Sounds like be compressor is on but the fan is not on in auto ot manual
  • 38 Answers
Check the circuit board
Posted on May 07, 2010
My GE GSL 25JFPABS Refrigerator failed yesterday. No Comressor no evap or condensor fan
Fan motor starts with the compressor. Sounds like you need a main board and condenser fan motor. Call GE. It might be covered under warranty. A known issue with certain models. You will also need serial # if you call.
Mar 23, 2017 | GE Refrigerators
Central air unit, outside unit fan runs, but not cooling. Compressor seems to turn on/off continously. Buzzing sound interminately.
Sounds as though the contactors are not pulling in tight. shut down the poer to the unit and check the contactor. you will find them behind a panel door on the outside unit.. BE CERTIAN that you have disconnect the power ot the unit . the contactors will have wires running to the compressor. you might not be able to see the pints on the contators. but you can remove the cover and take a look. you can ppush them in and let them move back a forth a bit . put it back toghter and turn it on. If you still hear the noise you will have to repalce the contactors . also the same applies for th outdoor fan as well. Good luck and let me know.. I really hope this helps Jon
Jul 24, 2011 | Ruud Heating & Cooling
I noticed some straining noise coming from my a/c unit today. The fan on top of the condenser runs fine but as soon as the compressor tries to kick on the fan stops for a split second and you get a kind of...
You amy ahave a bvad capacitor on the outside unit. It starts the fan and the compressor. You can change this yourself. Open the outside panel and you will see a silver canister with terminals out the top. Replace this and I think your problem will go away. On the cap. it will say something like 30uf 5uf 370 ot 440 Just get these numbers and get a new one. Russ
Aug 14, 2009 | Goodman CKL24AR24 Air Conditioner
Duro-therm rv roof a/c..model 57915.331...compressor coming on..fan not running..after a couple min. breaker trips....fan will not run on manual or auto...help,blackie williamson
Either your fan is stuck due to age or grime or is shot
if the fan does not provide cooling then the unit goes into thermal protection mode and shuts down
Jun 09, 2009 | Dometic Rooftop RV Air Conditioner
Buzzing noise from compressor start relay
sounds like your compressor is going bad, getting to hot , pull the unit from the wall and cleanall vents under and behind rear cover, make sure fan is running ot cool of the compressor, youll have 5 yr coverage on your compressor if needing repaired
Nov 11, 2008 | Jenn-Air JCD2295HES Side by Side...
Ptac fan keeps blowing
Try setting the fan control to "AUTO" this will cause it to cut out with the compressor.
May 02, 2007 | Amana PTH123B25AJ Heat Pump Air...
Heating & Cooling Logo
15 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
