My amplifier does not want to send power to the subs
    Novelist:
  • 100 Answers
What kind of application is it and what kind of amplifier is it? Meaning home or car, and a brand and possibly a model number. Thanks
Posted on Mar 27, 2008
SOURCE:
Why would my amplifier turn on but not send anything to my sub-woofer?
Try using a continuity tester turn the amp on as normal play the head unit and see if you get a reading or you can try using a different sub woofer if the problem persists I could be your amplifier then
Oct 07, 2016 | Kicker Car Audio & Video
Soundstream rub1000d is not sending power to my subs
Does it have power indication, e.g. red light, green light
May 25, 2011 | Soundstream CAR AMPLIFIER, 1 CH, 1000 WTS...
With the gain in the middle was runing vibe12" sub in bandpass box it blew the sub in 4 min of using could u please tell me what sub I can use to play loud it has to be 2 x 12" thanks.
There are many sub woofers out there that would be suitable for your amplifier. Just stick to the quality brands such as Elemental Designs, JL Audio, Alpine(type X), MA Audio, RE Audio and there are many more. Make sure the minimum power handling for each sub woofer is 600 WATT RMS. Another thing. The gain control on the amplifier is not a volume. It is there to match the output voltage (V) of your head unit to the input voltage of the amplifier. For example, if your head unit RCA output is (1.2V, 2V, 4V or even 5V) then match that on the amplifiers gain to be the same. The higher the V number is on your head unit, the stronger the signal is that is being sent to the amplifier. For example, If your have a 4V head unit and the gain control on your amplifier is set to 1.2V the you are sending almost 4 times the amount of signal strength to your amplifier. This causes distortion and distortion causes speakers and sub woofers to blow. I hope you understand the concept. IMPORTANT: This is a powerful amplifier, a 4 Gauge or 2 Gauge power cable MUST be used. Less than 4 Gauge, will cause over heating of both the cables and the amplifier. YOU DON'T WANT THAT. If you still have doubts and need more assistance, let me know.
dreamsystems
Feb 13, 2011 | Alpine PDX-M12 Car Amp
I have a rockford fosgate 1001d and 2 audiopipe dvc 12s need 2 know how wire speakers
Check to determine if your sub woofers are DVC 4OHM or DVC 2OHM SOLUTION 1 If your sub woofers are DVC 4OHM then, from the positive (+) of the amplifier run your cable to the positive terminal of voice coil 1 on sub woofer 1 then continue to connect all the positive voice coils together on both sub woofers. Do the same for the negative from amplifier to all the negative voice coils of both the sub woofers. RECAP: all positives together on the positives and all the negatives together on the negatives. This will give you a 1 OHM load to the amplifier making it deliver all its power but will also run hot. So if you are living in a hot climate take care. SOLUTION 2: Connect the negative on voice coil 1 to the positive of voice coil 2 on sub woofer 1 Do the same for subwoofer 2 now you should have a free negative and a free positive on each of the sub woofers. connect the free positives together and follow through to the positive on the amplifier. do the same for the free negatives sending them to the amplifiers negative. This will give you a 4 OHM load to the amplifier. Not full power in this mode but the most stable working condition for your amplifier. SOLUTION 3 If your sub woofers are DVC 2 OHM then you only have one reasonable wiring solution. Connect like solution 2. This time because of the DVC 2 OHM sub woofers you would have a 2 OHM load to the amplifier. This is also a stable load for the amplifier and does not generate to much heat and still deliver over 50% to 70% of the amplifiers power. good luck and drop me a line if you still have doubts. dreamsystems
Feb 10, 2011 | Car Audio & Video
Car amp will not send power to subs?
1-check polarity 2-on in power you have power? 3check fusibile from inside
Apr 05, 2010 | Legacy LA1099 Car Audio Amplifier
Connect stereo amplifier to powered sub
You can y out from the main out to the sub.This output is post volume control. set level on sub to desired balance of lows feq to highs
Nov 20, 2009 | Yamaha YST-SW015 Subwoofer
Amp sends power to sub at low volume. but when volume is increased speaker loses bass and distorts REALLY BAD. Still has power but clear bass disperses. just sounds terrible at even lower volumes
are the sub speakers ok? if ok then u have a problem with the Amp and the output IC's will have to be checked there cud be a problem with the input card in the amp.
Aug 26, 2009 | Jl Audio 500/5 Car Audio Amplifier
Help with CVR 12 (kickers) and a Power 1050 s amp (Rockford Fosgate)
Send me your email account and i will draw you a diagram and send it to you there. I will need to know if the ohms of each sub as well as the amp. I'll also need to know if the subs come with one or two voice coils.
Ciza
Nov 04, 2008 | Rockford Fosgate Power 1050S Car Audio...
Sub not working
The sub pre out is for a small output signal which is to send a signal to a power amplifier which amplifies this signal to a level that will drive the subwoofer. the preamp out signal is not capable of driving a speaker without being amplified.
Aug 17, 2017 | Pioneer VSX-D514 Receiver
Sub size
The sub you want is ONE single 4 ohm voice coil sub that is no higher than 500 watts in power but more than 350 watts. Your amplifier puts out the most power in the bridged state at 4 ohms so this is why you want a single 4 ohm voice coil sub. Also, you don't want to over or under power a sub so you want your sub to match or come close to your rated value of the amp. Good luck
-Andrew Hawkins
Sep 25, 2008 | Sony XM-1252GTR Car Audio Amplifier
 Grubhead
Grubhead
Marvin
Marvin
