Question about Electrolux EOB6636X Ultrafan Electric Single Oven
How do i turn the fan off. - Electrolux EOB6636X Ultrafan Electric Single Oven
  • 269 Answers
If you mean the oven fan that will turn off on control switch.I think you may be talking about the cooling fan.This is to cool the electrical panel on the top front of cooker. It comes on after the oven heats up and may stay running for 15 or 20 minutes after cooker is turned off it will turn off after the unit has cooled down sufficiently for the controller.
Hope I helped.
Good Luck.
Posted on May 07, 2010
Bosch oven cooling fan is continuously on at the same speed and is on always no matter what the temperature is. Upper heating element does not turn red hot in broil mode.
The oven has internal fan at back of oven encircling the element that should get reshot when stat turned up high. Also there is cooling fan under lid to keep the wiring area cool.This should stay on for around ten - fifteen minutes after cooking finished. David "The Famous Forry"
Oct 16, 2017 | Bosch Ovens
My oven wont turn off
The thermostat for the fan is shorted out
Jan 28, 2016 | Ovens
Indesit FID 20 WH fan double oven.when main fan oven turned on the fan does not operate .have to turn off and manually spin fan.turn oven back on and it seems to work.what could be the problem.thanks in...
The fan nneds replacing, as it has a tight or worn bearing/s, the fact that you turn it manually and it then goes, temporarily frees it enough to get it running, but the the only guarantted solution is to replace the fan motor.
Feb 17, 2011 | Ovens
The fan has stopped going round
When the oven (fan) is in use, it circulates warm air round the oven. This air, depending on what you are cooking, may be laden with oil/grease. This builds up on the inside of the fan cover. There are four self tapping screws in each corner of the cover. Undo these and the cover should come straight off revealing the fan and heating element. (The screw holes are offset so you cannot put the cover back upside down). Be careful of the thermostat sensor immediately above the fan cover! Grease/dirt builds up round the vent holes on the cover and may stop the fan turning. The dirt will have to be removed. I use the Lakeland brush on oven cleaner - it works a treat and don't worry about the stay clean surfaces, it cleans those as well.
When you have the cover off, try turning the fan manually to see if it turns easily and has not seized. If it doesn't turn then you will have to take the entire oven out of the kitchen carcass to access the back of it. If it does turn, then switch the oven on and see if the fan turns. If it does, you have found the problem, if it doesn't, then it looks like you will need a new fan motor. Don't leave the oven on too long as the element will not be cooled by the airflow as the cover is off. Let things cool down before you attempt to put the cover back on to stop yourself being burnt on the fan element! Try espares for a new fan.
Feb 16, 2011 | Stoves 720EF Electric Double Oven
Have a stoves 720 es main oven fan does not stay on to cool oven after switch off> also the oven will not trun back on when it is still hot or warm ? will
First things first. There are two fans. One in the bottom oven and one to provide background cooling. The background cooling fan turns on when anything is turned on. (Fan oven/top oven/grill). Just operate the top oven for a moment and this should cause the cooling fan to operate. There is a printed circuit board that controls the cooling fan and for how long the fan should stay on once everything has been turned off. (About 7 mins). If this fan is not running then the fan/motor could be faulty, or the circuit board or the resistor on the fan terminal block. The reason the oven will not turn back on is that the residual heat in the oven unit as a whole against the fan oven, is probably too high which causes the overheat device to operate.
You will have to take the oven out of the kitchen carcass, take the top and rear panels off and get an electrician to test and found out which item is not working/failed. Try espares for parts.
Jan 24, 2011 | Stoves 720EF Electric Double Oven
Fan is not turning
yes if you ave is set for fan forced...no if you have is set for non fan force....a lot of ovens have many setting depending what you are cooking....top oven/bottom oven or fan oven plus a combination.
Jul 24, 2010 | Frigidaire FEB30S5D Electric Single Oven
In cabinet oven cooling fan does not work
it is the cooling fan if you have already replaced the thermal fuse on the back then replace the fan also shop around that price for the fan sounds high
Apr 05, 2010 | Whirlpool RBS305PDS Electric Single Oven
My oven turns off on me after only a minute never heating up fully
Could be caused by either of following;
1. Faulty thermostat.
2. Faulty thermal cut out switch. (controls power to cooling fan).
3. Faulty cooling fan (not fan inside oven).
Test thermostat by setting thermostat to low temperature like 60 oC. If oven gets much hotter then its a faulty thermostat.
To test cooling fan and thermal switch take oven out and remove top or rear panels to expose components.
When oven gets hot the cooling fan should turn on. If it doesn't then check to see if there is a mains voltage present.
If mains current exist but fan is not turning then replace fan. If mains voltage is not present then its the thermal switch.
Jun 19, 2008 | AEG B1180-4 Electric Single Oven
Control panel fan won't turn off
Is the oven still hot?? this is a Electronics cooling fan it will run even after the oven is turned off give it some time it should shut off let me know if not
Jan 26, 2008 | Dacor Epicure 30" Double Wall Oven,...
Electrolux cooler fan
absolutely, Never registers when the oven is below a certain temp to shut the fan off. It always thinks it's too hot and the fan will continue to run
Nov 21, 2007 | Electrolux EOB5630 Ultrafan Electric...
Electrolux EOB6636X Ultrafan Electric Single Oven Logo
429 people viewed this question
Top Electrolux Ovens Experts
ashburton
Mack Baxter
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
