Question about Hotpoint WMA64 Front Load Washer
Need to change bearings
How do you remove drum from bearing housing
    Director Badge:
    Uploaded 100 video answers.
  • 213 Answers
Here are a series of free videos to help you with your bearing problems and how to fix them
For all your free videos on appliance repairs remember to mark us down and leave feed back please
For all your parts visit our site http://www.apart4u.co.uk
This first video shows you how to diagnose the problem
The next Hotpoint video is on how to take the drum out
This Hotpoint video will show you how to change the bearings in the drum tub
the last one will show you how to change the spider or drum support as they are known
Posted on May 27, 2010
I have a Honda whipper snipper that needs a bearing that attaches to the clutch /drum assembly.i removed the large circlip at the end of the clutch housing but can`t progress any further, any ideas?john
The bearing you want will be in the end of the shaft housing under the clutch drum. You will need to pull the clutch drum out of the housing so remove the head of the snipper to ensure that there are no retainers on the end of the shaft. Check if there are 2 holes in the housing under the drum . insert a punch and tap the clutch drum and drive shaft out of the bearing. If there are no holes there then there may be holes in the back of the clutch drum in which you will inset the legs of a slide hammer puller and hammer it out of the bearing
Dec 26, 2014 | Honda Cars & Trucks
Motor belt replacement sears dryer
You need to pull the drum forward so the belt can slide off of the back around the bearing housing in the middle. Replace the bearing sleeve in it while you are at it. I would have to see your dryer to see if you remove the front support or can disconnect the bearing housing from the rear. Not hard once you get it. I also usually change the plastic pulleys and stuff while there.
Jan 22, 2012 | Kenmore Dryers
WBVH6240FWW loud bang
that would be the bearing and housing gone on the drum, if you can lift the drum with your fingers at the bottom of the drum in the door hatch even by putting lifting inside then the bearing has gone. the plastic is the drum.housing usually were the bearing housing is. if there is a lot of movement then the bearing has gone. usually the front bearing but you will need to remove the drum and separated the drum to remove the drum then the bearing, rust on clothing is the bearing as its the only part in the drum that is metal.
Jun 27, 2017 | GE WBVH6240F Front Load Washer
I need to know how to remove the bearing from the drum. I have split the outer drum but can't get the shaft out of the back of the outer drum? My washing machine is a Hotpoint WT 960
this just takes a bit of mucle and time.
remove rear pulley and then refit screw (without washer) into shaft. screw the whole way in. then using a lump hammer knock shaft out. may take a good bit of hammerin.
knock bearing out then and also unclog the weep hole in bearing housing.
grease the bearing housing and press in new bearing and seal.
if old shaft damaged ( which prob is if hard to knock out) you will need to replace it.
screws holding shaft to drum usually impossible to undo so drill them out using a 8mm bullet bit.
fit new shaft, put some bearing grease on the bearing seal and re-assemble the drum
Oct 19, 2010 | Hotpoint Washing Machines
Do you have to remove the axels to change the brake shoes on a 94 chev 1 ton?
Yes, the axles have to come out, then the wheel bearings, and finally the drums will come off. Be careful when pulling the drums, pull them straight off the housing, do not allow them to drop on the housing tube, doing so will damage the inner wheel seal. When reassembling the bearings back in the drums just wipe grease on the outside of the bearing, do not pack them with grease. After the drum is back on put a squirt of rear end dope in the hub before putting the axle back in, top up the level in the rear differential, this is where the rear bearings get their lube from.
Apr 06, 2010 | 1994 Chevrolet C3500
I need to replace the bearings on lg wm2277
The metal covering piece is probably the outer seal for the front bearing--you remove both by driving the bearing out with a long metal rod (or a long punch) that reaches all the way through from the back (you have removed the inner drum and end shaft first). Tap fairly gently on the rod with a hammer and move the bearing end to another location after a few taps. The seal should pop out first, with the bearing next. Once out, look for a number on the bearing edge--it should match the replacement. Inspect the surface where the seal mates with the shaft--it should be pit and wear free. If it is not, a local machine shop should be able to repair that surface (and cheaper than a new inner drum assembly). It is essential that this surface be perfect as it keeps water out of the bearing behind it. The seal can be reused if it still fits fairly tightly on the shaft and that it was not damaged during the removal process. Check with a local bearing supply house to get a replacement bearing. The new bearing will have been greased at the factory, but you need to grease the shaft and inner seal lip with waterproof grease before installing the seal. Don't strike the inner part of the new bearing, only along the outer edge when tapping it back into the housing. Same with the seal. The far end bearing will likely be good and not need to be replaced--slowly turn the inside part and feel for any roughness which would indicate the need for replacement. If so, it gets tapped out from the front side in a similar manner as the front removal. Good luck!!
Dec 05, 2009 | LG WM-2277HW Front Load Washer
Washing machine was making a loud banging/tapping niose when the drum was spinning. It doesn't sound too good when turned manually. Is it the bearings and are they easy to fix?
banging may happen due to low load also, as cloths form a ball shape at one place.
otherwise it might be bearing or bearing housing. bearings are very difficult to replace as whole drum need to open. if bearing housing got loose in drum then drum needs replacement, also very costly.
Nov 18, 2009 | Ariston Technologies Washing Machines
Need to know how to change rear wheel bearing in a 95 suburban
jack & support vehicle. remove rear axle cover drain fluid, removeleft rear tire drum/rotor brakes, remove bolt in axle housing that holds the 3/4 inch pin in place pull pin , push left axle shaft inwards and remove c clip from inside axle case,slide out axle shaft,remove seal,remove bearing and install in revers
Jan 16, 2009 | 2003 GMC Sierra
How do you change bearings on a indescit wil133 washing machines
You will have to remove the rear panel and drum pulley to access the drum . shaft and bearing housing.
Then depending on the set up, you will have remove whatever screws there are to remove the bearing housing.
Dec 06, 2008 | Washing Machines
Drum Bearing Replacement
With a plastic tub (outer drum as you describe it) removal of the old bearings can deform or bruise out the plastic housing a little - you will need to check that the new bearings will be really good fit. You may need to use a retaining compound if not, to ensure that the outer journals of the bearings don't creeping round in the plastic housing and wear it looser.
I did my Hoover Electron 800 bearings (metal tub). As i recall it was fairly straightforward - needed a gasket for the tub backplate on that.
Unbolted tub backplate from tub and withdrew it through rear of chassis along with drum/drum-shaft/bearings assembly, removed pulley, tapped shaft through bearings with softfaced mallet (or hammer & wood), drifted bearings out gently, working evenly around circumference.
For plastic tub some kind of suitable extractor may reduce chances of deforming bearing housing during bearing removal, compared to drifting them out. If it'd serve to ease the new ones in too then that'd be even better.
Don't forget to check/clean the water level pressure sensor path while you're at it - stave off any problems in that area for a while while you have the machine apart. ;o)
Dec 29, 2007 | Hoover AL130 Front Load Washer
Hotpoint WMA64 Front Load Washer Logo
568 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
