Question about Panasonic TOUGHBOOK CF-18 Tablet PC
Bought used toughbook on ebay, no hard drive or OS. using my old hard drive from broken one. get to bios screen, but will not boot up into windows. I'm guessing some drivers may be jacking me up, how do I get around this issue and boot into windows? tried safe mode
    Guru:
  • 825 Answers
Reformat the had drive and install a fresh copy of OS from the compact disc.... once the installation is complete, boot up the computer again... if it works, then every thing is perfect....you can go ahead and install the drivers for your devices in the compter...
please clarify if you have any further troubles in installing the OS in your computer...
Posted on May 07, 2010
Panasonic toughbook cf-74 blue error screen loop
Which OS do you have? Have you tried booting to safe mode?. Restart the computer. Immediately after the BIOS post ends, start tapping the F8 key repeatedly. when Windows Advanced Options menu appears, select safe mode and see whether it boots completely without blue screen(BSOD)
Apr 22, 2014 | Tablets & eReaders
I am attempting to run full reload of this system using an exterior hard drive with usb connection. The reload will not start using thid device. I did not buy the docking station for this system when I...
Most laptops cannot boot up from a USB device/hard drive. Check the BIOS configuration to see if the USB is available in the boot order devices. In this case the USB driver is not available for use until Windows is installed.
If the USB is not available in the BIOS Boot order then you need to reinstall Windows using the installation CD in the CD drive..
Nov 24, 2010 | Compaq Refurbished TC1000 1GHZ...
My Panasonic Toughbook T2 was shut down properly and kept for about a month. now it does not boot. Even inital BIOS check function is not performed. Though HDD movement can be heard. Checked RAM by...
Is there any chance the video output is switched to feed the rear VGA connector? ie the screen is black due the video being routed away from the screen. Try hitting F5 key.
Can you hit the Delete key to try and enter the bIOS screen? (it may be another key such as F1 or F2. See your Toughbook manual)
Can you have someone make you a bootable USB thumb drive and try booting up with that?
Its also possible that the hard drive has failed, but usually the BIOS POST check will initiate and indicate a failed hard drive or bad RAM etc
Can you remove the 2.5 inch hard drive? Usually its accessible under a removable panel under the laptop.
Feel free to ask more questions.
Cheers,
Steve
PS have you tried the discussion forums on the Panasonic website?
May 03, 2010 | Panasonic TOUGHBOOK CF-18 Tablet PC
Toughbook cf-18 cannot boot thru window. it come out with a start using safemode, then go into window , then blue screen with "a problem has been detected and windows has been shut down to prevent damage...
Yu possibly have a virus
You will need to format the hard drive and reload Windows if this doesn't work you will need a new hard drive.
Try to "defragment the hard drive 1st. check the disk for errors.
Apr 27, 2010 | Panasonic TOUGHBOOK CF-18 Tablet PC
Screen is illuminated but blank.
Can you try restarting the Tablet and see if you get a result by tapping the F8 key?..on windows,that will put it into safemode and allow you do fix certain problems...please let me know..will try to get u fixed up
Apr 13, 2010 | Panasonic Toughbook-19 Tablet PC
Unable to install OS on Hard drive. Error PXE-E61: Media test failure, check cable. PXE-MOF: Exiting PXE ROM. Invalid partition table
When your computer failed to boot from the disk-drive, it tried to connect to a network-accessible "boot-server" via the Ethernet adapter.
However, if there's no cable connected to the computer's Ethernet port, you will get the "check the cable" error-message.
So, your real problem is "invalid partition table", which means that the very first record on the disk-drive is either missing or corrupt.
That first record contains the "partition table", which lists the size of the hard-drive, and the size of each partition (usually only one) on the hard-drive.
So, you'll need to buy an adapter that has a USB-plug on one end, and a connector for your "SATA" or "IDE" hard-drive at the other end.
Remove the hard-drive from your computer, attach it to the connector, and plug-in the USB connector to a USB port on another computer, and then use software to delete and then reconstruct the partition table.
Or, the hard-drive is failing, and must be replaced (maybe under warranty???).
Oct 22, 2009 | Panasonic TOUGHBOOK CF-18 Tablet PC
HOW TO INSTALL WINDONS XP PRO ON TOUGHBOOK CF-18
XP can not be installed from usb as the bios does not enable it. Plug the ide hard drive into an older desktop system and install from boot on cd. Once all files are copied over then you need to copy the i386 folder over from the cd. Reinstall the hard drive into the toughbook and carry on the install from there.
Jun 09, 2009 | Panasonic TOUGHBOOK CF-18 Tablet PC
Toughbook CF-18 Supervisor Passwd
Toughbook CF18, CF-18
How to remove the BIOS Supervisor Password:
Open all covers and openings. Remove hard drive and battery. Remove bottom of notebook. Many many tiny screws.
Now look towards the rear of the notebook. You will see 2 plugs both have a red and black wires. The one with the much smaller wires and connector is the BIOS battery. Use a pair of needle nose pliers and remove this plug.
Leave it off for 5-15 minutes.
Leave the BIOS battery plug off. Replace the laptop's main battery. Leave the hard drive out. Turn the unit over and turn it on.
Press F2 when the screen comes up. POOF! NO PASSWORD!
Go to Security and disable the password. Save configuration. Turn off the notebook. Replace the small connector. Turn it back over and turn it back on. Press F2 and verify that there is no password. Go to Security and Disable the password again. Save the configuration.
Put the bottom back on. You're done.
NOW FOR THE BAD NEWS!!!
Your hard drive is now dead. Replace it. When a supervisor password is used it locks the hard drive to that password. There is NO WAY to recover the hard drive. It is called an ATA security password. Without the ATA password the hard drive is completely useless.
Nov 10, 2008 | Panasonic TOUGHBOOK CF-18 Tablet PC
After a hard drive falure I need to install windows xp
At this moment I have taken the HDD out of the case, bought an adapter for its 1.8" interfce and proceeded over the USB. I was, however, installing Linux, with practically no experience with Windows.
Oct 21, 2008 | Toshiba Portege R100 Tablet PC
Cf-18 toughbook
The BIOS may not support the larger drive at all; I suggest you look for a Toughbook forum and repost there and check Panasonic's site for a manual download and possibly a BIOS upgrade if the unit is equipped with a flash BIOS.
Aug 27, 2008 | Panasonic TOUGHBOOK CF-18 Tablet PC
Panasonic TOUGHBOOK CF-18 Tablet PC Logo
461 people viewed this question
Top Panasonic Tablets & eReaders Experts
Paul Wang
Mike
Are you a Panasonic Tablet and eReader Expert? Answer questions, earn points and help others
