Question about Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
Drips from bottom of Inskerator Badger 5
My insinkerator Badger 5 is leaking from the bottom. Doesnt matter if running, when the sink or dishwasher is is use water drips out of all spots on the bottom And no, after a careful check it is not leaking from any "higher" seals or flanges. The unit is completely dry along its sides at top. However, there is a persistent drip from each the small openings in the bottom of the unit. Thank you for your help.
  • Ace Hardware Master
  • 43,501 Answers
Obviously you didn't like what I answered you before, but if that is not the case and the leak is infact coming out of the bottom of the disposal then you are really not going to like the bad news I have for you now...
I had to remove a disposal today to fix a sink that is exactly like yours, so I took a close look at it an the bottom line is that if you are getting water out of the motor then you have a seal leaking where the motor shaft goes into the grinder part.
From what I can see on from this exploded diagram that is not even repairable and the part you would need is not available.....
So... it looks like you need to look for a new one... or check to see if you have had it less then two years...they do have a two in home warranty...
sorry I can't give you better news...
heatman101
Posted on May 08, 2010
Insinkerator badger 1 leaking from the bottom
check to be sure water is not leaking down the side from d/w drain or sink drain if not look inside with flashlight to check for rust if rusted trough time for a new one
Aug 10, 2015 | In-Sink-Erator InSinkErator Badger 1, 1/3...
Insinkerator leaking from bottom
Any leak from bottom part of disposal means replacement.
Copy following link for specific troubleshoot, and replacement steps with tips.
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
Nov 05, 2012 | Badger 5 Insinkerator 76037h 1/2 Hp Feed...
Why is insinkerator badger plus 5 leaking from the bottom?
Check hose and connection from the dishwasher to the unit. Look for cracks and proper installation.
Apr 22, 2012 | Electrical Supplies
My badger 5 disposal is leaking from the side whats wrong
Check where leak is coming from.
1) Run water until leak starts. Use dry paper towel near top of disposal to see if sink strainer is leaking.
2) Move paper towel down and check where dishwasher connects to disposal.
3) Move paper towel down to tubular drain tailpiece.
4) Water should run down side of disposal if sink strainer, dishwasher connection or tailpiece are leaking. You can fix these problems using tips below.
5) If disposal is rusted out, then water will leak out of bottom or side of disposal body.
There are no repairs or repair parts for disposals.
I wrote EZ installation tips for garbage disposal from when I worked apartment maintenance that will save time and sometimes money:
http://www.fixya.com/support/r7929008-replace_garbage_disposal
Feb 19, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Badger 5 is leaking from bottom of unit... is this repairable? Thanks Chad
If it is leaking from the bottom and not from the top and running down the side then it is only repaiable by replacing the disposal, If it the top leaking and running down the side, then it can be rpaired by replacing the rubber gasket on the top.
Nov 29, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Water has begin to spray/leak when using the
Here is a tip that I wrote about how and where a garbage disposal will leak and what can be done to fix it.
Garbage Disposal Leak from bottom of motor
heatman101
g
May 15, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
My insinkerator Badger 5 is leaking from the bottom. It runs, but water runs out of all spots on the bottom; including the ara where the conduit runs into the unit - please help!
My bet is that the garbage disposal in not what is leaking... the connection to the bottom of the sink is leaking and running down the sides of the disposer...
Look higher and you will find your leak..
How is the best way to use a Garbage Disposal
http://www.fixya.com/support/r4062792-best_way_use_garbage_disposal
heatman101
May 04, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Water leaking from bottom of Badger 5 Plus
There is a metal ring on the 'top' of the disposal. It's underneath the sink, on the top. Put a screw driver in and turn it (CW) to tighten it and it will quit leaking.
Aug 03, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Water leaks from two locations on my Badger 5, 1/2 hp disposal
These holes are probably due to wear, as they are at about the level of the cutter. In general, residential disposals are not repairable and once they begin to leak, they must be replaced. The Badger series is Insinkerator's budget line and probably has about a 5 year lifespan with normal use.
Dec 20, 2008 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
889 people viewed this question
Top Ace Hardware Electrical Supplies Experts
handygirl911
handygirl911
Mike
Treefrog15
Treefrog15
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
