Question about Canon imageRUNNER iR C4080 Color Copier
Colored ink is smearing on the page when I print
The canon IR 4080i has started to smear yellow ink on the page when printing two sided files.
  • 1,219 Answers
Did you change the toner?Developer unit? When did it occured?
FIRST: the copier must be cleaned and vacumed, it may be that toner falls onto transfer section and that causes the problem, you may also have problem with yellow developing unit or drum or transfer cleaning blade.
Pls. rate
Posted on May 10, 2010
I have colored smears on left side of all my printed pages with my Brother MFC-9420 CN. What causes this?
It's not unusual for paper to hit the bottom of the print head, especially if the paper is bent. This can cause smearing. If you have pets, you can check for pet fur in the printer, or other foreign material inside that can also cause smearing.
Sep 11, 2014 | Brother MFC-9420CN All-In-One Laser...
HP laserjet 5000gn when i print, output smears ink on 2 sides. not a toner issue cause changed toners already. someone says printer is telling me something and might be a warning of
If by smearing you mean the print is also rubbing off? Then you definately have a fuser unit issue. The fusing unit is the assembly that heats up and "fuses" the toner onto the page. When these start to go bad, usually on one edge or the other the print will smear/double image/wipe off of the effected area. One test you can do to verify a fuser problem is to print a page and then when the page is about half way thru the prcess, shut the printer off. Open the top and remove the toner cartridge, pull out the page and see if the lower part is not smeared. Basically what your checking is to see if the print is ok BEFORE it goes thru the fuser. Based on your description I would suspect your fuser is going bad.
Good Luck and Thank You for using Fixya.
Sep 09, 2010 | HP LaserJet 5000gn Printer
Ink from smearing all over my papers
Using original cartridges won happen like this.
May 30, 2010 | Canon Pixma MP450 All-In-One InkJet...
Cannon Pixma MP830 - smearing on front when printing
If you have taken it apart that far then you are way ahead of the game. My suggestion would be to clean the head or anything the ink touches in a vinegar/water solution. The vinegar dissolves any dried ink whereas the soap may actually gum things up. If that doesn't work or improve things I would say that your print head has a seal problem. The replacement print heads are worth more than a new printer so you can probably figure out whats cheaper to do.
Aug 21, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Epson Stylus C86 smearing
Your printer has ink build up inside it. This comes from cleaning cartridges and builds-up steadily over time. Remove top cover. Wet a cotton swab with isopropyl alcohol (available at drug stores) and clean the inside. use a cotton bud where the swab gets entangled.
Aug 07, 2009 | Epson Stylus Photo 1290 InkJet Printer
Canon Pixma MX 310 print smears.
You need to clean the bottom of the printhead, and use a Q-tip to clean the wipers on the clean station that is on the right side where the printhead parks. There are 2 or 3 squeegees there that wipe the bottom of the printhead and when there's too much ink it stays on the printhead causing the smears.
Jul 23, 2009 | Office Equipment & Supplies
Black ink smears everything.
you may have to clean the print head. since the jam cause the smear, and there still have some ink left on the print head.
you wouldn't get aclean copy till all of the ink trace are gone.
May 20, 2009 | Canon Office Equipment & Supplies
All ink cartridges leak onto to copies
I think you need to change the tranfer belt assm.
If all the colors are smearing .
Or all of your toners are bad and leaking,
Hope this helps
Mar 28, 2009 | HP LaserJet 4650 Color Printer
Pinstripes in image after print (phaser 8560)
Appropriate cleaning procedures, as listed in the following tables, should be
performed when specific print-quality or paper transport problems occur.
All cleaning procedures are detailed in the printer’s Phaser 8400 Reference Guide or
the Phaser 8500/8550 User’s Guide.
Light Stripes or Missing Colors
Problem type Solution
Missing or light-colored
stripes on prints.
Select the automated procedure Eliminate Light Stripes from
the Control Panel.
Ink Smears, Oil Spots, or Random Ink Streaks
Ink smears on the front,
back, or edges of a page.
Select the automated procedure Remove Print Smears from
the Control Panel.
Check the maintenance kit for ink and paper-dust build-up on
the wiper blade.
Oil (drum fluid) on top edge
of print.
the Control Panel.
Hope this helps
pdouglasss
Nov 24, 2008 | Xerox Phaser 8560DN Laser Printer
Smeared lines
Okay, this was the problem I posted a few days ago. It's fixed now, so in case you have the same problem with smearing, here's what the help desk from Canon suggested: Open the cover and remove the ink cartridges. There is a gray lever in front of the cartridges. Lift this lever and the printhead can be easily removed.
Our printhead had a buildup of black ink on the surface. I carefully removed this with rubbing alcohol. I let the printhead dry and replaced everything. No more smearing. Imagine a help-desk that actually helped!
Nov 16, 2008 | Canon MultiPASS MP390 All-In-One InkJet...
Canon imageRUNNER iR C4080 Color Copier Logo
267 people viewed this question
old marine
old marine
