Question about GE Security Simon 3 Wireless Home Security System
Simon3 entry & exit delay wont work.
I have entry & exit delay #10 #11 set to 222 and #28 off #69 off and when i arm by key pad or fob and open door the alarm goes off.
    New Friend:
  • 74 Answers
It sounds like the door you are working with is progammed as a type 13 (perimeter) rather than a type 10 (entry exit)
Alarmprofessor.com
Posted on Sep 05, 2010
Locked keys in 1999 lincoln town car executive and no keyless entry. can I gain entrance without an expensive locksmith?
Hello Jennifer Jackson...
No... even LINCOLN windows are harder to break
(sorry... your LINCOLN is pretty secure).
Worse... the best price I've paid to get a double sided
PATS (passive anti-theft system) key cut = $6.
Bring your own key... But this was all about the price of PREVENTING your current situation... (oops).
If your ONLY key is truly "inside"...
Your goose is pretty much cooked... The cost of
the LOCKSMITH is pretty trivial compared to your
alternatives... Dealers will zing you MUCH BETTER
than your "expensive locksmith"...
But what ever you do... (my recommendation)... Since
you prefer not to be prepared... (no door code or FOB)
Don't pass on the opportunity to have that same SMITHY
at least tell you about your door code POSSIBILITIES
or at least program a remote FOB for you ...
A RESPONSIBLE "expensive locksmith" will
explain the WISDOM of NEVER having less than 2 (TWO) transponder keys. (by reading your owners manual you can program the FOBs yourself (FREE).
How do you manage the "no" keyless entry...?
I remain pretty sure the number pad... & KEY FOB
(wireless transmitter) were standard equipment...
2 SPARE keys minimum... ALWAYS.
SEALED Strattec Ford Mercury Lincoln PATS Transponder Chip Key UNCUT H72...
NEW FORD KEYLESS ENTRY CAR REMOTE FOB PAIR amp TWO UNCUT TRANSPONDER KEY...
1998 1999 2000 2001 2002 2003 Lincoln Town Car FOB Remote Transponder Car...
Carnac the Magnificent
Jan 06, 2017 | 1999 Lincoln Town Car
How do I reset the anti theft system on my Suzuki XL7? A new battery was installed and messed my system up
which one.
radio antitheft
car doors. (alarms) Content Theft Deterrent (CTD)
or immobilizer.
say what messed up means.?
the CDC system must be armed with the fob.
is that failing? I can not arm the system or it will not disarm. on my command?
my guess is arming. fails
  1. Turn OFF the ignition.
  2. Exit the vehicle.
  3. Important: The system is not armed if the doors are locked manually. The keyless entry transmitter or the door lock switch must be used to arm the CTD system.
  4. With a vehicle door open, lock the doors by pressing the LOCK button on the keyless entry transmitter or by pressing the LOCK button on the door lock switch. The system will begin the arm sequence when all doors are closed. The CTD system transition to the arm delay state when the final door is closed. The security indicator will illuminate steady when in the arm delay state.
    If the keyless entry transmitter LOCK button is pressed after the vehicle doors have been closed, the system will transition directly to the arm delay state with the indicator on steady.
  5. The system will arm approximately 30 seconds from the time that the system has entered the arm delay state. When the security indicator transitions to flashing slowly, the system is armed.
    Alternately, if the LOCK button on the keyless entry transmitter is pressed a second time, the system will arm immediately, bypassing the 30 second delay.
if this fails try the Second fob.
if the 2nd fob fails, then pull the battery neg lug, for 5 minutes
and put it back.
the full system rules are in the book called, FSM
seen here, read it for who to diagnosis this problem if it continues
just 4 bucks to read all facts
https://suzukipitstopplus.com/Products/10182-2007-xl7-service-manual.aspx
the book also tells you all things messed up with battery pulls.
good luck.
Oct 24, 2014 | 2007 Suzuki XL7 AWD
Can the Simon xt be programed so that when you enter the stay mode there is not exit delay beeps?
There is always the exit delay, however, you can arm it silently and with no entry delay. To arm silently, press Door and windows, press silent.
To arm without entry delay, press doors and windows twice. Press silent if also wanting no beeps.
Nov 04, 2012 | GE Security Simon 3 Wireless Home Security...
I just bought a 2003 road king classic and can not set the alarm. Can you tell the procedure?
Arming: Hold Fob button down until signals flash twice. The 'key' lamp on
the speedo will Blink to indicate the system is armed. If auto arming is
enabled, the key lamp will Stay continuously lit for 30 seconds after the ignition is turned off, then the system Will arm itself.
Disarming: 'Double-click' the Fob, the signals will flash once and the key lamp will stop flashing. If the Fob is lost or not working, the system can be disabled by entering the passcode. Without setting off the alarm, get the ignition switch to accessory, hold down both left and Right signal switches until the key lamp flashes rapidly, enter the first digit on the left And use the right as an 'enter' key, enter all five digits of the passcode and the system will Disarm, if you screw up, the alarm will activate and you will have to wait ten minutes.
Transport Mode: Allows the system to be armed with the motion sensors disabled for service, Trailering, etc. Turn the ignition switch on, arm with the Fob, turn the ignition off and Arm once again with the Fob. Signals will flash 3 times to confirm
arming, All other functions of the alarm system require entering the configuration mode. This is done by Disarming the system, run/stop switch in stop, flip the ignition switch on/off/on/off/on Then push the left signal button
twice. If power was disturbed to the alarm module, The sequence may have to be repeated to get into configuration mode. The system will respond by flashing out the module type code.
(1-TSM, 2-TSSM dom, 3-TSSM hdi)
Now that you are in the config mode, you can do the following.....
- To assign the Fobs, push the right once (one flash) then the left once (two flashes)
Then hold down the Fob button until the system recognizes it. Hold down the second
Fob until the system recognizes it. Both Fobs must be assigned at the same time.
- To assign a passcode, use the fob to send a disarm command, signal will flash once
To indicate the first digit, push the left signal button and the key light will flash out the Value of the first digit. Pushing the left button will advance the value up through 9 and Will start over at 1. When done setting the first digit, double click the fob again and The signals will flash twice to indicate the second digit, continue on through all five digits. Turn ignition off to exit.
- To adjust the sensitivity, use the fob to send an arm command (one flash) then push the Left signal button once. The signals will flash out the current setting, 1-4, push the left Button to advance the setting, turn ignition off to exit.
- To extract system trouble codes, press the right signal button three times,
pausing between Each press for the system to flash once, twice, and three times
respectively. Press the left signal button once and they signals will flash out two digit
codes. Press and hold the left button to clear all codes from memory, otherwise
turn ign off to exit.
- To enable auto arming, use the fob to arm the system twice, and press the
left button once. The system will flash the setting code, 1-disabled, 2-enabled. Press the left button to change The setting, turn ignition off to exit.
- To adjust between Sidecar mode and normal mode, push the right button
twice quickly, Then the left button once and the signal will flash out the current setting, 1-normal, 2-sidecar. Press the left button to change the setting, then turn the
- To adjust the length of time delay before going into storage mode, use the fob to send an Arm command three times, then push the left button, the signal will flash out the current setting. 1-30 days, 2-60 days, 3-90 days, 4-disabled. Use the left
button to advance the setting and turn the ignition off to exit.
Aug 31, 2011 | 2003 Harley Davidson FLHRCI Road King...
Is it possible to program a new keyless entry fob for a 2002 Suzuki Grand Vitara?
try this...
1. Make sure vehicle is in Park
2. Press Vehicle Information button (has the icon of a car and an 'i')until 'PRESS *check mark* TO RELEARN REMOTE KEY' displays.
3. Press set/reset button. The message 'REMOTE KEY LEARNING ACTIVE' will display.
4. Press and hold the lock and unlock buttons on the transmitter at the same time for about 15 seconds. A beep will sound indicating that the transmitter is matched.
5. To match additional transmitters at this time, repeat Step 3. Each vehicle can have a maximum of four transmitters matched to it.
6. To exit the program mode, you must cycle the key to LOCK.
If that doesnt work, go to: http://www.bing.com/search?q=how+to+program+a+keyless+entry+fob+for+a+2002+Suzuki+Grand+Vitara&go=&form=QBLH&qs=n&sk=
Jan 06, 2011 | Suzuki Grand Vitara Cars & Trucks
Need to make entry time longer . I am able to delete option 10 but can't add option 10. Entry is only 5 sec.
Here is instructions from Installation Manual. I am also attaching links to full Installation as well as User Manuals for your reference at the bottom of page. Make certain to input as 3 digit time - example 45 seconds as 045. Good luck!
Option 10: Entry Delay (Default = 030 sec.)
Determines how much time the user has to disarm the system
after entering the armed premises through a designated delay
door, before an alarm occurs. Beeps sound during the entire
delay time to remind the user to disarm the system.
When turned on, the Entry Delay can be set from 005-254
seconds (030-254 if SIA Limits Option 69 is on). All entries
must be 3 digits. When turned off, the Entry Delay is set to
005 seconds.
Note
For UL listed systems, the entry delay must not exceed 45 seconds.
 To set Entry Delay, press:
1. Add
2. Option #
3. 10
4. Use the numbered keys to enter the 3-digit delay
time.
5. DONE
 To turn off Entry Delay, press:
1. Delete
2. Option #
3. 10
4. DONE
Installation - http://www.homesecuritystore.com/downloadmanual.aspx?mnl_id=334&prod_id=171
Users: http://www.safemart.com/manuals/simon3.pdf
Oct 02, 2010 | GE Security Simon 3 Wireless Home Security...
Have ADT 3000 series alarm system - would like to set it to max
adt sw3000 panel does not support max button on key pad. best solution would be to have ADT tech reprogram Zones so windows are perimeter zones(instant when armed away or stay) and motions interior follower (instant when no perimeter zone was triggered first). doors stay exit/entry.
Feb 25, 2010 | GE Security Simon 3 Wireless Home Security...
How to program key fob. I have the fobs.
Transmitter Programming Procedure
Close all the vehicle doors.
Insert the ignition key into the ignition lock cylinder.
Press and hold the door unlock switch.
While holding the door lock switch in the unlock position, cycle the ignition ON, OFF, ON, OFF.
Release the door unlock switch. The doors will lock and unlock to confirm the program mode.
Press and hold the LOCK button and the UNLOCK button simultaneously on the transmitter. After a delay of approximately 15 seconds, the doors will lock and unlock to confirm the programming of the transmitter.
Turn the ignition switch to the RUN position in order to exit the keyless entry transmitter mode.
Operate the transmitter functions in order to verify correct system operation.
Good luck
Jun 25, 2009 | 2002 Chevrolet Tahoe
Key fob and keypad do not work
check fuse 39, 10 amp red color first. panel is on dash by dirver knees.
May 04, 2009 | 1997 Lincoln Continental
Program fob
Instructions to program a keyless entry remote for a Chevy Silverado. They also work on 2003, 2004 and 2006 Suburbans.
  1. Close all the vehicle doors.
  2. Insert the ignition key into the ignition lock cylinder.
  3. Press and hold the DOOR unlock switch.
  4. While holding the DOOR lock switch in the unlock position, cycle the ignition ON, OFF, ON, OFF.
  5. Release the DOOR unlock switch. The doors will lock and unlock to confirm the program mode.
  6. Press and hold the LOCK button and the UNLOCK button simultaneously on one keyless remote. After a delay of approximately 15 seconds, the doors will lock and unlock to confirm the programming of that transmitter.
  7. Repeat the previous step to program up to four transmitters.
  8. Turn the ignition switch to the RUN (one more click forward) position in order to exit the keyless entry transmitter mode.
  9. Operate the transmitter functions in order to verify correct system operation
Apr 19, 2009 | 1999 Chevrolet Silverado 1500
GE Security Simon 3 Wireless Home Security System Logo
350 people viewed this question
Top GE Home Security Experts
Sean
Jim Goldsmith
Jim Goldsmith
Grantec 2000
Level 1 Expert
Are you a GE Home Security Expert? Answer questions, earn points and help others
