Question about Haier hwr10xc6 Air Conditioner
Blowing water it is blowing water when i turn it on
  • Haier Master
  • 43,501 Answers
Window Air conditioners need to tip back just a bit in the window...if they are flat or tipped front you will have the water problem...
Here also is a tip that will help you to keep you Air Conditioner running well...
Window Air Conditioners - Clean them every year
http://www.fixya.com/support/r3623253-window_air_conditioners_clean_every_year
heatman101
Posted on May 07, 2010
Had the same problem last year. Took the unit out side and washed it down making sure I covered the electrical panel. It was full of leaves that drifted into the vents. I let it dry for a couple of hours and put it back in the case. Worked great. Now I clean once a year.
Posted on Jun 07, 2010
Toro lawn sprinkler system, shut water off went to winterize system hooked compressor to blow out plug turned on first zone, water blew out everything good, went to blow out 4 other zones and nothing
I may suggest your distributor was set to the first zone.
Therefore, neither water nor compressed air will "flow" in any zone except that one.
See if turning on the electric and setting a different zone will accomplish your desired result.
God bless your efforts.
Nov 11, 2016 | Garden
Why is my heat or air is not blowing and car is running hot
How hot is the engine running in degrees f? Does the radiator fan run?
With hvac turned on, check voltage and ground at the blower motor. If good voltage and ground, suspect the blower motor is faulty.
Jan 02, 2016 | 1992 Saturn SL
Why does my 2002 clk320 keeps blowing turn signal fuse ?
could be a loose wire or water/moisture in the light front or back and the fuse blows when +/- connect from water
Aug 23, 2014 | 2003 Mercedes-Benz CLK
How can I stop my air condition from blowing out water whenever I turn it on?
Check the outlet where water naturally drains out of the unit, because AC, if working properly, produces water as waste that it takes from the air. Sometimes these things get blocked and also remove and clean the filter if there is one.
Aug 22, 2014 | Heating & Cooling
Blows fuse when I turn it on
try disconnecting cord to the unit that goes into pool check to see if water in plug if so dry out if no water try turning on without being connected if it still blows fuse bad control unit or water inside
Oct 09, 2013 | Maytronics Dolphin Dynamic Dolphin Dynamic...
Washer runs but the water does not turn off, THe waterm hot and cold just run until I cut it off manually.
while machine is filling turn of power if the water is still entering machine you have a mechanical fault water valve hot or cold needs replacing if water stops when power turned of you ave an electrical or control problem check water level hose from tub to level switch for damage or perishing if ok check water level switch blow into it see if it clicks if not replace also while blowing hold pressure to see if the diaphragm in the pressure switch is not perished keep me informed
Nov 05, 2009 | Washing Machines
My mastercool blows out hot air upstairs
The one on top probably has no water in it or the pump is not working. Look closely at the front to ascertain if water is being pumped.If not turn electric off and remove one of the side panels with a 1/4 driver. In the reservior there should be water. If not you need to turn water on to unit or adjust/replace float. Also is it's warmer than 100 degrees outside you're unit might be fine...it has limitations.
Jul 09, 2009 | Mastercool 67471 Evaporative Cooler Air...
Fuses keep blowing out
IF water is not going in the drum It sounds like the water valve coil has finally failled , It has been blowing fuses ,because the ccoil on the water valve was getting weak . change this water valve and you sohould be ok , but before doing so chaeck to see if you have the proper voltage going to this valve when It is calling to open ,if the power is there and the water is turned on the valve should be letting water in the machine . you can also take a ohm meater and check the valve for proper resistance . . If the machine is up in years I would change this valve . from the chack I mentioned earlier . hope this helps you
Nov 03, 2008 | Maytag Atlantis MAV6451 Top Load Washer
No water
Try to blow thu the other end and see if you have something blocking it..should bo able to blow air thu if nothing blocking it... If you cant blow thu.. get some thin wire and try to find the blockage
Sep 01, 2007 | Hotpoint HSS25GFP Side by Side...
Haier hwr10xc6 Air Conditioner Logo
749 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
