Question about Fedders R6DH45X Dehumidifier
Is there parts to make the unit self draining
    Problem Solver:
  • 12 Answers
My unit originally came with a separate plastic adapter for a garden hose, and there is a circular knock-out on the back where the hose would exit the unit. Not sure if this will help or not, but it appears as if the part was available - but is now discontinued: http://www.repairclinic.com/Fedders-Dehumidifier-Parts?s=t-R6DH45X-%3d%3db168a14c245
Posted on Jun 08, 2010
  • dadr Jun 08, 2010
    Not sure that this one will fit your machine, but it might:http://www.appliancefactoryparts.com/sea...
  • 24 Answers
Is there a rubber plug in the right hand mid back pannel ? if so you probably have a unit that can have a drain installed . If you look in the hole you will see a white plastic tube near the front of the unit . You can access it from where the tank slides in . it just needs a short hose and a garden hose adapter .
Posted on May 10, 2010
I have a keystone 70b dehumidifier. the hose is attached but won't continuous drain. The bucket keeps filling. When I take the hose off, water comes out so I know there isn't a plug that needs to be...
1st make sure the unit is level , sometimes we forget that it needs to be perfectly level to drain out
2nd this also might be a case where unit runs so long and for so long that it never rests, this might sound funny but its not most units need a cool down period where the internal parts cools off and the fluids run out only when the fan inside shuts off , the humidistat should be set at 70% Rh this should allow a bit of a rest period if not you unit is too small for the task you gave it
Oct 26, 2014 | Dehumidifiers
What part do we need to connect this unit to a drain ? Is it available ? ****** #404TA003818
Not well up on the unit, but most just require a pipe to be pushed on, have a look round back, might have a drain plug that you will need to remove, and connect a pipe to.
Aug 13, 2014 | Dehumidifiers
Haier CPN12XH9 Portlable Air Conditioner/Heater - The upper water plug (which I can't find a picture of on any manual) accumulates water while the lower tank (where water should be) is dry. Unit is only...
Not up on the unit, but water condenses on the evaporator of an a/c unit dropping onto a tray, as self evaporating, would assume that the drain from that tray is fed to the top of the compresor, which will have a tray around the top, heat from the compressor will evaporate the water, same as with a fridge. In dehumidifier mode, water would need to be collected, rather than evaporated back into the atmosphere, defeats the object other wise. so is lower tank around compressor? that would be for a/c mode upper tank for dehumidifier
Aug 05, 2014 | Haier CPN12XH9 12,000 btu Portable AC Air...
What is the part/how to find replacement discharge tube for DH400P? I lost the original hose because, initially, I was able to just drain into floor drain. Now, new location, I need to use the pump feature...
Try explaining what you need to an appliance parts supplier or find a current model DeLonghi dehumidifier and identify to a salesperson what you need.
Jun 12, 2014 | Dehumidifiers
I need a part(s) which allows the water from the dehumidifier to drain into a hose which goes to a basement drain. What are the names of the parts and where can I order them?
Not knowing which brand and model number dehumidifier you have, makes telling you what parts you need difficult at best. Most dehumidifiers only require a garden hose section, no longer than 5 feet, that connects to rear of the unit. The connection will be a threaded male connection. It is plastic, so don't over tighten it and crack it. It will have a screw off cap, which must be removed to connect the hose.
Keep in mind, most dehumidifiers rely solely on gravity to drain the water thru a hose. So, the hose should slope down from the unit and straight over to the floor drain.
If the above didn't help you, get back to me with the brand and model number of your dehumidifier.
Thanks for choosing FixYa
Aug 14, 2011 | Dehumidifiers
"Check drain" light is on
If the float switch is indicating a full drain pan, the light will be on and the compressor and fan will not run. Make sure the dehumidifier is installed level and the condensate drain is open allowing the drain pan to empty. Next check that the float is free to move up and down and the switch operates a required. Call the manufacturer at 1-800-533-7533 for parts and instructions if there is a problem wirh the float switch.
Aug 06, 2011 | Therma-Stor Santa Fe Compact Dehumidifier...
The dehumidifier drain hose does not drain when a hose is connected properly and is set at ``Continous Run``.The light on Continous setting is orange,is this normal? Raymond Benoit
http://www.searspartsdirect.com/partsdirect/part-number/Whirlpool-Parts/Dehumidifier-Parts/1172075/0042/106/Model-AD25BBK0/1198/0907000?keySuffixId=NA&productTypeId=x&searchModelNumber=AD25BBK0&subCompDesc=Cabinet&brandDesc=WHIRLPOOL&modelDesc=DEHUMIDIFIER&blt=11
I would suspect the float first, IF the unit is level. But it could also be blocked with gunk and you will need to check the drain holes. I have always found a guitar string is an affective clean out of drain lines and holes.
The orange light indicates that your bucket is full, so if it isn't then it is most likely the float above.
Jun 19, 2011 | Whirlpool AD25BBK Dehumidifier
Unit runs but does not collect water. If I shake unit water will drain into bucket from coil. I pushed a plastic trigger sprayer pickup tube into drain tube and some water came out. I felt some kind of...
Use an 18" long plastic Zip Tie that will fit into the drain tube and carefully slide it in. The tricky part will be when you reach the curve in the drain tube. So be careful, but persistent. Once it has gone as far as it can, slowly pull it out while rotating it. This will help to dislodge the clog. Be prepared for water to follow. This should solve your problem.
Mar 29, 2011 | Haier DM30EAL Dehumidifier
Self drain is not working. I have to empty the
Assume you have a line to drain, line is probably clogged with sediment/lint from drain tray where it connects there. try blowing or backflushing the line at the drain end.
Dec 31, 2009 | Frigidaire Dehumidifiers
How do I connect a drain hose to the maytag M7DH65B2A Dehumidifier, so that It will drain it's self while I'm on holidays
Connect the correct size tubing to the 90 degree drain on the left side of the unit(above water tray) and knock out plastic cutout on the rear of dehumidifier. Feed into drain.
Sep 03, 2009 | Maytag M7DH65B2A Dehumidifier
Fedders R6DH45X Dehumidifier Logo
244 people viewed this question
Top Fedders Dehumidifiers Experts
Bill Long
jasbo
jasbo
Steve
Are you a Fedders Dehumidifier Expert? Answer questions, earn points and help others
