Question about Arctic Air 22 cu. ft. Commercial Freezer F22CWF
Need a defrost timer for Arctic Air F22CW freezer, but don't know where to order?
  • 8,197 Answers
You can get the timer on the link below.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-F22CW-%3d%3db193i890598&PartID=890598
Good Luck and please rate 4 thumbs up for the free answer
Posted on May 07, 2010
Testimonial: "Great advice"
Arctic air freezer building up ice but not freezing
It is a defrost problem. Either the defrost timer is not working or the defrost heater is shorted out. You will need to ohm out the heater. It should have close to infinite ohms. If "open" then that is your problem.
Nov 09, 2013 | Arctic Air 22 cu. ft. Commercial Freezer...
I have a 22 CUFT upright reach-in that ices up constantly. The ice builds up in the back of the freezer near the drain and then extends out to all the food toward the back area. I've tried increasing the...
this can be multiple issues. look for the freezer being level. look for any missing screws where water can leak out during defrost. make sure the door closes and seals. be sure you have the right amount of defrost cycles at the correct length. check to see if defrost heaters work. you may need to add a heater to the drain if there isn't one. worst case: remove product overnight and store in another freezer, unplug unit and leave door open to defrost, then plug in first thing in the morning.
Apr 17, 2017 | Arctic Air 22 cu. ft. / 623 liter Upright...
My f22cwf freezer keeps freezing up.
see if you can locate the defrost timer. then check it to see if it works. If it is a mechanical one, it will have a timer face on it that moves. make a mark on it and then check it in about 15 minutes to see if it has moved. If not, there is your problem.
Let me know if we need to go any farther. will be glad to dig alittle deeper.
May 21, 2010 | Arctic Air 22 cu. ft. Commercial Freezer...
Heat strip not working in freezer
What they are talking about is the defrost coil...
The most common problem though is the defrost timer fails....
Here are a couple of tips that I wrote that will help you figure this out...
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
heatman101
Apr 15, 2010 | Arctic Air 22 cu. ft. / 623 liter Upright...
I have ice build up in the coils and the freezer is not freezing , thawed the coils with a dryer but in a couple of days it is back again
Can't locate specific manual for your product but sounds like a defrost problem.
Unit should defrost on a regular basis. Usually controlled by a timer. It should turn refrigeration system off, including fans, and turn on heaters to clear any frost or ice on the evap coils. Cycle varies on usage. Look for timer and see if it is running. Make a mark on it and give it an hour and check again to see if it has moved.
Hope this gets you started.
Mar 03, 2010 | Arctic Air 22 cu. ft. Commercial Freezer...
F22cw thaws & compressor is very hot..will stay that way for a day or 2 then starts working again...also fan on bottom of unit net to compressor doesn't seem to work.....help
Your problem is probably attributed to one of the following:
* compressor
* attachments to compressor (e.g.: relay, capacitor (if applicable) and overload protector)
* refrigerant restriction or leak
Contact an appliance service company.
Feb 19, 2010 | Arctic Air 22 cu. ft. Commercial Freezer...
Fan in freezer not working
It runs when the compressor runs except when it's in the defrost cycle. If you have an electronic control instead of a defrost timer the control could be the problem since it runs the fans. You can test the evaporator fan. See how here> How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Sep 21, 2009 | Arctic Air 22 cu. ft. Commercial Freezer...
Broich Commercial freezer ~ manual lost
I just turned it off and pulled out the super defrost button. I used towels not the drainage plug since I couldn't find a pan of any sort.
Also...very funny comment about my husband taking care of it!
Feb 08, 2009 | Arctic Air 22 cu. ft. Commercial Freezer...
F22cw freezer
The only possible switch that would be located on the back on the bottom may be a defrost timer. Other than that would be the starting components of the compressor which would be a relay and possibly capacitor.
Jan 16, 2009 | Arctic Air 22 cu. ft. Commercial Freezer...
Arctic Air 22 cu. ft. Commercial Freezer F22CWF Logo
425 people viewed this question
Top Arctic Air Freezers Experts
Dennis Boxerman
Dan Webster
Dan Webster
AJMAL KHAN
Are you an Arctic Air Freezer Expert? Answer questions, earn points and help others
