Question about Pentair White/Gray Legend Platinum Automatic Pool Cleaner - Ll105pm
My wheels wont move
The wheels on my legend pool cleaner will not spin
  • 640 Answers
Check to make sure that you do not have a blocked impeller. I would also check to make sure that you dont have something stuck in your drive train. The only other thing that could cause an issue with these pool cleaners is if you are not getting sufficient water flow.
Posted on Sep 30, 2010
Platinum Legend keeps moving to the left
take cover off make sure both sides of the drive wheels are evenly tightened also notice the inside of the wheel is a gear if defective you can switch fronts with backs
May 09, 2014 | Pentair White/Gray Legend Platinum...
Legend pool cleaner rides on back wheels
make sure the hose floats are correctly placed and the tail float does not have a leak
Apr 21, 2013 | Pentair White/Gray Legend Platinum...
Letro legend front wheel drive wheels no moving
take top off and adjust front wheels closer to gear but not too tight
Jan 17, 2013 | Pentair White/Gray Legend Platinum...
I need a manual on how to install and repair letro pool cleaner
pool distributor or amazon pool section remove bottom 4 screws see if hoses came off or belts if tires worn switch with backs front only drive if not moving adjust wheels to touch gears
Aug 17, 2012 | Pentair White/Gray Legend Platinum...
Front wheel gear not engaging
move wheels out to meet gear if gears stripped switch wheels from front to back
May 05, 2012 | Pentair White/Gray Legend Platinum...
The cleaner stands on front wheels and barely moves.
With these pool cleaners, there are several things you will want to try. Check the filter screen in the in line filter and the skimmer basket, pump basket, and pool filter. Clean any if necessary. Make sure that all hoses, connections, and swivels for leaks that could cause loss of water pressure. Make sure that your wheel RPM is correct. Make sure that your thrust jets are positioned correctly and that you have proper waterflow.
Oct 01, 2010 | Pentair White/Gray Legend Platinum...
I just moved into a house with a pool and i hook up the legend and it doesn't crawl
If these pool cleaners are moving, there are several suggestions in the users manual. I have attached a copy below in case you didn't get one when you took the pool over. Basically, make sure that your filter ,booster pump, and wall fitting screen are all clean and working properly, check wheel RPM and get it to 28-32 RPM, make sure that your backup valve is cycling, and check all of your hoses and connections for leaks or cracks that would allow air into the line.
http://www.poolcenter.com/Platinum_Manual.pdf
Jun 15, 2010 | Pentair White/Gray Legend Platinum...
Pentair legend 4 wheel cleaner - runs over its hose
check the white float on the cleaner. take it off and shake it, if it is full of water you will need to replace it. when they get water in them they make the cleaner heavy and it will tip of on its side.
Dec 20, 2009 | Pentair White/Gray Legend Platinum...
Legend pool cleaner wheels not moving
You might want to pull the drive wheels and see if their might be a small pebel stuck in the drive gears on the wheel.
Oct 04, 2009 | Pentair White/Gray Legend Platinum...
Pentair White/Gray Legend Platinum Automatic Pool Cleaner - Ll105pm Logo
222 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
