Question about GE Refrigerators
Compressor runs but condenser fan does not,tried
Compressor runs but condenser fan does not run,tried another fan and same thing
  • tbirdman5901 May 07, 2010
    The fridge is cooling but just the condenser fan does not work and i replaced it and had the same thing on the new fan.
    i will try this out thanks
  • 17,970 Answers
Could be the timer /defrost thermostart or heater most time is the timer. When you changing timer, also replace the defrost thermostart.
Fans not running will cause the fresh food and the freezer sections not to work. If the condenser fan (the one under refrigerator) is not working, the compressor will cut off on the overload. If the evaporator fan is not running, there will be no airflow to the freezer or the refrigerator. First walk up to the refrigerator and listen to see if the fans (one in the freezer on one under the bottom) are running. If one is running and the other is not then get to the one that is not running and see if something is blocking it. If there is nothing blocking it then replace it. (Note that some refrigerators cut off the fan inside the freezer when you open the door so be sure that the door switch is depressed when performing this test). Refrigerator fan motors can be purchased at AppliancePartsPros.comcompressor runs but condenser fan does not,tried - show?id=6bjnatppuce&bids=92089.10000015&type=3&subid=0 or simply search your part above.
It is recommended by pros to replace the main control board if the condenser fan motor failed. For your model, check the right part number for the main control board is AP4297272
Hope helped.
Posted on May 07, 2010
  • ZJ Limited
    ZJ Limited May 07, 2010
    These GE refrigerators have two fan motors (some models) and both must be operating
    properly for the refrigerator to cool properly. The condenser motor is
    located behind the refrigerator and it must be running anytime the
    compressor is running. If the compressor is running but the condenser
    fan is not, replace the fan motor. The other fan motor is the evaporator
    motor and it is located inside the freezer behind the ice bin. To check
    the evaporator motor, open the door of the refrigerator for more than
    three minutes. After three minutes the evaporator motor should come on,
    if not you must replace the motor and the main board. This is because
    the old fan motor caused the main board to go bad. Behind the
    refrigerator you should see a metal plate about two feet from the floor,
    remove it to access the main board. Be sure to unplug the refrigerator
    before attempting to replace the main board or the fan motor. Use this
    page for more in-depth GE Refrigerator Fan Motor diagnostic (next lines).
    GE Refrigerator Fan Motor Diagnostics
    (For GE’s electronic
    refrigerators made after 2002. Including top-freezers, bottom-freezers,
    and side-by-side models).
    The main board controls the fan motors on these refrigerators. This
    makes them more difficult to check but with the help of this page it is
    easy. On GE electronic refrigerators the main board is located on the
    back of the refrigerator. There is an access panel either on the bottom
    right or the top left of the back of the refrigerator.
    Note that
    not all GE refrigerators made after 2002 are electronic models so if
    there isn’t a main board, your refrigerator isn’t an electronic
    refrigerator and this page doesn’t apply to your refrigerator. However,
    if you have an electronic board and the fan motor isn’t running this
    page will help.
    Note that if you at anytime determine
    that the main board is bad look closely at the board for any burnt
    resistors. If you see a burnt resistor replace the fan that isn’t
    working along with the board because the fan most likely caused the
    board to go bad. So if you only replace the main board the fan will
    cause the new board to go bad as well.
    Below is a
    picture of a main board for a GE electronic refrigerator. It shows the
    location of the J2 plug where testing for fan motors is done. Note that
    the location of the J2 plug may vary depending on the year the
    refrigerator was made. Also the board may be turned sideways.
    Condenser Fan (the fan beside the compressor)
    The condenser fan is the fan located near the compressor and it
    should be running anytime the compressor is running. This section of the
    refrigerator fan motor diagnostics guide will discuss how to test the
    condenser fan on GE electronic refrigerators. If the compressor is
    running but the fan isn’t more than likely the fan is bad but it could
    be the board. Leave all plugs connected even the J2 plug at which you
    will be testing.
    To test this, locate the main board on the back
    of the refrigerator. On that board there is a plug marked J2, this is
    where testing for the fan is done. Set your meter to read DC voltage and
    place your black (common) lead on J2-pin 3 (third pin from left) and
    your red lead on J2 pin 8 you should get 12-14 VDC and if you don’t
    replace the main board. Next, leave your black lead on the same wire and
    test to pin 5 this pin should read 12 VDC, 8VDC, or 4VDC. Note that you
    should only get 4VDC if your refrigerator has a variable speed
    compressor.
    If the voltage is correct and the fan isn’t running
    replace the fan. If the voltage isn’t correct replace the board. This
    refrigerator fan motor can be purchased at AppliancePartsPros.com As well as the board.
    Good luck.
Condenser Fan Shuts off after 15-20min, Compressor continues to run but gets hot
Condenser fan motor or motor wiring is bad. That compressor should never run without the fan. Good luck.
Jun 14, 2014 | Beverage-Air MT27 Beverage Cooler...
U-Line ice maker compressor won't run
Dose compressor fell too hot ? There could be several things wrong. First you will need to get out your Volt meter to make all test. With unit calling for freeze cycle the condenser fan and compressor should be running. Check at the compressor to make sure your getting power to the over load switch and then through it to compressor. if not then check to see if compressor is to hot and has the switch open> If so then unplug unit to let compressor cool down so switch will close. when switch closes plug unit back up and start up unit check to see it compressor starts if so then you will need to see what is causing compressor to over heat. could be dirty condenser, low charge, fan dropping out, Bad compressor.
Mar 07, 2014 | U-Line Icemaker
Rangemaster sxs cream . Why is my fridge and freezer the same temp ???? If anybody could give me an answer or solution.
Jason,
MOST refrigerators get there cold from the freezer side and circulate it via a fan that's also normally inside the freezer. There are three motors normally in a refrigeration system. The inside Evaporator fan motor that circulates air across the evaporator coil inside the box, the Condenser fan motor near the compressor that cools the freon after compression, and the compressor itself. If you open the doors (and sometimes you may have to hold in the door switches) do you hear a fan running? If not you could have a couple things going on: 1. The fan(s) has failed. 2. The freezer Evap coil may of iced over and the fan too is frozen stopped. 3. Your condensing unit:(compressor, condenser fan, condenser coils) has a problem.
It is important to know if the compressor itself is running. If there is a loose connection to the compressor via the start/over load relay (normally attaches directly onto the compressor), or if the start/over load otself is bad the compressor will not run. Best way to tell is via gauges but I doubt your frig has ports. Check to see if your compressor is really hot. Could be bad start/over load relay or bad compressor. Try unplugging your frig for say 30 min then, with your hand on top of a cool compressor, plug the frig back in and see if compressor smoothly vibrates for at least 5 min without becoming very hot or shutting off even though fan continues to run. The fact your fan is running TYPICALLY means the thermostat is calling for lower temps and the fan/compressor kick in together.
Oct 11, 2013 | Refrigerators
Refrigerator wont run. Clicking noise coming from main board preceded by a short humming noise every several seconds. Unplug for 30 minutes then plug back in and compressor starts up after several clicks...
That condenser fan motor needs to be replaced. You and doing the right thing as far as using a seperate fan to keep compressor cool,buy replacing the fan the compressor will run cooler and click off by being too hot as you have heard/seen.
Find your model number and call your local appliance parts store and see if they have a CONDERSER FAN MOTOR in stock
Gene
Aug 15, 2011 | Refrigerators
Refrigerator & frezzer no longer cooling. Compressor is still running , but condenser fan doesn't seem to be working correctly. Does the fan not working full time when the compressor is running...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 23, 2011 | Refrigerators
COMPRESSOR RUNNING,CONDENSER FAN RUNNING,EVAPORATOR FAN RUNNING,NOT COOLING
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
heatman101
Jan 12, 2011 | Refrigerators
Not cooling or freezing. compressor and fan running
Hi, you say compressor and fan are running, you have 2 fans, a condenser fan motor in the back behind the panel at the bottom, and the evaporator fan in the freezer. When you check the condenser fan in back by the compressor, check the front of the coil to make sure it is clean as the fan pulls air through the coil to keep internal pressures down. You may have a sheet of dust on it. Check these things and get back to me. Keep me posted.
Sincerely,
Shastalaker7
Jan 30, 2010 | Refrigerators
My refrigertors stop working
First thing to do,is,see if the compressor is running,it should be humming,and warm to the touch.There should be a fan running under the unit,cooling the condenser.And the fan in the freezer unit should be running.If none of these are running,check to see if there is current in the wall plug,maybe plug it up to a known hot,receptacle.If the fan in the freezer is working,or the condenser fan,check the thermostat to see if it is working.If it is,take a 120 volt,volt meter,and check the voltage going in the compressor,if it is getting voltage,and is real hot to touch,then it is bad,the compressor,or if it s not running,then it is bad.If the compressor is running,and the large line off the compressor is cold,or near it,then it may be just low on freon.So many things to check here.
Nov 10, 2009 | Refrigerators
A/C FAN MOTOR SHUT OFF, BUT CONDENSER KEEP ON RUNNING
The condenser fan might be going out. It'll start when cool but shuts off as soon as it starts to warm up.
Jun 28, 2009 | Heating & Cooling
Fan running but compressor is not
which fan is running? evaporator fan or condenser fan?
if the condenser fan is running and the compressor is not, try to feel the compressor if it is VERY hot,
( use caution please)
if it is very hot, unplug the unit, put some wet rags on top of the compressor and let it cool for a while.
after 4 hours, try it again, plug it back and observe the compressor if it would run,
let me know what happen,
tnx 4 using fixya,
drcool
Sep 26, 2008 | Whirlpool Refrigerators
Refrigerators Logo
61 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
