Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Door locked door still locked after wash has finished. Light still on and door won' open!
  • 1 more comment
  • izor Mar 27, 2008
    Any ideas on how to unlock the door after wash has ended. DOOR WON'T UNLOCK.
  • izor Mar 27, 2008
  • Anonymous Mar 18, 2014
    Door won't open
After trying all the above, making sure that as much of the water has been removed as possible, you can always use the manual door release. This is located behind the soap powder tray.
Push to open as you would normally when adding more soap powder, pull the tray out as far as you can.
Press down on the yellow portion in the tray and this should enable you to then pull the soap tray completely out.
Once out you should see what looks like a small grey plastic circle with a rectangular hole (ideal for a screwdriver) turn this and your door should open.
Posted on Jun 22, 2008
    President:
  • 1,294 Answers
You cld try 3 things:
1 Find the button on your panel which has the 'key' symbol, press and hold this down till the lock light goes off.
2 Hold down 'options' & 'select' buttons together till the light goes off.
3 Press 'end of cycle' button for 3 seconds, lock should come off.
Pl post back results. Rate if helped.
Posted on Apr 01, 2008
  • 108 Answers
WARNING: Do not take the lid off and reach inside the washing machine to try and release the door if the washing machine is still plugged in as you will be electrocuted!!!
There are many reasons why the door may be jammed shut -
  1. The water hasn't pumped out properly and the washing machine has a pneumatic door safety lock (a rubber hose connected to the door interlock and connected to a pressure chamber bottle on the tub - water forces air up this tube and locks the door)
  2. The water has pumped out properly, but a blockage of gunge inside the pressure chamber bottle is trapping the air that's operating the door lock (if a pneumatic lock is fitted - not many have these days due to cost cutting)
  3. Door interlock jammed
  4. Door catch, handle, or mechanism broken
  5. ****** (a device that detects the motion of the drive belt fitted to many older Hotpoint washing machines which "pecks" at the belt when the door handle or button is operated) is broken or has fallen off
Try a final spin again to see if the drain of at the beginning of the cycle is enought to empty the washer and release the door.
Posted on Mar 27, 2008
  • 183 Answers
SOURCE: WF100 door wont open
The interlock has jammed, first try gently pushing the door frame on the latch side of the door and then hit the outer door frame with your fist, not too hard but a reasonable bang this may release the door, if this works spray a lubricant into the latch hole in the panel, open and close the door a few times before reusing, if this fails then you have to force the door open, the best way is to remove the lid and manouver the door lock from the inside, either the lock or the latck will eventually break, this is unavoidable, then replace the interlock and any other broken part.
Regards
Advisor
Posted on Nov 17, 2007
jason0110
  • 66 Answers
SOURCE: Door locked
sounds like your interlock has failed you can buy from any appliance spares outlet or online regards jason
Posted on Jun 15, 2008
SOURCE: Door on Hotpoint WT540P Won't open
I have solved this problem now. I removed the top of the washing machine and opened the catch with a screwdriver to release the door. The plastic handle on the door has snapped so have ordered a new one on line for £5 plus p+p. Should be able to fit it myself. Hotpoint wanted £100 - £160 to come out and fix it. Beware!!
Posted on Aug 25, 2009
SOURCE: door wont open on my washing machine hoover select 1500
I just had the same problem and came here looking for a solution...I went back one last time and tried to unplug. That didn't work. Then I put it on drain/spin and after a minute interrupted by hitting the pause/cancel button - and it released! I am so happy!
Posted on Sep 21, 2009
  • 104 Answers
SOURCE: Indesit wd 125. Wash cycle had finished, door lock was off but
Unplug machine, take lid off and locate the door lock. You will have to use a small screwdriver or something to release the lock. Then replace your door handle.
Posted on Jan 28, 2010
My Bosch AvantiXX front load washing machine has finished the wash and now it has locked on me and I can't open it. How can I open the door?
hi Suzanne.
i have had a look around the internet and found that there is lots of ways to try and open it.plus there is people on youtube showing how to open a door.
so if you go to this link and pick the one you think would be the best one for you to try.
Bosch AvantiXX front load washing machine door wont open Google Search .
or this one.
How to open washing machine door that won open normally
Nov 20, 2017 | Bosch Washing Machines
HNL 6146 door won't open
Has it emptied all water out ??
Jun 18, 2013 | Hoover Washing Machines
My servis m6011 5kg washing machine door won't
Possible that the door lock has jammed and so is not working.please check this link: door lock
Jul 03, 2012 | Washing Machines
LG WM3431 door won't unlock
did you unplug it,leave it unplugged for 5 minutes and plug it back in,if it's to hard to get to plug flip the breaker and leave the power off for 5 minutes or longer when you power it up again the door should unlock.here's a link to check hope it helps
https://www.google.com/search?q=lg+front+load+washer+how+to+manually+open+a+locked+door&oq=lg+front+load+washer+how+to+manually+open+a+locked+door&aqs=chrome..69i57.21935j0j8&sourceid=chrome&ie=UTF-8#kpvalbx=1
Dec 29, 2017 | LG WM3431 Front Load Washer / Dryer
I pushed the 'pause' button during the wash cycle of my LG WD-3274HD and now the door won't open.
Hi!
The machine knows it dint't finish the washing cycle, and, because it may be possible that water is still a lot inside, the door is locked.
If you are shure the door can be opened without the water coming out by the door, simply disconnect it from the electrical supply and wait a few minutes until the door unlocks. (you will hear the unlock click)
Aug 08, 2011 | LG WD-3274RHD Front Load Washer / Dryer
My Electrolux ewf1090 front loader door wont open
Turn the power off and leave for 5-10 minutes then turn on. This should release the door lock the problem could be the pump drain filter is blocked clean this and it should resolve future problems.
Apr 25, 2010 | Electrolux Washing Machines
Jan 19, 2010 | Washing Machines
Door locked
Jun 08, 2008 | Indesit W 123 Front Load Washer
Bosch axxis door won't open
michele99, So when you put it on drain, do you here the machine trying to drain the water? After it finishes draining, (you have to wait a few minutes, it should then have a blinking light
on the Finished/Door locked light.
Are you waiting for it to finish?
May 08, 2008 | Bosch Axxis WFL 2060 Front Load Washer
A problem with my Bosch washing machine
It usually takes 2 minutes after the wash to open the door; do not force the door. Doesn't matter if the active light is on. Just try.
Oct 05, 2007 | Washing Machines
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
332 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
