Question about Datamax H-Class H-4212X Printer
My datamax H class is giving error "Ribbon Fault", how can i fix it?
SOURCE: 4208 Datamax M Class printer Problems
After changing the size of your labels the printer needs to measure the new label length. Press the feed button for four seconds (wiht new labels loaded & printhead locked down). If this doesn't fix your problem you need to correctly position the media sensor.Make sure the short white line on the media sensor is above the label gap.
Posted on Aug 21, 2007
SOURCE: datamax dmx-m-4208
press MENU then enter(cancel) then FWD(feed) appear sensor type then press ENTER(cancel)
then choose continuous >>>
Posted on Feb 12, 2009
  • 52 Answers
SOURCE: datamax I4208
position fault is normally a problem with either the formatting or the printer is not calibrated correctly.
Hold the feed button down until at least 3 labels pass by the sensor.
Also check to see the sensor is directly over the die cut on the label if more than 1 up label
Posted on Feb 25, 2009
  • 67 Answers
SOURCE: will not feed full length of label. display reads
You may need to take out the whole ribbon assembly by removing 3 screws. The ribbon sensor looks like a L shaped clear plastic glass.
If still not working. buy the ribbon assembly.
Posted on Nov 07, 2009
  • 67 Answers
SOURCE: datamax dmx-i-4208 (ribbon fault)
Re-calibrate the printer. If still not working, take out the ribbon assembly by removing 3 screws and check the sensor ( "L" shaped plastic glass). If still not working, buy a new ribbon assembly.
I HAV A DATAMAX I-CLASS PRINTER IT IS SAYING THAT I HAVE A RIBBON FAULT AND THE PRINTER IS THERMAL
Thermal can mean "Direct Thermal" (no ribbon) or "Thermal Transfer" (with ribbon). If you want to print using Direct Thermal labels you need to select Direct Thermal from Media Settings in the Menu accessed from the Control Panel on the front of the printer. Otherwise, the printer sensors will look for a ribbon that is not there, and you will see an error message.
Feb 16, 2015 | Datamax I-4208 Thermal Label Printer
Ribbon fault
Hold in the Feed button for 4-5 seconds, which causes the printer to attempt to "Auto-calibrate." If that doesn't solve it, then slide out the Media Sensor (green plastic bar that sticks out over the labels) about 1 inch from all the way in ("in" = left if looking from front). Then press Feed to clear errors. If still get same error, then look for piece of label or ribbon stuck in that error - ok to blow out with canned air. Then try holding in Feed again for 4-5 seconds to Auto-calibrate again.
May 08, 2013 | Datamax I-CLASS DMX-I-4406 Thermal Label...
Top of form fault
May 16, 2012 | Datamax W-Class W-6208 Thermal Label...
Errors= head cleaning fault. position fault
head cleaning fault, you need to remove the option for head cleaning.
The position fault may be due to either a wrong label size, wrong detecting sensor selection or your printer sensors needs callibaration
Aug 15, 2011 | Datamax M-CLASS DMX-M-4208 Label Printer
My datamax thermal is not heating up
These printers do not "heat up" as such. Possible causes are:
1. Incorrect ribbon type for fitted ribbon spools. Look at back plate and see which way arrows are pointing. If arrows point Anti-clockwise, then you require inside wound ribbon (i.e. standard datamax) If pointing clockwise then you require outside wound (i.e. Zebra type ribbon). Check ribbons by touching sticky side of label to ribbon (it will transfer ink to label on print side).
2. Could also be faulty printhead, Logic board or Power supply. These will require an engineer to check properly.
Jul 05, 2011 | Datamax M-Class Thermal Printer
WE HAVE A DATAMAX CLASS PRINTER AND IT'S GIVING ME AN ERROR " TOP F FORM FAULT" WE DO NOT HAVE THE MANUAL. CAN YOU PLEASE HELP? THANK YOU
Most likely problems:
Wrong sensor set in the media type area. Gap, Reflective.
If the incorrect meday sensor is set, the unit will give a TOF error.
If you hae pressed the feed button and kept pressed for at least 4 labels, and it does not automatically calibrate, check the type of sensor.
If you still get error, and the correct sensor is set, do a complete calibration.
You can downlad the user manual at Datamax-ONeil Web site.
Feb 24, 2011 | Datamax I-4208 Thermal Label Printer
Do you know the part number to order the ribbon or film?
After doing a little research, I can see why you are having a hard time figuring out the correct part number to replace the ribbon.
Here's what I found as a compatible ribbon on the CDW website:
http://www.cdw.com/shop/products/default.aspx?edc=2066585&RecommendedFOREDC=320985&RecoType=AP&cm_sp=Product-_-ComplAcc-_-Datamax+Pioneer+GPR+Plus+-+print+ribbon
The Datamax website has a chart with Media and Ribbon Requirements for I-Class models on page 111 of the following online PDF:
http://www.datamaxprintingsolutions.com/corp/88224101_p.pdf
Hope this helps. You may also wish to get purchasing help from the sales agents at a company like CDW or Tiger Direct (CDW's number is (800) 800-4239
Steve G.
Jan 20, 2011 | Datamax DMX-I-4212 Label Printer
Hello, i have a datamax i class he give a fault "top of form fault" i don't no what that is
The error is indicating that it cannot calibrate the media. Try holding in the feed key for approx 10 seconds and see if it will calibrate. Experiment with the position of the media sensor. It will slide horizontally.
Sep 25, 2010 | Datamax DMX-I-4212 Label Printer
Datamax I-4208 ribbon loading
Follow the arrow symbols stamped on the ribbon spool assy
Sep 24, 2009 | Datamax DMX-I-4212 Label Printer
Datamax I-CLASS DMX-I-4212
Printer ribbon has a wrinkle and it transfers to the label in the form of a blank line accross the ribbon.
Jun 03, 2008 | Datamax DMX-I-4212 Label Printer
Datamax H-Class H-4212X Printer Logo
157 people viewed this question
Top Datamax Office Equipment & Supplies Experts
pkwc
Greg Cann
Greg Cann
Kevin Brown
Level 1 Expert
Are you a Datamax Office Equipment and Supply Expert? Answer questions, earn points and help others
