Question about Hitachi 42HDT51 42 in. Plasma SLC1551AW
When I turn on my TV the on screen flashes on ant than goes off as the tuner light flashes from red to off and back to red. Finally when the tuner light turns green ( goes on) the screen goes on and stays on and the TV works normal. This usully happens when the TV first ges on in the morning. when it is warm the proiblem does not seem to appear.
  • mskor2028 May 07, 2010
    This TV comes in two parts. The tuner and in my sterio component cabinet ant the monitor that hangs on the wall. The tuner/control unit is the unit that does not seem to turn on when you push the power switch on the remote or on the tuner unit itself.
  • mskor2028 May 08, 2010
    The seperate control center unit will not turn on when the on switch is turned on or if you use the remote. However after about ten or 12 tries it goes on. This only happens in the morning when the TV hhas been off for the night. During the day it seems to work most of the time. Maybe because it is warmed up some
  • 666 Answers
The blinking light signifies to a repair technician with capacitors or circuits are having an issue they can diagnose the problem via the amount of blinks in between pauses however it will require a technician and some specific tools and schematics to fix and it may be cheaper if its no longer under warranty to purchase a new one
Hope this helped
Robb
Posted on May 08, 2010
    Guru:
  • 416 Answers
Is this a newly occurring issue or did you just notice this happening? Your TV has a digital module, either incorporated into the Main PCB or on a separate PCB. In either case, the module must boot operating software in order to function. After the TV is initially turned ON, the module will remain ON after the TV is shut off for a period of time. An unwritten standard seems to be about 2 minutes. So, if you turn the TV ON, see the issue you describe, turn the TV off, then turn the TV right back ON... and then the problem occurs, this may not be the cause. However, if it does not occur, turn the TV OFF, wait about 3 minutes then turn the TV back ON. If the issue occurs, it is related to the digital module. This does not mean it is a mis-operation.
Posted on May 07, 2010
  • Adam Halfhill
    Adam Halfhill May 09, 2010
    I'm not familiar with this particular TV, but that doesn't leave me without a few ideas. First, the TV should power up without the media box attached. If you could, disconnect the media box (may be easier to do this on the back of the box than the TV. Then power the TV on. Does it seem to come on... perhaps it a special mode. Next, power the Media box on... does it come on or do you have the same difficult on/off condition. I'm simply just attempting to ruling out influences from one or the other with this process. If the box is still acting up, the first thing I would look at would be the power supply inside the media box. Mostly because it sounds like a low voltage related symptom. The most common cause of this is dry capacitors. Often they are bulging on top, but not always. Let me know what you find.
  • 4,472 Answers
Ok,
There is most likely a problem that will eventually get worse. When the problem does occur next time look for how many times the light blinks this number of blinks is associated with a trouble code that can better isolate the problem. How long have you owned the tv and how long have you had this problem?
Thank you,
Lee
  • 1 more comment
  • Lee A.
    Lee A. May 07, 2010
    Hi can you confirm the model of your tv. From the specs this tv should have a built in hdtv tuner. Do you have the model of the separate box? I may be misreading what you have posted. Once I have more information I can assist you further. When/if you find my information helpful please reconsider and accept/rate my solution accordingly.
    thank you,
    Lee
  • Lee A.
    Lee A. May 08, 2010
    Did you read my last post? I asked you several questions. If I don't get the proper feedback there is no way I can properly assist you.
    Thank you,
    Lee
  • Lee A.
    Lee A. May 08, 2010
    A replacement AVC would run you like 1200$. You can get a 52" lcd for around that price, brand new with a warranty with a lot better picture quality. So you can either inquire with hitachi on repairing the AVC or sell your tv on ebay/craigslist for someone who can use it to recoup some of the cost for a new tv.
    Thank you,
    Lee
  • 4,889 Answers
This is definitely a power supply board related problem. Do you have a multimeter? I will see if I have a service manual for this one and we will get started.
The tv has power .the red light is on ,but when it turns on,the green light comes on but then it turns right back off ant the light goes back to red it has a round 1/2" button like plastic plug in...
Tod,
The little plastic button you are referring to is the IR receiver for the Remote. When the TV turns itself off, are there any flashing lights on the front or rear of the unit. Look through the vents in the rear for any flashing lights or try tuning the tv on in a dark room and see if any lights flash and reflect off of walls. If there are flashing lights tell me how many flashes and what color and I will try to look them up in the manual.
Nov 02, 2010 | Pioneer PDP-425CMX 42 in. Plasma...
The TV turns on, after about a minute the screen goes black. The green light which indicates the power is on flashes. After about a minute again the picture comes back on, and so on. When looking at the...
The tv Tuner signal boaard is dead.That the board,where the incomming broadcasting signal cable plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner signal board for the replacement.
Oct 21, 2010 | Sony KDS-60A2020 60" HDTV
Power light is flashing green. i hold the power button it turns red. i press it again it turns yellowish then solid gree the screen comes on the 3 second later screen goes blank and flashing green power
Sharp tv are famous for this problems.Take ur tv aparts,where the a/c power cord go into it.That ur tv power supply board,check for all those dead leakage capacitors parts that bulges up on it top or puff up on it top.Than it ur power supply board,replaced those dead leakages capicitors or replaced the whole power supply board.No leakage capcitors on the power supply board.Than it 100% the Tuner board it dead,this board is where the coalax broacast tv signal cable go into it.This board can't not be repair only replaced,because it alway some ICS it the problems it dead on this Tuner board.Tries websties like Shopjimmy.com,Ebay.com to buy either or both refurbishes the power supply board or the Tuner board.
May 26, 2010 | Sharp LC32D47UT 32 in TV
TV ANT Jack Broke off and lost cable viewing
Yes it can be replace only if it just a connector adapter connected independently unto tv tuner. But if it is with the tv tuner as a whole. You will replace the entire tv tuner. Just bring the part as reference to your favorite electronic store selling tv parts.
Apr 11, 2009 | RCA Alert Guard 20" Flat Screen 20F670T...
Can't get PIP to work on my Samsung LCD 46"
its talking about the analog tuner in your tv. split the cable before it hits the box plug the cable strait into your tv if there is more than one coax connector on your tv you will need a second two way splitter run one into ant a and one into ant b yo will not be able to use pip and hd at same time you can only do pip with the analog tuners built into you tv
Mar 17, 2009 | Zenith Z36X31D TV
TV SREEN GOES BLANK, BUT AUDIO CONTINUES NORMAL,
Try unplugging for 36 hours. I had the same problem but with no sound and picture
Mar 03, 2009 | Sony KP-53HS10 TV
PLasma wont turn on
Unfortunately you need a repair man. The power supply is bad.
Nov 12, 2008 | Televison & Video
Changed bulb, now tv does nothing. . .please help
same problem. TV turns on but no picture or sound. when i press power button on the remote control orange light flashes for about a minute and goes back to red.
TV won't turn on. It iz frustating me a lot ay !
Mar 07, 2008 | Televison & Video
Hitachi 42HDT51 42 in. Plasma  SLC1551AW Logo
71 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
