Washing Machines Logo
Posted on May 07, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to replace lid switch kenmore 110 22922 washing machine
Kenmore 90 series model 110 22922 100 washing machine how do you open the top to get to the lid switch?
Anonymous
Level 3:
President:
  • Master 1,937 Answers
  • Posted on May 07, 2010
Anonymous
Master
Level 3:
President:
Answers
1937
Questions
0
Helped
430216
Points
5400
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Look at the section on the cabinet.
Then see the following for how to release the console and pull the cabinet.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=9b19162f839199d33f88dac696ac636c
My kenmore 90 series washer will not drain i have tried playing with the lid leaver any thing else i can do ,can i replace the leaver switch?
Yes you can replace the lid switch its fairly easy to do...this tip i wrote will help ya to replace the lid switch http://www.fixya.com/support/r9939128-whirlpool_kenmore_estate_kitchen_aid
Series 90 is unfortunitly not a model number please reply with exact model number as found on a label on the rim of the tub inside of the lid and i will give you the part number for the lid switch.
GENE
I have Kenmore 90 series washer its lid switch is not working I want to replace my self how I can fix it model # 110 20922991
remove the top control panel,there are 2 brass colored clips that hold the cabinet on,remove these clips and tilt the cabinet forward to remove it,then you can replace the lid switch
How do I replace lid switch in a Sears Kenmore 80 series, model 1
The following link explains step-by-step how to replace a lid switch on a Kenmore top loader:
http://www.fixya.com/support/r3557193-replacing_a_lid_switch
If you have any questions about this repair, please post back and let me know. I hope this helps you.
NOTE: Kenmore is manufactured by Whirlpool so these instructions will apply.
1helpful
I HAVE A KENMORE 90 SERIES WASHER JUST REPLACED
it mounts to the metal where the lid closes, not on the drum... there's usually two holes where the screws go through... and a third hole where the actuator(plastic post) on the lid goes through to activate the lid switch...
Kenmore series 90 washing machine will not spin or drain
I hate to say it, but your friend is probably wrong on this one. A bad pump would not affect a washer's ability to spin. It would only affect the drain function. If the washer fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain, this is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price.
If you have questions, please let me know. I hope this helps you.
Kenmore 90 Series Washer
CHANGE THE LID SWITCH
My Kenmore Washer Model 100, 90 series fills and agitates but
most common solution is to replace the lid switch. (the machine thinks the lid is still open)
15helpful
2answers
You have a broken lid switch. Its # ll in the diagram. Part # is 3949238. Let me know if you need info on how to replace it, Dave www.washermd.com
3helpful
3answers
My washing machine water wont drain,it is a kenmore 90 series.
  • first thing to check is the lid switch.
  • if the lid switch is bad it will fill up, then agitate then sit there full of water.
Alexander
vince
