Question about Mitsubishi WD-52725 52". Rear Projection HDTV
Code 34 error repair shop wants to charge me $700
Can I pull this repair off myself? Repair man stated that they need to replace the Chassis Assembly part # 955B298001 yet after reading many discussion board comments most of the fixes were simple capacitor replacement (and upgrade to a 16V version to handle any future power surge)?
Is the repair guy giving me a false diagnosis?
  • 160 Answers
It just takes time. An issue like this is one that is known by the manufacturer however it takes time for the repair man to get into your tv and they are paid hourly which is where they make the big bucks. You can do it yourself just fine however you can also put your tv in the grave forever. As long as your ok with buying a new LCD if this does end up dead you should be fine. Always make sure your willing to except the risk, don't forget the insides of projection televisions can store electricity as well.
Posted on May 07, 2010
Testimonial: "Great advice I will repair myself :)"
Dropped my JVC Everio and
Sorry to say you have to take the camera to a professional repair man, I've attempted to repair these myself but they are a pain to put back together.
Jun 15, 2008 | JVC Cameras
My shutter stopped working on my minolta X 700 how can I fix it myself.
It sounds like the same problem I had your capacitors need to be replaced. They store the energy needed to fire the shutter when you depress the button. Most camera shops are aware of this problem and the can obtain the parts. The replacement requires camera tear down and soldering in the parts. If you don't feel comfortable doing this then take it to the repair shop.
Jun 14, 2010 | Minolta X-700 35mm SLR Camera
Our picture shows double. The repair man came out
Not advisable. $500.00 is way over board what we charge for that repair. 250-300 max. I don't know of any shop or with our tech web site that charges that kind of money. I would still shop around.
Jul 20, 2009 | Mitsubishi VS-60803 60" Rear Projection...
DISPLAYS LF (LONG FILL) ERROR CODE WHEN HOT WATER is involved.
This is a faulty water valve Assembly. you can order this online and it is shipped with easy to read instructions on how to attach as well. it quite the novice job.
May 21, 2009 | Whirlpool Washing Machines
Error code 34... eventually error code 14
How to fix error codes 14 &34 on Carrier Infinity furnace
Mar 30, 2009 | Heating & Cooling
Mitsubishi WD62526 - Error/repair code
Error Code Probable Cause
12 No error detected
22 Recovery from momentary Reset
32 Lamp Cover open
33 Air Filter Cover open
34 Lamp abnormality
35 Chassis Fan failure
36 Exhaust (Back Cover) or Lamp Ballast Fan failure
37 Engine (DMD or Lamp) Fan failure
38 Excess Lamp Temperature
39 Excess DMD Temperature
41 Short Detected
44 DVI Cable (between Chassis and Engine) disconnected
remove the back and lamp (make sure the lamp door is on) turn the tv on and look to see if the fan is running (keep you hand out of the tv when doing this - as the lamp connectors are empty) if the fan does not start - replace lamp - the connector is located under lamp housing connector JA - measure the red wire and ground (any metal part) for 12v at turn on - if 12v replace fan - if no 12v check the power pcb
Oct 09, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Frigidaire FRS26R4A Side by
No its nothing you want to attempt. You need special equipment and technical training. I would recommend buying a new refrigerator before spending that much on a repair.
Jul 08, 2008 | Frigidaire FRS26R4A Side by Side...
Convergence board- Repair/ replace?? who has done this?
replace convergence ic's probably stk392-150 and check all resistors normal values 1.5 ohm-2.2 ohm-2.0 ohm-3.9 ohm check out of circuit- tolerance has to be dead on.
Nov 30, 2006 | Hitachi 57TWX20B 57" Rear Projection...
Mitsubishi WD-52725 52". Rear Projection HDTV Logo
314 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
