Question about Sony Network Walkman NWZ-S545 Digital Media Player
Locks up when I plug it into my computer - Sony Network Walkman NWZ-S545 Digital Media Player
    Problem Solver:
  • 12 Answers
On the back of the unit, there should be a small reset button. Pushing and holding that button for about 5 - 10 seconds should reset the unit.
If that doesn't work, you may want to read WarMaiden.org's solution to getting the computer to recognize the Walkman...it may work for you.
Posted on May 16, 2010
Unlock
Unlock an iPod Model A1199
Although the second generation iPod Nano (also known as 2G) uses a four-digit pass code that prevents unauthorized access to your iPod by locking the screen, you can also unlock the device by plugging it into your computer's USB 2.0 port.
When the 2G iPod Nano is connected to the computer it is synchronized, and automatically unlocks the screen according to the official Apple site.
In order to successfully unlock the Nano it must be plugged into the primary computer used for synchronizing content.
Click "Start," "All Programs" and "iTunes" on your PC's desktop, or click "iTunes" on the Macintosh's desktop dock.
Plug the iPod Nano's cable into the docking port on the iPod Nano.
Plug the other end into the USB port on the computer to open iTunes.
Click "Controls" at the top of the iTunes' menu, and select "Eject iPod."
The iPod Nano's screen will be unlocked once it is ejected from your computer.
Manual Guide download
http://manuals.info.apple.com/en_US/iPod_nano_2nd_Gen_Features_Guide.pdf
Unlock an iPod Nano Code
With the latest iPod Nano model, you can set a four-digit code and lock all intruders from accessing your iPod.
In order to use the device's functions again, you need to enter the correct code.
However, if you happen to lose or forget the code, you will need to find another way to unlock your iPod Nano.
Plug the iPod USB cable into the bottom of your iPod Nano.
Plug the other end of the USB cable into a free USB port on your Mac or PC computer.
Open the iTunes program by using the Dock on a Mac or the Start menu on a PC.
Select your iPod Nano from the "Devices" list in the main iTunes window.
Click on the "Sync" button to make a connection between your computer and your iPod Nano.
Click on the "Eject" symbol once the syncing process is complete.
Remove your iPod Nano from the USB cable.
The iPod's lock code will now be reset and you will be able to access all features again.
Navigate to the "Screen Lock" option in the iPod menu to lock your iPod's screen again.
Since your iPod's lock code was just reset, you will be prompted to select a new four-digit code.
iPod Support
http://www.apple.com/support/ipod/
Jul 24, 2013 | Apple iPod nano
Pc was locked
Unplug the source or delete the software that was downloaded that caused the problem do a system repair. Or go back to an earlier time when you know the computer was working fine.
Also you can take out the battery and unplug the computer wait about 20 minutes to reset itself, plug the battery back in and power the computer up again to see if that unlocks the computer make sure your external devices are not plugged in for the moment at the reboot.
John
May 11, 2012 | Dell Computers & Internet
Keyboard is unresponsive and locked. NumLock light locked on.
Try unplugging keyboard from computer and plugging it back in. Then restart computer.
Mar 02, 2011 | Dell XPS M1730 Keyboard
My computer is not acknowledging the numeric keyboard because I had to have another hardrive installed. What can I do? My keyboard came with my computer and is much better than the computer acknowledged...
If the keyboard has a round plug (PS/2) then it must be plugged in BEFORE you turn the computer on and make sure none of the small pins are bent or broken. PS/2 plugs are keyboard and mouse specific so make sure it is the keyboard port. Typically it is color-coded purple.
Make sure the Numbers Lock is engaged. There should be Num Lock button and many keyboards have a Num Lock light that turns on.
Try the keyboard on a different computer, it might been damaged when the hard drive was replaced.
Buy a replacement keyboard, the are really inexpensive online. I recommend www.newegg.com
If this helps please vote for my solution. Good luck!
Feb 03, 2011 | Computers & Internet
Not working
Make sure your keyboard and mouse are plugged into the right USB ports on the switch. If you plug the keyboard into the mouse USB port the hotkeys will not work! The USB ports on the KVM switch are labeled under each port, with a mouse and keyboard icon respectively.From the Quick Start Guide/Manual: The Numlock hotkeys are listed as:
[Num Lock]+[-] [1] Switches to output 1
[Num Lock]+[-] [2] Switches to output 2
[Numlock]+[-] [A] Auto-scans and chooses which ever port is connected.
Alternatively: Tap [Scroll Lock] twice to automatically switch between ports.
Note: I've never been able to get the Numlock key combinations to work correctly. I always just use double-tap [Scroll Lock] trick to switch.
If you get stuck with your scroll-lock and Alpha lock lights flashing, just hit [Esc] to fix it.
Source: http://www.aten.com/download/download.php#productGuide (Scroll down to "Quick Start Guide" and choose CS62U out of the drop down).
Oct 03, 2009 | Altusen Aten CS62U-2 Port USB KVM Switch
Computer locks up when plugged into camera
Might be that the USB Port you're plugging the webcam into is USB1.1 and the camera is USB 2????
look at the port on the computer.. is it Black Plastic or White... If Black It is USB 1 if White...USB2...
Might be that causing the freeze up... Hope it helps
Jun 04, 2008 | Philips SP900N Webcam
Messed Up.
hi what you need to do is put the mp3 into recovery mode to do this follow these instructions
1 with mp3 player off push hold/lock button to lock position(this is what you press to stop you pressing buttons when its playing it locks the buttons out) switch this to lock
2 press and hold rec button on left hand side keep holding down
3 whilst holding rec switch mp3 player on keep holding rec button untill it comes on it should now say recovery mode.
Dont do this whilst plugged into computer and dont plug into computer after its in recovery mode untill told to
once its in recovery mode got sandisk website and download the latest firmware once you have downloaded it onto your computer then open the file on your computer it will then talk you through the rest of the procedure this will solve your problem.
Let me know how you get on or if you need further assistance ok
Apr 09, 2008 | SanDisk Sansa e250 MP3 Player
Sony Network Walkman NWZ-S545 Digital Media Player Logo
161 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
