Kindly go to www.lg.com and choose your area then you will find the product of them and probably chat online with their online customer service if they will get it for you or probably still do something for you ok. search with the model of your phone Kindly go to www.lg.com and choose your area then you will find the product of them and probably chat online with their online customer service if they will get it for you or probably still do something for you ok. search with the model of your phone
You can't post conmments that contain an email address.
Buy a lens pen and carefully clean the lens yourself. it will set you back about 10 dollar. If you never removed the lens form your camera, it is only the front lens you need to clean. Don't use any fluid, unless it says social for photo camera lenses. If you scratched the lens, no way it can be cleaned or repaired it. It would be cheaper to buy a new lens.
With just a little luck, the scratch is not too big, and you won't even see it on most pictures. Don't try to remove the scratch, because the front of the lens has a coating you can remove very easily. That will do more damage to the pictures then a scratch. You could contact a Canon repair centre, and ask what it would cost to replace the lens. I think it could set you back more then a new camera will cost, but always worth trying. If you don't see a thing on the pictures, leave everything as it is right now.
Only clean a lens with a lens pen, you can buy in every camera shop. In a camera shop you also can buy other cleaning suff special for lenses. Never use fluids that are not special for use on lenses, or you will also damage the lens.
1. Get the front lens element replaced by Panasonic. This will be fairly expensive. Afterwards, buy and fit a skylight filter to protect the lens.
2. Buy a skylight filter to protect the front of the lens from further damage and use photo processing software to retouch the affected images. This won't necessarily cost much, but will be a real pain to have to do all the time.
Whatever you do, do not attempt to polish out the scratch as this will destroy the lens coatings and will also reshape the lens slightly ruining it's optical qualities.
Well, you cannot buy the front element by itself. The whole front optic set comes as a unit. You can call Canon USA, ask for parts,
1-800-828-4040 The part number you are inquiring on is: CY1-2800
Have you taking any pictures with the lens? usually it takes quite a bit of damage to effect images. The rear optics are the more sensitive glass on all lenses
The same thing happened to mine. Customer support was useless, telling me I voided my (expired) warranty by breaking it, and that it is not a replaceable part.
Here's the fix that worked for me:
If you look closely at the metal bezel around the lens, you will see a seam between two metallic parts, near the front surface of the lens.Take a knife and gently work it around that seam until you separate the two pieces. They are held together with doublestick tape, so they come apart easily. That will expose the lens which is actually not a lens at all, it's a window; a flat glass disk. Take the tip of a pointy knife and gently pry the glass piece(s) off. Again, this is held on with double-stick tape so it will come off easily. If you can find a glass disc that is the same diameter and thickness, you can place that in. The disc is a 20mm diameter by 1mm thick. You can probably order a replacement watch crystal from somewhere like this place:
They cost less than a dollar (not including minimum orders, shipping, etc), and they are probably more scratch/crack resistant.
If you don't want to bother replacing it, your camera is still fixed, just a bit uglier and vulnerable to dust. The front lens has no optical significance, it's just a dust cover and/or a design element.
The metallic bit you took off is little more than a piece of tin foil.
Had they used a more substantial part that could divert shock instead of directly transferring it to the glass, there would be far fewer cracked lenses out there. But that would probably hurt their "go buy a new one" repair policy.
It is not hard to change the faceplates on cell phones but you will need a special screwdriver to take the faceplate off, It looks like an octogon. I am not sure if it will fix the lens but when you look at the new plate you will be able to tell. Anymore question just giveme a shout bud.
This is very simple to fix. I have replaced 2 of them already. You can buy the new glass for I believe $6.99 or around that delivered from someone selling them on eBay. Then just pull out the old glass etc. Then the new piece has a little trim of double sided tape on it to fit into the exact same spot.
.Actually will be helpful to find if you unit is been damaged from a scratch or a Crack display.The one on the front is Called Faceplate.The one inside(the lcd is called screen).
If your screen is cracked you can order one on line and follow some tutorial.If the scratch is from the faceplate you can try to open the machine and clean the scratch with some plastic polish
Good Luck
Where can I buy one?
I looked on line and I counldn't find one. I need a maroon one.
