Question about Garmin nuvi 750 GPS Receiver
It won't charge in the car and the MSN isn't working. Cable shows green light when plugged in the car.
    President:
  • 1,851 Answers
Try the unit in another car - if it still doesn't work - try reversing the inline fuse.
If all else fails - try charging it first on the home wall unit - or a charge that is COPMPATIBLE and doesn't charge too fast. Most cell phone charges with the mini plug will work but not all. IF all else fails - try resetting the unit - turn it off - then on - hold your thumb in the lower right corner on the screen. The next screen should ask you to reset - select yes - reboot and try again - if this fails I would try a new cord and then if that doesn't work - send the whole unit back - GARMIN is great for the first full year.
Posted on May 07, 2010
Dell inspiron M5030 won't charge, green light is
This is a common problem. It may be that the charger is dammaged. these Dell chargers have a micro thin communication cable in them that tell the charger to charge the battery. this micro thin cable can often break. Its use it to prevent the laptop battery from over charging, but if it breaks or becomed broken inside tha charger cable, then the laptop simply won't get the charge signal and the battery won't charge. If this is the case, then you will need to replace the charger with another Dell charger compatible with your laptop
Dec 23, 2012 | Computers & Internet
MY PLYMOUTH GRAND VOYAGER 'S HEADLIGHT'S AND DASH LIGHTS WORK, BUT THE ENGINE WON'T TURN OVER. THERE IS NO SPARK COMING FROM THE ELECTRICAL WIRES.
When you say no spark, are you talking about the spark plugs, or just the general wiring?
If the engine won't turn over, then it isn't moving, and if it isn't moving then you need to check the following in this order:
1) Does the battery have power i.e. around 12.4 volts or over?No? Charge, test or replace battery.
2) Do the car's head lights dim considerably if turned on when attempting to crank? Yes? Possible lack of battery charge or faulty battery.
3) Assuming the battery is fine, can you turn the dash warning lights on and off with the key? No? Faulty ignition switch.
4) Is there a click sound when you turn the key, but no starter motor spin? Check starter motor connections or replace starter motor.
If none of the above prove to be of help, then please report.
Oct 31, 2012 | Plymouth Cars & Trucks
Macbook won't charge
Your battery is probably not working anymore. Go to an apple store and ask for the repair.
Oct 24, 2012 | Apple MacBook Laptop Computer Mac...
Notebook won't turn on
my nb500 netbook wont turn on i slamed it shut now wont turn on
Apr 23, 2012 | Toshiba NB500-12X
Won't turn on
Your computer isn't recognizing the camera and you may need to install some software in order for it to do so.
Another thing? Are you trying to charge it? In my experience, Jazz cameras will only charge with an adapter that is usually included with the camera. Hope this helps.
Jan 19, 2012 | Jazz DV-179 Digital Camera
My Garmin nuvi 265 was working fine until 2 weeks ago. We got a screen message saying that the XM traffic was not supported, and then noticed that the unit no longer could be charged using the car...
The traffic receiver is in the car charger cable. The charger should have a red light on if it is getting power. If the light is on and the unit is not charging and you have no traffic, the charger cable is bad. If the light is off, then either the fuse did not fix the problem, blew again, or is somehow not sitting properly in the charger. Another thing you can check is by using the unit in another vehicle. If it works fine there, then the charger is not making good contact with your vehicle outlet for some reason. You will probably have to buy a new traffic receiver charging cable.
May 04, 2017 | Garmin nuvi 265 Car GPS Receiver
I have a JXD 206 mp4 player. It just came with 1 usb cable. How do i charge it?
To charge your player, Plug one end of the cable into your MP3 player and the other end (usb) into a usb connection on your computer.
Dec 22, 2009 | Audio Players & Recorders
Dell latitude D600 battery charge light flashing
That usually indicates battery is beginning to go bad. Eventually it will not hold a charge and will need to be replaced.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 09, 2008 | Dell Inspiron E1705 Notebook
Garmin nuvi 750 GPS Receiver Logo
115 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
