0 not found. How do I fix it?
Toshiba sattelite A205 s5816 will not boot up. Auto fix failed, restore failed , error could not find path. Results from diagnosis -Error=0x0. root cause found = No OS files found on disk
windows are dead. reinstall the Os. if you have important data - remove the HDD, copy all inportand files, put it back in and then reinstall the system
Mar 09, 2012 | Computers & Internet
Fujitsu fi 5120c e2 error
See page 25 of:
http://193.128.183.41/support/scanner/manuals/fi-5120c_gs_p3pc-1312-01en.pdf
"E2" is "Trouble with the optical system (front)."
That doesn't solve your problem, but at least it narrow downs the focus of your problem.
Dec 05, 2008 | Fujitsu ScanPartner fi-5120C Pass-Through...
An unhandled exception has occured .......
An attempt was made in a program or script to use an object before creating the object. For example:
dim SomeObject as Object
SomeObject.attribute = "string value"
will generate thie error message because the SomeObject that is being referred to has not been created. For this, we need the New keyword:
dim SomeObject as New SomeObject
will run without errors
Nov 19, 2008 | Microsoft Windows XP Home Edition
Printing error
the problem is with the printer. try to examine if the printer head is on the right side. the default must be on the right side. if you can't move the printer head towards the right it means it got stuck up. if you will look inside it you will see a 'rail like' object on the bottom of the printer you can push it down with any pointed object for the pinter head to get back to its original position. if this doesn't solve the problem look for the nearest service center coz the printer needs an alignment.
Aug 10, 2008 | Casio HR-8TMPlus Calculator
Schema classes and attributes
Every directory object you create is an instance of an object class contained in the schema. Each object class contains a list of associated attributes that determine the information the object can contain. Classes and attributes are defined independently, so that a single attribute can be associated with multiple classes. All schema classes and attributes are defined by the classSchema and attributeSchema objects, respectively.
Classes
ClassSchema objects are used to define classes in the schema. A classSchema object provides the template for building directory objects of that class. Examples of classSchema include User and Server. A classSchema object contains, among other things, the following information:
Class type (structural, abstract, or auxiliary)
Common name and Lightweight Directory Access Protocol (LDAP) display name
Lists of the "must contain" and "may contain" attributes for instances of the object
Relative distinguished name attribute
A list of possible parent classes
Class types
Three different types of classes exist in the schema:Class type Purpose
Structural
Used to instantiate objects (users, servers and so on) in the directory.
Abstract
Provides templates for deriving structural classes
Auxiliary
Contains predefined lists of attributes that can be included in structural and abstract classes
Attributes
AttributeSchema objects are used to define attributes in the schema. An attributeSchema object determines the allowable contents and syntax for instances of that attribute in the directory. Examples of attributeSchema include User-Principal-Name and Telex-Number. An attributeSchema object contains, among other things, the following information:•
Common name and LDAP display name
Syntax rules
Data constraints (single versus multivalued, minimum, and maximum values)
Whether and how the attribute is indexed
Jul 17, 2008 | Microsoft Windows Server Standard 2003 for...
Unkown SCSI Problem
Hi Fatoil ,
Have you tried another SCSI port , another SCSI card , another SCSI drive , swopping if it is card problem or drive or both problem ?.
If you have a spare SCSI hd , plug it in to same port and see if it works . Swop to another port and see if the spare SCSI hd works. Swop to another SCSI card and see if spare SCSI hd works.
All this elimination will narrow down the problem .
SCSI cards are not expensive ,.
old working SCSI hds don't cost you anything if you have them.
Sending out the server for servicing will cost you.
I presume you don't have a maintenance contract for this server .
If you have , get them down to settle it .
If you don't , after you settle this matter , make sure you get a maintenance contract for all your critical servers / equipment.
Maint Contracts seem expensive when nothing breaks down. However , when they do , it makes every worry go away.
Good luck,
David
May 26, 2008 | HP CC3310 (a9863a) Server
Error Code 5010
This behavior can occur because the Setup program is attempting to locate the Microsoft Exchange System Objects container, but cannot locate it. This behavior can occur because the objectclass attribute that the Setup program is attempting to locate is msExchSystemObjectsContainer. The Setup program then attempts to create an Exchange System Objects container by using the proper class type. However, the object already exists, and a new one cannot be created
To resolve this behavior, rename the organizational unit to something other than "Microsoft Exchange System Objects". To view the objectclass attribute, either use ADSI Edit or LDP. Note that if this organizational unit has the objectclass of msExchSystemObjectsContainer, this organizational unit cannot be renamed.
WARNING: If you use the ADSI Edit snap-in, the LDP utility, or any other LDAP version 3 client, and you incorrectly modify the attributes of Active Directory objects, you can cause serious problems. These problems may require you to reinstall Microsoft Windows 2000 Server, Microsoft Exchange 2000 Server, or both. Microsoft cannot guarantee that problems that occur if you incorrectly modify Active Directory object attributes can be solved. Modify these attributes at your own risk.
Feb 05, 2008 | Canon Pixma MP450 All-In-One InkJet...
Just bought Zire 31 and won't hot sync Outlook Calendar, Contacts, Notes with the following log:
Generally this error means that HotSync manager (via the 4 Outlook conduits) is having a hard time connecting to your Outlook or, in some cases, specifically to your Oultook profile.
Sep 12, 2005 | Palm Zire 31 Handheld
Texas Instruments TI-89 Calculator Logo
104 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
