Question about Motorola Mobility MOTOKRZR K1 Cellular Phone
Problem in connecting
I am not able to connect my phone to laptop. So from where can I get pc suite for this phone so that I can connect my phone
USB Driver
Posted on Mar 29, 2008
Usb connection settings
No setting required. Install Nokia pc suite in your pc/laptop and Just connect your phone using usb cable to pc or laptop and wait 5-10 minutes it will install all required setting automatically. Then u can see your phone connected in PC Suite application.
Jan 28, 2014 | Nokia 5230 Cell Phone
I have a Nokia 6700. How do I download a PC Suite for this phone?
Possible there are errors in the PC and so the phone is not recognised. You can transfer the pictures by removing the micro sd card and inserting on a card adapter to be directly read on the card reader on the laptop. If this is not possible you can activate bluetooth on the phone and laptop and get the files transferred easily after detection.
finally remove any programs particularly if a phone was installed earlier and reinstall the Phone.
Get tips from the link below:
http://cellular.wirenode.m/obi.
h
ttp://www.nokia.co.id/dukungan/software/nokia-pc-suites/compatibility-and-download#
Dec 05, 2011 | Nokia 6700 Slide Cell Phone
I connected my usb cable from my phone to my laptop and it is saying nt connected
Have you installed usb drivers for your phone? or PC suite? For example: if you have NOKIA phone install Nokia pc suite. Also if you have SonyEricsson install SonyEricsson PC suite. This software comes with phone, it is written on CD of your phone.
May 29, 2011 | Toshiba Satellite A135-S2276 Notebook
How can i install nokia pc suit in nokia 3110c right now
hOw?
You need pc with suitable pc suite nokia for your phone.
Then you need Bluetooth or cable to connect between your pc and your phone.
If you have this then you open pc suite nokia on your pc.
Link PDF GUIDE PC SUITE
lInk to download pc suite 7
that new version pc suite.
After you have installed the pc suite to your pc, then connect, it will ask you to install at phone.
IF YOU HAVE BLUETOOTH DEVICE AT YOUR PC/LAPTOP, THEN YOU CAN CONNECT IT . TRY CONNECT IT FIRST USING BLUETOOTH. THEN IF IT WAS CONNECTED, USING PC SUITE.
May 28, 2011 | Nokia 3110 Cellular Phone
Dear Sir/Ma'am, I'm not able to connect my Sony Ericsson K750i to my laptop with Windows XP SP1 operating system. 1. The PC suite "Select the Phone You Want to Connect To" screen shows my...
hi,
while you installing your pc suite you have to install fully...
disconnect your phone and connect
or change the pc suite thant means search for latest pc suite...
uninstall and reinstall the pc suite
open the pc suite may be the connectivity can be shown there....
check the setting in the phone...
thanking u
happy new year
Jan 01, 2011 | Sony Ericsson K750i Cellular Phone
How to use the Nokia PC suite with the HCL Laptop computer
dear connect ur phone with pc suit then make dailup internet connection.control pannl -> network connections-> new connection
Jan 23, 2010 | Nokia 3110 Cellular Phone
My laptop does not recognize my n97 when connected via usb
Have had many similar issue with Nokia phones & PC Suite connections - works fine then stops - in add remove programs there is an entry called PC Connectivty Solution - it does not say Nokia unless you go change then it says Nokia - remove this, the Nokia suite & Nokia Connectivity Cable Driver - restart PC, switch off phone, remove battery, switch on, reinstall and it should work.
Good luck.
Oct 14, 2009 | Nokia N97 Cell Phone
Nokia 6070 internet connection
www.blogfortech.co.cc
go to this link u will find the PC suite for Serial cable
Download that and install on your PC/laptop
Connect ypor mobile to PC/laptop via CA-42 cable
When youR phone gets connected to your PC/laptop
go to control panel and then in phone and modems and
go to modems and select add new and click on 'dont insatall my modem i will select from the list'
after that select manufacture nokia and select modem of NOKIA 3200 and select the port ON WHICH YOUR PHONE IS CONNECTED
dont select the different port you will not be connected to internet.
and finish it
NOTE:-Install your modem only when your phone is connected.
Go to PC suite and click on the modem you installed
and provide your Operator setting and you have done it.
NOTE:-when your connection is Established your Phone will be disconnected from the PC suite
After disconnecting from the internet Your phone will again connected to PC suite.
ENJOY...........
Jan 08, 2009 | Cell Phones
Motorola Mobility MOTOKRZR K1 Cellular Phone Logo
48 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
